2019 2020 transmission cooler missing
Discussion in '2.5 Gen Tundras (2014-2021)' started by sgtfluffy16, Aug 10, 2020.
Thread Status:
Not open for further replies.
  1. Aug 15, 2020 at 6:50 PM
    #571
    blanchard7684
    blanchard7684 New Member
    Yep very much this...
    went out and ran the truck hard today and couldnt get pan temps above 229.
    103 to 105 ambient.
    Oil temps ran right along with trans temps.
  2. Aug 15, 2020 at 7:10 PM
    #572
    Allrsdup
    Allrsdup New Member
    Joe
    24 Lunar Rock Limited crewmax trd ord
    same here, 111 here today trans ran at 212... apparently according to some we are doomed.. lol
    cnoyes72 and Melikeymy beer like this.
  3. Aug 15, 2020 at 7:10 PM
    #573
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
  4. Aug 15, 2020 at 8:05 PM
    #574
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Your engine oil temp ran at 229 with the trans temp?
  5. Aug 15, 2020 at 8:35 PM
    #575
    Vizsla
    Vizsla 2 = 2.5
    5.7 does not have a oil temp sensor, it’s an inferred value, if this is that then oil temp is probably this if that makes sense. It’s always 1-2 deg below tranny pan temp from my experience. Suspect it’s lower, probably coolant temp.
    osidepunker and Sumo91[QUOTED] like this.
  6. Aug 15, 2020 at 8:40 PM
    #576
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
    This is my pic from my truck. No trailer, no bed weight. Just driving on a flat highway with a headwind. I do this drive weekly and have hit 250 but was too busy to snap a pic.
    sask3m likes this.
  7. Aug 15, 2020 at 9:50 PM
    #577
    blanchard7684
    yep.
    coolant temps at 203-204 in heavy repeated acceleration like hot lapping at the track. 4-5 0-80 runs and 4-5 60-80 runs. And a few 0-95 runs all in Short succession.
    ram 5.7 hits 248-252 on engine oil temp. High alarm is 265 on those.
    not concerned about engine oil temp.
    Trans temps seemed to be under control with heavy acceleration in high ambient temps. Tc temps would shoot up and then drop on lock up with only minor increase in pan temps.
    Trans temps quickly move up to 220-225 range but took lots of heavy loads to get up to 229.
    if it’s the case that fluids are good to 280 and high temp alarm is 302 then I’m ok.
    however if I was towing at full capacity I’d likely add a cooler.
    Sumo91[QUOTED] likes this.
  8. Aug 15, 2020 at 9:59 PM
    #578
    Sumo91
    TN
    Never mind guys, my head wasnt screwed on right when I made that post lol I misinterpreted that as the coolant temp for some reason :bananadead:
  9. Aug 16, 2020 at 12:35 AM
    #579
    I was towing tonight thinking about this thread a bit.
    If the shoe was on the other foot, and my new truck I just paid good money for had the transmission high temp warning message come on, can’t say I wouldn’t be a little upset (especially at half of the tow rating).
    I took some video tonight of converter lockup, temps, and what not. Let me know if you all want to see them. It’s not a Tundra, so totally get that if you don’t.
  10. Aug 16, 2020 at 1:05 AM
    #580
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    And thats what I was saying in a previous post, if it happens and you are towing, hauling whatever within the specs that Toyota says then take it to a dealer, have it checked out and documented. Its the only way to have Toyota solve what could be a potential issue.
  11. Aug 16, 2020 at 6:32 AM
    #581
    I would have already installed the cooler and been done with it or sold my Tundra and purchased something else. I’m not brand loyal and just need the best tool for the job at hand. On the flip side, I was pretty happy to have my CPO warranty on my 2012 Tundra (front differential replacement, had the cam tower leak, front wheel bearing). The dealership started blaming my Bilstein 6112 shocks on the lowest setting for the front diff issues. I politely reminded them about how a TRD Pro has a factory 2” lift and they backed off.
    Wish there was a perfect truck/car/boat etc that would do everything with perfection. Unfortunately there isn’t and owners have to make their own decisions. If you think my current truck is factory, you would be wrong. I know the weak spots on the Duramax powered trucks (no lift pump) and resolved them.
  12. Aug 16, 2020 at 6:52 AM
    #582
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Spot on.
    PWMDMD likes this.
  13. Aug 16, 2020 at 7:55 AM
    #583
    blanchard7684
    No worries...also meant to mention new Rams thermostat is 203F and unloaded in high ambient temps they hit 228-235F.
  14. Aug 16, 2020 at 9:19 AM
    #584
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    I installed a cooler on my 19 and when towing 6000lbs my pan temp is generally in the 190-200 range unless crawling a steeper mountain grade then I've seen it hit around 205. The convertor temps run in the 190-225 range and the 225 drops like a rock with the convertor locked once you've crested the hill. Unloaded the pan sits pretty much a constant 185.
    Wallygator, jetfishn, rebmo and 2 others like this.
  15. Aug 16, 2020 at 10:47 AM
    #585
    sgtfluffy16
    sgtfluffy16 [OP] New Member
    Corey
    2019 Super White Tunda TRDPro
    Stock
    what cooler did you use? Care to share some pictures? Im assuming you used the Toyota 32970-34030?
  16. Aug 16, 2020 at 11:21 AM
    #586
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Absolutely nothing new I can add here, except:
    "One of these nights, one of these crazy old nights
    We're gonna find out, pretty mama, what turns on your lights
    The full moon is calling, the fever is high
    And the wicked wind whispers and moans
    You got your demons, you got your desires
    Well, I got a few of my own..." :D
  17. Aug 16, 2020 at 11:28 AM
    #587
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Sorry if I missed it earlier in this thread but did you measure your temps while towing that same trailer on the same route before adding the cooler?
    Bammer likes this.
  18. Aug 16, 2020 at 11:45 AM
    #588
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    “One of these days
    I’m going to cut you
    Into little pieces”
    P. F.
  19. Aug 16, 2020 at 11:50 AM
    #589
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    That's a b&m 70274 cooler. My son drew up a bracket for me using autocad and I had it cut at a local place. It's based off of nicks design. It's made from standard steel 1/8", I did go have it powder coated as well to deal with any rust issues.
    Yes I did use all toyota factory up to the cooler.
    I'm in Canada other wise I would have just gone with his package deal.
    Wallygator likes this.
  20. Aug 16, 2020 at 11:55 AM
    #590
    palehorse
    palehorse @grey_ghost_trdpro
    Mount Pleasant, SC
    2020 TRD PRO
    Cruising down the interstate, flat area at 70mph. 88F outside.
  21. Aug 16, 2020 at 11:59 AM
    #591
    JohnLakeman
    Sorry for offending you Chris. I don't have dog in this fight, will abstain from any further comments. It's all been said anyway. :thumbsup:
  22. Aug 16, 2020 at 12:02 PM
    #592
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    The pan temp was high 240's and that was with temps at around 16c. Only went for half an hr round trip to see before installing the cooler, not the same route but did go over some grades.
  23. Aug 16, 2020 at 12:14 PM
    #593
    rebmo
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    Installed Nick's Cooler kit with the Toyota Thermostat and lines to the cooler. Was running pan temps of 217F ambient 80s unloaded, TC near 230F. Pan temps were 230F towing a 3500lb boat/trailer/motor, 3 adults, and about 300lb of luggage, gear, etc.. with TC temps spiking at 249F pre-cooler install.
    After the Cooler installed I'm running 186F in 80s ambient temps with the thermostat unpinned. I have not had a chance to tow the boat yet but 230F pan and 249F TC peaks are too high for my liking only towing a 3500lb boat and 3 adults and gear. I'm very pleased with the cooler installed and pan temps at 186F in mid to high 80s ambient temps unloaded. A 30F drop in pan temp has to be an improvement for transmission life from everything I've' read and increase the fluid life.
    I do live in a northern weather climate so the cooler will likely not be doing anything towing my snowmobile trailer in 0-30F temps but the warmer puck is in place to bring the transmission to operating temps quicker with the transmission heat scavenging from the engine radiator coolant. I'm not sure at what temp the transmission coolant thermostat opens, but the cooler is hot to the touch when the pan temp is at 186F after a 30min highway run. I suspect if partially starts opening if not fully opened at the 186F pan temps.
  24. Aug 16, 2020 at 12:21 PM
    #594
    tttrdpro
    SWGA
    2024 GMC 2500 AT4
    In progress…
    You didn’t offend me at all John. You put in a lyric from a band and I put one in I thought was kinda/sorta related. Just being silly today I guess. Sorry for the mix up.✌️
  25. Aug 16, 2020 at 12:28 PM
    #595
    JohnLakeman
    I was trying to add a little humor, but it wasn't my place...this is a deadly serious thread. I thought I might have ticked you off. :cool: :thumbsup:
  26. Aug 16, 2020 at 1:03 PM
    #596
    Melikeymy beer
    Muscogee Nation
  27. Aug 16, 2020 at 7:35 PM
    #597
    ‘19pro
    ‘19pro New Member
    Walter
    19 Tundra Pro, black
    295/75-18, TRD intake, CB pro kit.
    Well shoot, now I’m concerned about trans temps. Will be towing a unloaded 3500 lb. v nose from central Texas to Southern California upcoming weekend. Return trip will be loaded to 7100 lb... I figured the truck had an external cooler! Even though I had never seen it. I am for sure putting the original tires back on the thing before I go, no need for useless additional rotational weight to further exacerbate the trans temp.
    I have never had the trans temp warning come on while driving 70+ mph on the highway with 34.6s un-geared in the summer heat so I figured I was good.
    Do y’all see a potential issue with trans temps in my future?
    AZ_Tundra1 likes this.
  28. Aug 16, 2020 at 7:40 PM
    #598
    AZ_Tundra1
    AZ_Tundra1 Gold member
    Phoenix, AZ
    2020 White Tundra SR5
    Bilstien 6112 front shocks set at 1.9"
    Get one of those Bluetooth OBD2 readers and keep an eye on it. There are things you can do like keep it in S4 but you will probably be fine.
  29. Aug 16, 2020 at 8:33 PM
    #599
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    Hope this doesn't offend, but...
  30. Aug 16, 2020 at 8:42 PM
    #600
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Not offended, but i disagree with the beatings. This is a fairly new (uncovered) potential problem, not like an oil or tire size thread. But that's just me. :notsure:
    rebmo and MSU Tundra like this.
Thread Status:
