2018 Tundra front turn signals
Discussion in 'General Tundra Discussion' started by Crewmax18, Jul 7, 2019.
  1. Jul 7, 2019 at 12:34 PM
    Crewmax18
    Crewmax18 [OP] New Member
    Northern Illinois
    2018 White Tundra Limited TRD OFF ROAD
    Does any one is complaining about weak front turn signals in 2018 and up with LED headlights ??? I believe I have simple solution. Just did this to my Tundra yesterday.
  2. Jul 7, 2019 at 12:37 PM
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
  3. Jul 7, 2019 at 12:40 PM
    Crewmax18
    Northern Illinois
    Haha good one. But not liquid
  4. Jul 7, 2019 at 12:43 PM
    Crewmax18
    Northern Illinois
    Wires in turn signals need to be changed. Because one your front signal works as Older model DRL
  5. Jul 7, 2019 at 12:46 PM
    Crewmax18
    Northern Illinois
    You need to remove your harness from turn signal and swap white with black wire from position 2 to position 1 and turn signal will be much stronger. Just did that to mine yesterday. And installed LED bulbs
  6. Jul 7, 2019 at 3:18 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I didn't do what you suggested but I did install resistors and LEDs in all my exterior lights a couple of years ago. They're bright AF!
  7. Jul 7, 2019 at 3:22 PM
    Crewmax18
    Northern Illinois
  8. Jul 7, 2019 at 3:26 PM
    Crewmax18
    Northern Illinois
    I also have LED all around. But without resistors. Even front turn signals have LED without resistors. No hyper flash after I change the wires. Before unfortunately have hyper flash.
  9. Jul 7, 2019 at 4:07 PM
  10. Jul 7, 2019 at 4:18 PM
    Crewmax18
    Northern Illinois
  11. Jul 7, 2019 at 4:29 PM
    FoghornTX
    FoghornTX Proud American and Infidel since 1968
    Ft Worth, Texas
    2022 Camry XSE (Black w/blackout package)
    Crewmax18[OP] likes this.
  12. Jul 7, 2019 at 4:33 PM
    Crewmax18
    Northern Illinois
    That’s awesome. I don’t know why I have this hyper flash. Mine was with canbus and until I change wires I have hyper flash. What is iHacker harness ???
  13. Jul 7, 2019 at 4:34 PM
    Crewmax18
    Northern Illinois
    I just follow directions from headlight revolution website. And it’s works.
  14. Jul 7, 2019 at 4:38 PM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    Wonder if this would hyperflash with traditional 2016 Limited headlights...
  15. Jul 7, 2019 at 4:42 PM
    Crewmax18
    Northern Illinois
    I don’t think so. You just have to order the right one. Blinker with DRL . With canbus installed in led bulb.
    Tierhog[QUOTED] likes this.
  16. Jul 7, 2019 at 5:11 PM
    I just swapped bulbs, no hyper flash. I have a 2018 TRD Sport.
    Crewmax18[QUOTED][OP] likes this.
  17. Jul 7, 2019 at 5:20 PM
    Crewmax18
    Northern Illinois
    It’s look like every Tundra is different . Mine hyper flash until harness wires swap. After that no. The point is it’s working now. And if someone else have this problem its easy fix .
    https://youtu.be/xPZbmI4QMQg
  18. Jul 7, 2019 at 5:21 PM
    That is weird, you would think all 2018's were the same.
  19. Jul 7, 2019 at 5:26 PM
    Crewmax18
    Northern Illinois
    I know it’s freaking crazy .
    My friend have 2016 Tundra. Put OEM led headlights from 2018 . Did everything like he should. But his turn signals work as blinker and DRL. Plus he have led DRL
