2019 2020 transmission cooler missing
Discussion in '2.5 Gen Tundras (2014-2021)' started by sgtfluffy16, Aug 10, 2020.
Thread Status:
Not open for further replies.
  1. Aug 17, 2020 at 3:13 AM
    #601
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    I wouldn’t sweat it. Keep in mind, there have been no transmission failures due to overheating. None.
  2. Aug 17, 2020 at 3:55 AM
    #602
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Welp... the beatings shall continue until morale improves.
  3. Aug 17, 2020 at 7:05 AM
    #603
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    :rofl:. So apropos
  4. Aug 17, 2020 at 7:20 AM
    #604
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    But the oldest 2019 has only been on the road for about 2 years. Even a Ram transmission won't fail that quickly...
  5. Aug 17, 2020 at 7:25 AM
    #605
    tttrdpro
    SWGA
    2024 GMC 2500 AT4
    In progress…
    True, but I just don’t see any point in hyperventilating about something that may or may not be a problem. Maybe it’s just me.
  6. Aug 17, 2020 at 7:27 AM
    #606
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
  7. Aug 17, 2020 at 7:40 AM
    #607
    I’ll take that bet....:D
    Seen Ram transmissions fail rather early.
  8. Aug 17, 2020 at 7:48 AM
    #608
    tttrdpro
    SWGA
    2024 GMC 2500 AT4
    In progress…
    And GM & Ford.
  9. Aug 17, 2020 at 8:12 AM
    #609
    That’s a fact. One of my Navy buddies that owns a construction company in Michigan has either some tough luck, or needs a different truck. All three of his last GM 1500’s transmissions have failed just past 100k miles...like clockwork.
    Could be an underlying cause like services and what not or towing a bit more than he should for long distances.
    Interesting enough, GM also removed the trans coolers from their 1500 lineup.:rolleyes:
    Hummmmm
    ryanwgregg likes this.
  10. Aug 17, 2020 at 8:42 AM
    #610
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    That's what the guy on Truck Talk said too but you can still get one with the Max Trailering Package (unless that's changed for 2021).
  11. Aug 17, 2020 at 8:42 AM
    #611
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    GM spends lots of money in "lifecycle engineering" with 100K miles as the benchmark.
  12. Aug 17, 2020 at 8:55 AM
    #612
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    That's the Marketing Division of the Engineering Group.
    sgtfluffy16[OP] likes this.
  13. Aug 17, 2020 at 8:58 AM
    #613
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Our 2019 Tahoe, without Max trailering, has an "auxiliary" trans cooler. Its built into the radiator.
    The trans temp stays pretty consistent between 190F and 200F daily driving with amb temps over 100F. I'm looking now to see if there is a way to "pin the tstat" as can be done with the tundra.
  14. Aug 17, 2020 at 9:01 AM
    #614
    A lot of vehicle manufacturers do this very thing. I once heard a Porsche/Audi engineer once state:
    “We took oil change intervals up to 10k miles for a couple reasons. Less use of oil, looks cheaper to operate over time, and engine replacements will not be at 3-400k miles, but 150-200k miles.”
    Think about that when a manufacturer tells you 10k+ miles between oil changes is perfectly fine. Even if sending oil out to Blackstone labs and they say oil is fine...no thanks. Oil is cheap and recycled. I go 5k max.
  15. Aug 17, 2020 at 9:04 AM
    #615
    I’m editing some videos for you all from the other night.
    What I’m trying to show is not a certain brand superiority or start arguments. What I hope show is a properly cooled transmission, gear selection in TC lockup can really help with temps.
    Attempting to edit and upload 1 hour of video has been fun.
  16. Aug 17, 2020 at 9:08 AM
    #616
    14burrito
    2014 SR5 CM 4x4 5.7
    Can you share this trick to "locking the TC" in 5th, 6th gear when under load? The behaviour should be controlled ECM/TCM via load mapping, etc. I have heard a few time people stating they they can "lock the TC in 5th and 6th" like it was normal, manually operated function...
  17. Aug 17, 2020 at 9:23 AM
    #617
    Melikeymy beer
    Muscogee Nation
    Aside from running at a higher RPM and possibly using more fuel, is there a downside to S4 in tow/haul mode at 65 mph when towing my TT?
  18. Aug 17, 2020 at 9:31 AM
    #618
    There is no trick. The TCM does it for you. The only other way to lock your TC is have aftermarket TC controller. Some think by shifting in manual, and the trans actually shifts, TC lockup has been completed. In reality, the trans is heating up quick in a higher gear.
    14burrito[QUOTED] likes this.
  19. Aug 17, 2020 at 9:33 AM
    #619
    Your situation might be different than mine. I always used D/TH mode for 89k miles. With the weight i was pulling and being in CO, I never was able to get into 5th gear. My Tundra sang in 3/4th gears all day long.
  20. Aug 17, 2020 at 9:42 AM
    #620
    14burrito
    2014 SR5 CM 4x4 5.7
    But it does it under specific conditions.
    I guess I misread others stating that they were able to do so on the fly...
  21. Aug 17, 2020 at 9:54 AM
    #621
    Melikeymy beer
    Muscogee Nation
    Pulling my 6k lb, 22 ft trailer, the truck will absolutely go to 5th when on flat stretches of highway at 65 mph. RPM is probably less than 3k in S4 which doesn't bother me.
  22. Aug 17, 2020 at 10:00 AM
    #622
    Ok, editing completed. My first video had all the music deleted due to copyright violation...even though I purchased the music. :rolleyes:
    **disclaimer.
    I was using a iPhone mount around my neck for over an hour. The videos are not great, but I had more important things to do like drive.
    end of disclaimer**
    This is towing 9k lbs, truck is 7800 lbs, for a GCWR of 16800 lbs. Ambient temperature was 81*, speed varying from 65-75 mph. Elevation 7500’.
    Again, this is not intended as a brand bashing post, nor is it for anything else other than showing what good transmission cooler can do and showing you can tow in OD, as long as converter lockup is maintained. My coolest temps were in converter lockup in OD.
    Trans temps stabilized out at 140* on the highway. I was in 6th gear, converter lockup. I can maintain 68 mph in 6th gear and not have higher EGTs or coolant temps. I personally try to keep the speed at 70 mph unless the speed limit is 75.
    Since my audio was deleted along with my voice, towards the end, you can see me slowing down and making a right hand turn from the highway. Some stop and go, and trans temps went up a bit, but not bad. This video was done in CC, exhaust brake on. The exhaust brake function will increase transmission temps a bit, but I like having the extra braking if needed.
    In this video, I have just started on a pretty good stretch of passes and trans temp is around 156*, in 5th gear, converter lockup. On one of the rather large passes, temp didn’t even go up.
    CC on, exhaust brake on.
    This last one, a bit long, and maybe some offensive language :D. I was in 2nd and 3rd gears, out of lockup (yes, the Allison can lockup the converter in lower gears due to exhaust braking), and at one point you can see me turn the exhaust brake off.
    Temps started to rise quickly. The video showed 162* from 140* in a matter of 6 min. After I parked and let the truck idle down and cool everything off, trans temp went up to 171* and then started to cool off. Technically the trans temp went from 140* to 171* in the 7 min video. This is a rough road and a pretty good climb, so the higher temps are expected.
  23. Aug 17, 2020 at 10:02 AM
    #623
    Do you have a scanguage? When going into 5th, does the converter lock?
  24. Aug 17, 2020 at 10:41 AM
    #624
    Melikeymy beer
    Muscogee Nation
    No scanguage, don't know if it locks. I'm really just wondering if it will cause any issues to just use S4. The RPMs at 65 mph don't bother me at all.
  25. Aug 17, 2020 at 10:56 AM
    #625
    I don't believe you will have any issues. Others in this thread with a SG reported lower trans temps in S4/TH mode. The only thing you are missing out on is grade braking beining in manual shift mode, which isn't the tundra's strong point.
  26. Aug 17, 2020 at 11:05 AM
    #626
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    But if you're in S4, isn't it easier to just drop it into S3 if you need grade braking, rather than relying on the truck to figure it out?
  27. Aug 17, 2020 at 11:11 AM
    #627
    I would say it would be. To engage grade braking you need to be in D/TH mode and initiate by depressing the brake pedal and the transmission should downshift.
    Funny, I just did this out on my DM. During this video, I was going to show how the exhaust brake and grade braking worked well together to maintain 60 mph. Well, I forgot to take the shifter back out of manual mode and back to drive. My truck just took off down the grade up to 73 mph. Glad I wasn't on Vail Pass (Ike Gauntlet):rofl:. The exhaust brake worked a little, just not as effective at lower RPM.
  28. Aug 17, 2020 at 11:12 AM
    #628
    sgtfluffy16
    sgtfluffy16 [OP] New Member
    Corey
    2019 Super White Tunda TRDPro
    Stock
    weird how this video has been marked private now. Probably because he was telling a WHOLE BUNCH OF LIES that hundreds have questioned him on and his sources
    sask3m likes this.
  29. Aug 17, 2020 at 11:23 AM
    #629
    tttrdpro
    SWGA
    2024 GMC 2500 AT4
    In progress…
    I watched that video last week. IIRC he had a viewer send him an email about the lack of aux. trans cooler on 19+ Tundras and he basically covered both sides of the argument. No lies as I recall but no new info either.
  30. Aug 17, 2020 at 11:31 AM
    #630
    blanchard7684
    blanchard7684 New Member
    Yes it’s early in service life.
    however the narrative offered is that the temp range the transmission lives in can either immediately fail the fluid; damage seals; or otherwise hurt other internal components.
    so I think it is valid to point out the lack of trans failures... at least in relation to ab60f failures running a cooler.
    Other OEMs are running elevated temps even with a cooler and their failure rate doesn’t seem to be incrementally higher.
Thread Status:
