2019 2020 transmission cooler missing
Discussion in '2.5 Gen Tundras (2014-2021)' started by sgtfluffy16, Aug 10, 2020.
Thread Status:
Not open for further replies.
  1. Aug 14, 2020 at 9:26 AM
    #391
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    That's what she said.
  2. Aug 14, 2020 at 9:36 AM
    #392
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    To all the folks complaining about the missing trans cooler, auto lsd, or whatever else; please sell/trade your truck immediately and do some fucking research before your next purchase. Have a great day!
    316KS_Runner, Bammer and Moon Puppy like this.
  3. Aug 14, 2020 at 9:38 AM
    #393
    blanchard7684
    blanchard7684 New Member
    Yes this is possibly true.
    However it is also the case that the change to R1234 was known and associated changes were planned and tested to support it. OEM's typically don't wake up and go "oh crap we have to change freon next model year...everyone run and panic!"
    The "no transmission cooler, and R1234" permutation was likely known for a while and needed to be tested on current model years regardless of the changes coming.
    Cpl_Punishment and Clemsonman14 like this.
  4. Aug 14, 2020 at 9:56 AM
    #394
    RightBatwing
    RightBatwing New Member
    2020 Tundra SR5 4x4
    I guess I should go check and see if my 38 gallon tank is there. :boom:
  5. Aug 14, 2020 at 10:11 AM
    #395
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    Lol
    Cpl_Punishment likes this.
  6. Aug 14, 2020 at 10:15 AM
    #396
    MSU Tundra
    MSU Tundra Numerous rodeos experienced
    Mississippi
    2017 Tundra and 2013 LC200
    Nah, I did my due diligence. I owned a 2012 with tow package prior to purchasing my 2019. I never had high trans temps on my 2012. When it came time to purchase my 2019 last April, I verified that the window sticker had the same tow package with larger gears, HD battery and alt, and the engine/trans oil coolers (was worded exactly the same as my 2012 window sticker). I was lead to believe that my transmission was the same setup as my 2012. There was nothing published (or even on a forum) back then to tell me otherwise.
    So no, I'm not going to sell my truck immediately. I will productively complain and hope there is a resolution from Toyota. If there isn't, then I will change my fluid out more regularly and consider installing an aftermarket cooling system.
    Have a great day! ;)
  7. Aug 14, 2020 at 10:23 AM
    #397
    tttrdpro
    SWGA
    2024 GMC 2500 AT4
    In progress…
    My comment really wasn’t directed at you but at some others who are always complaining about something they really should have known before they bought the truck, but thank you for your prompt reply. I am having a great day!
  8. Aug 14, 2020 at 10:23 AM
    #398
    Rex Kramer
    Georgia
    When did dealer window stickers become Gospel?
    EDIT: I haven't purchased a brand new vehicle in about 25 years, and I remember dealers had a practice of replacing the manufacturers window sticker with their own dealer window sticker... I was taught not to trust the information found on "dealer window stickers".
  9. Aug 14, 2020 at 10:32 AM
    #399
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 OR MGM 5.7
    In 1958.
  10. Aug 14, 2020 at 10:32 AM
    #400
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Got a call from Schaeffers earlier regarding my question about their fluid ( I use 204SAT) They said above 230F, it will begin to oxidize slightly, but only if the fluid stays at that temperature for extended periods, around an hour or so. Pulling hills or passing someone is completely fine and will not hurt the fluid to spike up to 250 while doing so for a few miles while pulling hills, etc. The fluid starts to break down at 300F and will break down rapidly at 350F+. But at those temps I'd be worried more about the clutches than the fluid. Hope this helps
  11. Aug 14, 2020 at 10:33 AM
    #401
    Ericbike6
    Ericbike6 So we're doing this shit today?
    Eric
    Austin, TX
    2019 Tundra TRD 4X4 sport
    Air bags, ARK liners, misc bullshit added also
    No need for that, I can tell every time I fill it up!! $$$$
    Moon Puppy and BravoDeltaRomeo like this.
  12. Aug 14, 2020 at 10:33 AM
    #402
    MSU Tundra
    Mississippi
    So Rex, I'm curious. What would you have done? Hooked up an OBDII reader during the test drive to monitor the trans temp so you could ensure that the cooling system performed the way every year Tundra prior with the same advertised option did? Or maybe you would have contacted someone at Toyota Motor Manufacturing to see if they made any undisclosed changes to the drive train for the 2019 model year?
    Give me a break.
    Alex38, Jtundra81, Eaganite and 4 others like this.
  13. Aug 14, 2020 at 10:57 AM
    #403
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    LMFAO!!!
    Moon Puppy likes this.
  14. Aug 14, 2020 at 11:01 AM
    #404
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I bet you thought your main bearings caps were torqued correctly.
    That's right... get under there.
    GODZILLA likes this.
  15. Aug 14, 2020 at 11:08 AM
    #405
    Rex Kramer
    Georgia
    I know you are.
    As I mentioned in my previous comments, I would open the hood and inspect before I made my buying decision. I would question the absence of a remote transmission cooler... I would make sure I knew as much about the changes made so that I could make an informed buying decision.
    What would you do?
    BravoDeltaRomeo likes this.
  16. Aug 14, 2020 at 11:14 AM
    #406
    Ghost23
    Ghost23 New Member
    2015 Tundra
    Yes, it always helps to look and ask questions. But a lot of people don't know what they would be looking for to begin with. They just know that it has something that keeps the trans cool. That is what Toyota put on the window sticker. A good salesperson could really talk up that trans cooler (warmer) if someone did question it.
  17. Aug 14, 2020 at 11:19 AM
    #407
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Or there might be no point in asking because the salesman knows less about the truck than you do.
    Alex38, Bammer, JohnLakeman and 4 others like this.
  18. Aug 14, 2020 at 11:23 AM
    #408
    Rex Kramer
    Georgia
    True!
    This is why the buyer should always do their own research, and press on until they find answers to their questions.
  19. Aug 14, 2020 at 11:28 AM
    #409
    RightBatwing
    2020 Tundra SR5 4x4
    Being brand new to Toyota, and given the amount of people looking at this truck before I signed on the line for a really good price I admit it was a bit rushed. Although, I did ask about the tow package and what it included. I recall specifically looking at used 18's and 17's with coolers, but the salesperson for my new one I guess probably didn't know or didn't feel it necessary to explain any differences.
    You win some you lose some, but I do believe Toyota should at least somehow justify the change and make it CLEAR that these new trucks DO NOT have an external radiator for the transmission like they used to. Its like every vehicle, nothing is perfect but I always like to inch that way towards it to save trouble and $$ down the line.
  20. Aug 14, 2020 at 11:32 AM
    #410
    Ghost23
    Ghost23 New Member
    2015 Tundra
    They just want to sell vehicles. They will say anything to make a sale. No matter if they know less than the buyer.
  21. Aug 14, 2020 at 12:32 PM
    #411
    MSU Tundra
    Mississippi
    If you're so informed, then you would know that opening the hood on a 2019 would not reveal whether or not there was a remote transmission cooler. Even if it didn't use the ac condenser (like in my '12) and was a separate unit by the radiator, one would be looking at it through the grill and not by opening the hood. You know not what you are trying to speak of.
    What would I do?... I would read and believe that Toyota advertised the product accurately. Which is what I did, and why I am complaining. I don't understand why you are trying to be devil's advocate here? You have no dog in this fight and you are bringing no helpful information to this thread. Troll on though if it makes you happy.
  22. Aug 14, 2020 at 12:38 PM
    #412
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Can't believe a car salesman would lie. What's the world coming to?
  23. Aug 14, 2020 at 12:51 PM
    #413
    RightBatwing
    2020 Tundra SR5 4x4
    I literally just got off the phone with Toyota Customer Support after spending an hour combined on hold back and forth. I advised them of my concern with the temperatures I was seeing driving and towing and about the previous year model specs. They opened a case and gave me a case number on the issue. I then was transferred to another person, an engineer maybe? They advised me that the "transmissions cooling system is working as designed and that those are normal temperatures for the new design". I also asked about adding the older Toyota part with thermostat with an external cooler, this would absolutely void my warranty noted as "tampering with factory installed parts not indented in the design". I next asked about changing to a different fluid (Amsoil) that may deal with the temps better since my temp lights had came on. They advised me that that would also void my warranty.
    The first person I spoke to said this was the 3rd or 4th call they have about people complaining about trans. temps this week on 19/20 models and they have had no reported failures and no service bulletins are in effect. Apparently the common denominator of callers were folks who discovered the temps and "have been online reading and were armchair mechanics", said the second person they let me speak to. Basically telling me in other words to run the piss out of it, it is under warranty and ignore the temps its "normal".
    JohnLakeman likes this.
  24. Aug 14, 2020 at 12:54 PM
    #414
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    I gotta agree on this one. While I’m not so wound up because I don’t tow a lot but if I bought my Tundra for a tow vehicle and found this out after the fact, I’d be hot (pun intended!)
  25. Aug 14, 2020 at 1:02 PM
    #415
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    There you go.
    Eschew this Catch 22 they're providing, and (1) drive that MF like it's on loan from Toyota (assumes you trade trucks every five years or less), or (2) install an external cooler (if you keep your trucks forever). No more anxiety. :thumbsup:
    I hope you apologized for interrupting their busy day with this silly-azz problem. :D
    Ghost23 likes this.
  26. Aug 14, 2020 at 1:08 PM
    #416
    RightBatwing
    2020 Tundra SR5 4x4
    But I want a warranty and a cooler. :( I feel like if I wait till 60k when the warranty is done it will be too late to do any good.
  27. Aug 14, 2020 at 1:10 PM
    #417
    glowblue
    VA
    I’d get an extended warranty if anything for the cam tower leak and faulty transmission!
    Ghost23 likes this.
  28. Aug 14, 2020 at 1:17 PM
    #418
    JohnLakeman
    Yeah, I know. But...You bought Toyota because you knew they were reliable. What are the odds you're going to need the transmission warranty if you take care of the transmission by retrofitting an external cooler? And, even if you do have a transmission problem, removing that cooler before taking it in would be a real pita, but doable for a possible $5K-$7K repair. They want to play games, accomodate them. JMHO.
    Ghost23 likes this.
  29. Aug 14, 2020 at 1:20 PM
    #419
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Interesting thread, I have spent several days off and on reading thru it.
    I see some interesting points of views from all sides.
    IMO, I would not worry about this. Toyota designed it that way for a reason, good or bad, time will tell. I say drive it, pull it and haul it. If the transmission fails then file a claim for warranty if its under warranty, its there for a reason. If its out of warranty and you think you will feel better about things with a external cooler then add one to it, heck even its still covered by a warranty and you think one will put your mind at ease then add one to it.
    Other than that drive it and enjoy it. I dont think I will waste my time worrying about a external cooler.
  30. Aug 14, 2020 at 1:24 PM
    #420
    Ghost23
    Ghost23 New Member
    2015 Tundra
    I would run that truck so hard! Break it and make them fix it
Thread Status:
