2019 2020 transmission cooler missing
Discussion in '2.5 Gen Tundras (2014-2021)' started by sgtfluffy16, Aug 10, 2020.
Thread Status:
Not open for further replies.
  1. Aug 13, 2020 at 1:27 PM
    #271
    18" TRD Off Road Wheels
    That's pretty cool actually. Thank you for sharing your experience.
    SomeGuy4 likes this.
  2. Aug 13, 2020 at 1:43 PM
    #272
    sgtfluffy16
    sgtfluffy16 [OP] New Member
    Corey
    2019 Super White Tunda TRDPro
    Stock
    Yes, the trans fluid temp is getting too hot. Look at the standard basis (as shown in multiple posts on here) the fluids operating temperatures and what they do at each stage above 220F. Toyota can't and still has yet to give specification of the transmissions "normal" operating temperature range. Nor will they even say at what temperature the fluid starts to decompose
    It is NOT a synthetic fluid, Spoken directly from my ExxonMobil rep. "Toyota WS ATF fluid is NOT a synthetic fluid"
    Flash points are relevant to an extent, but thats the peak the fluid can reach before total failure. The important # is to know as what temperature does the fluid START to "breakdown" decompose
  3. Aug 13, 2020 at 1:43 PM
    #273
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Dont me get started on our 2019 Tahoe.
    Powertrain issue after powertrain issue that never seem to "be able to be recreated" - BS guys, fcuking BS. Now, top end noise - sounds like an oil pressure issue on cold start. Going back next week. Yay.
    Cpl_Punishment likes this.
  4. Aug 13, 2020 at 1:46 PM
    #274
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    ^This! I agree 100%. The transmission team didn’t just have a meeting and say “well geewhiz, we’ve not had any problems with our transmissions let’s remove the cooler and see if anyone notices! And let’s see how long before they overheat and fail...”
    There was a reason and I am confident it what evaluated, tested, analyzed, etc. well before the change in the 2019 MY.
  5. Aug 13, 2020 at 1:46 PM
    #275
    blanchard7684
    blanchard7684 New Member
    Clearly didn't look through my post.
    If this was the case then their own branded "Synthetic ATF" isn't "synthetic" either.
    Does that make any sense?
    No it doesn't.
  6. Aug 13, 2020 at 1:49 PM
    #276
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Is it like engine oil where "full synthetic" and "100% synthetic" mean two different things?
    Bammer and sgtfluffy16[OP] like this.
  7. Aug 13, 2020 at 1:58 PM
    #277
    sgtfluffy16
    Corey
    Stock
    its really easy. monitor your own transmission fluid temps. Compare them to a 2018 model or older where the only thing that has changed is the removal of the external transmission cooler. Make your own opinions from there and call toyota with your concern if you have one. but the ONLY way this is going to get resolved is if MULTIPLE people are raising this concern directly to Toyota
    lifetime powertrain warranty???? through Toyota? thats a new one!
    reliabilty territory is the ENTIRE REASON why i am doing this thread and this post and spending so much time on all of it.
    Ding Ding DING! you hit the nail on the head.
    I can buy some Wolf's Head oil. Put a few drops of a synthetic compound in it and call it a "synthetic" blend oil.
  8. Aug 13, 2020 at 2:02 PM
    #278
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    The lifetime powertrain warranty is something some dealers in this area do and yes I have it in writing.
  9. Aug 13, 2020 at 2:05 PM
    #279
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2025 RAM 3500 6.7L Cummins
    Nah. I bought this super duper reliable Tundra so I don't have to spend money doing stuff like monitoring transmission temps while pulling a trailer 2,000 lbs below max tow rating. Shit, I could have bought a Ford if I thought this truck was that crappy.
  10. Aug 13, 2020 at 2:10 PM
    #280
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    I see too much "may" and "might" regarding high temps, by having installed a cooler it's "will".
    mountainpete likes this.
  11. Aug 13, 2020 at 2:11 PM
    #281
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    Same here. Lifetime powertrain as long as I let them service the vehicle
    ryanwgregg likes this.
  12. Aug 13, 2020 at 2:17 PM
    #282
    tttrdpro
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Yep, that’s the only stipulation and I have no problem with it. I figure it gives them a little extra incentive to do things right.
  13. Aug 13, 2020 at 2:31 PM
    #283
    timsp8
    NY
    From what I have read it was a change in refrigerant in 2019 that caused a change in the ac condenser and the atf cooler could no longer be integrated.
    07-mid 10 the atf cooler was separate in front of the condenser and radiator.
    mid 10-18 the atf cooler was integrated with the ac condenser.
    If the condenser had to be redesigned in 19 because of new refrigerant, Toyota wasn’t going to design and test a new separate cooler for 2 or 3 model years knowing the tundra was being redesigned already. The separate one from 07-10 won’t fit, bolts don’t line up.
    Toyota can’t simply put the old ac condenser/ atf cooler on an 19/20. They aren’t going to design a new one on a truck on its way out. They also aren’t going to contract an aftermarket company like Hayden to add one. They have said several times it’s within spec and that’s going to be their (and their lawyers) final answer.
    If I had a 19/20 I was keeping, I’d add one myself. It’s easy to remove if you ever have trans issues before you take it to the dealer.
    FrenchToasty likes this.
  14. Aug 13, 2020 at 2:38 PM
    #284
    glowblue
    VA
    Sell it! Prices on used Tundras are sky high right now. No better time to dump it and cash out.:bananadance:
  15. Aug 13, 2020 at 2:41 PM
    #285
    Re-read what you quoted me on. I was speaking to another member about potential liability issues with an over loaded truck.
  16. Aug 13, 2020 at 2:48 PM
    #286
    Melikeymy beer
    Muscogee Nation
    It's not as bad as I whine about. My plan is to keep it until I get a motorhome in a few years or just sell the TT. It's OK. Just not blown over.
  17. Aug 13, 2020 at 2:49 PM
    #287
    This is Toyota to all the keyboard engineers:
    “You guys are right. Let’s recall all 19 & 20 Tundras, Tacoma’s, 4R and install transmission coolers!”
    While we are at it, we should complain about AIP, Cam Tower Leaks, needle bearing failures in the front differential. Let’s get this done! Is there a petition to sign someplace?
  18. Aug 13, 2020 at 2:50 PM
    #288
    Cthulhu
  19. Aug 13, 2020 at 2:52 PM
    #289
    blanchard7684
    yeah terminology is getting in the way--but your sentiment is accurate.
    The SDS doesn't show the actual composition.
    What is shown is the description of the processing to get the oils--this is a huge hint for synthetic vs non synthetic.
    Hydrotreating and hydrocracking are a process step in making Group 3 oils which are considered synthetic, even though mineral oil based, due to the change in structure.
    There could be more of a mixture involved in WS than is shown on the SDS due to trade secret protections. On paper it looks similar to a gas turbine oil (way hotter than a little transmission). These oils have a polyol ester and PAO base. Not sure if WS has this or not.
    Mobil1 synthetic atf has solvent dewaxed oils which is the lowest grade oil out there--yet is marketed as synthetic.
    I have an email into mobil tech support to see if there is any POE or PAO content to the oil. They may not indicate.
  20. Aug 13, 2020 at 2:52 PM
    #290
    :rofl::rofl::rofl:
    And this post is perfect. Thanks, Cthulhu!
  21. Aug 13, 2020 at 2:55 PM
    #291
    Melikeymy beer
    Muscogee Nation
  22. Aug 13, 2020 at 2:56 PM
    #292
    Redcon41318
    Redcon41318 New Member
    Im kinda pissed i didnt buy a 18’ model when i had the chance. Oh well email sent to Toyota Hq
    sgtfluffy16[OP] likes this.
  23. Aug 13, 2020 at 2:58 PM
    #293
    Melikeymy beer
    Muscogee Nation
    Meanwhile at Toyota headquarters...
  24. Aug 13, 2020 at 3:02 PM
    #294
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Well I suppose Toyota "may" have changed something in the Tundra transmission in 19 and 20 to allow for higher than shit temps but somehow I doubt it. How's that for a keyboard engineer.:thumbsup:
  25. Aug 13, 2020 at 3:02 PM
    #295
    glowblue
    VA
    Prices are so high I was going to sell my 2019 and get a 2020, but common sense prevailed - I got my truck right where I want it, it runs great and has zero issues.
    If I ever had a need to tow regularly I’d get a 3/4 or probably a 1 ton. Guy at work has a F-350 Platinum and it’s real nice (the walk home from a breakdown isn’t part of the advertisement though).
  26. Aug 13, 2020 at 3:05 PM
    #296
    sgtfluffy16
    Corey
    Stock
    I was just agreeing with your statement
    odds are they wont answer it. i just got off the phone (about an hour ago) with my exxonmobil rep. legally they can't say anything about Toyota's WS fluid because its "their" proprietary fluid. But what i was told WS is not a "real" synthetic ATF fluid.
  27. Aug 13, 2020 at 3:10 PM
    #297
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I'm gonna get a tandem axle MACK to do all my towing.
  28. Aug 13, 2020 at 3:14 PM
    #298
    My statement had nothing to do with reliability, though. I can't figure out how your comment about reliability related to my statement. :confused:
  29. Aug 13, 2020 at 3:18 PM
    #299
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I'm jealous.
  30. Aug 13, 2020 at 3:28 PM
    #300
    Very convincing.
Thread Status:
