2018 window tint question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Travo60, Jul 17, 2018.
  1. Jul 17, 2018 at 1:52 PM
    Travo60
    Travo60 [OP] New Member
    Travis
    Austin, TX
    2018 Limited CM Cement
    has anyone experienced any issues after window tinting? I had mine done a week ago and now I experiencing my dew sweep on the inside wanting to roll down into my door frame when I roll my window down. Had anyone experienced this?
  2. Jul 17, 2018 at 1:55 PM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    No issues here.
    Travo60[OP] likes this.
  3. Jul 17, 2018 at 1:59 PM
    Boerseun
    Ferdie
    Sarasota Florida
    Was it done by the dealer or aftermarket? I had my truck in for oil change today and the service advisor told me about different types of tint (I had a question about mine); they only install 3M product that has a lifetime warranty. Other products are not the same; I am thinking that different types might not be as slick and cause the sweep to catch and roll down. Otherwise, maybe just give it time, maybe it is just a little sticky from install.
    Totally just guessing here..
    Travo60[QUOTED][OP] likes this.
  4. Jul 17, 2018 at 3:25 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    No issues on my 15. No clue what kind of tint it os
  5. Jul 17, 2018 at 4:57 PM
    Blueknights75
    Ron
    Clayton, NC
    No issues on mine as it was installed by dealer.
  6. Jul 17, 2018 at 6:01 PM
    Travo60
    Travis
    Austin, TX
    It was not installed by the dealer, but a local guy with very good reviews. It’s quality Llumar ceramic tint that was used. I’m dumbfounded myself. All other windows are functioning fine. I’m taking it in to see if I can get a replacement dew sweep. Also while doing trial and error at the tint place it scratched the film up, going to have to get them to replace it again...:annoyed:
  7. Jul 17, 2018 at 6:48 PM
    Masher59
    Masher59 New Member
    Ponchatoula, La
    2018 Platinum Tundra
    Yea my guy has a lifetime warranty. No idea what would be causing that.
    Travo60[OP] and lackeycc like this.
  8. Jul 17, 2018 at 7:49 PM
    OCxCEMENT
    OCxCEMENT HI :)
    Orange County, CA
    2018 Tundra Crew Max Cement TRD-Off-Road 4x4
    I have an 18' CM with lumar ceramic tint all the way around and didn't have issues with it.
    UNTMatt and Travo60[OP] like this.
  9. Jul 18, 2018 at 6:17 AM
    TundraNoCo
    TundraNoCo New Member
    Northern Colorado, FoCo
    2018 Toyota Tundra Platinum
    Bed lined, tinted all 5 windows, hose clamped tailgate, toolbox, steps, ESP rear seat storage bins, dash cam, anytime camera switch, console safe, pop a lock for tailgate and wheels/flares, sway bar. I have Techstream if anyone local needs it.
    The bottom trim on the new Tundra and Sequoia is very tight. The proper way to tint the roll down windows is to either remove the door panel, or even better, pop the top of it out so that the tint does not risk not being perfectly flat and below that trim level. If the installer "tucked" the rubber at the bottom, which is how all roll downs used to be done, that could be the issue. It may have never popped back up all of the way, and you or he may have to help it back up with one of the hard plastic tint squeegees. When I tinted my 2018, I popped the door panels off at the top. I didn't even try tucking the bottom, so I'm not 100% positive it can even be done with the new ones. I used to own a tint shop, and comebacks like yours were not common.
  10. Jul 18, 2018 at 6:33 PM
    Travo60
    Travis
    Austin, TX
    Thank you everyone for the feedback and input. You all have been more than helpful. I’ll post what the outcome is incase anyone else has a scenario like this in the future.
