2018 Steeing wheel controls are backwards
Discussion in '2.5 Gen Tundras (2014-2021)' started by mrburns05, Sep 20, 2018.
Would this bother you?
  1. Yes
    75.5%
  2. No
    24.5%
  1. Sep 23, 2018 at 2:24 PM
    mrburns05
    mrburns05 [OP] New Member
    Jacob
    Menifee CA.
    2018 4.6L White DC SR5
    Maxtrac 3.5” Spindles Bilstein 6112 Icon AAL Icon 2.5” PB shocks Coachbuilder +1 Shackles AFE dry filter TRD AIA Magnaflow muffler TB Coolant Bypass
    This is interesting because I’ve never had anything but Toyota trucks, and the cruise controls have always been the same - I just considered it standard like column shifters always being on the right side
    realbeefyjay[QUOTED] likes this.
  2. Sep 23, 2018 at 3:22 PM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    I did have to get used to it, but it’s fine now. And there are worse!!
    I am renting a 2017 Ford Explode-Ition currently. Here is the stupid layout they have... everything is backward, complicated, and counter intuitive. And cheep-feeling.
  3. Sep 23, 2018 at 9:39 PM
    Devcom
    Devcom Miles per Gallon? More like Smiles per Gallon!!
    2018 Blazing Blue Tundra Double Cab SR5 5.7L 4x4
    https://www.youtube.com/watch?v=08i9kvCJvJ0
    panicman[QUOTED] likes this.
  4. Sep 24, 2018 at 8:17 AM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    what is so complicated about that? Ford (and Lincoln) have used this same layout for 5+ years across many models. It is less scatterbrained than the toyota one.
  5. Sep 24, 2018 at 12:28 PM
    panicman
    Eric
    Every vehicle I have owned that was equipped with cruise (Honda, Toyota, VW, Dodge, Chev, Volvo) has the cruise located at the right of the wheel. The volume/input/scroll has always been on the left. Most had a control layout that was more intuitive by my reckoning.
    I have never owned a Ford or a Lincoln because of preference, and I will stop there to avoid providing any unsolicited and potentially offensive opinions on Fords and Lincolns.
  6. Sep 24, 2018 at 12:39 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    It's that way because you are scrolling the screen on the dash display up or down for channel selection or search.
  7. May 12, 2020 at 8:16 AM
    skeeter281
    skeeter281 New Member
    This drives me so crazy I’m tempted to get another steering wheel and try to fix it. Anyone do anything to modify it so that volume is up/down and and tracks are left/right?
  8. Dec 22, 2020 at 7:33 AM
    MogwaiBoogie
    MogwaiBoogie New Member
    Justin
    TEXAS
    2020 Tundra Platinum
    Did anyone ever succeed with turning the buttons 1/4 turn? Been in my 2020 since August and cant get used to it. So illogical
  9. Dec 22, 2020 at 8:04 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    I am sure you could just swap around the wires in the plug that are associated with each command and then paint the entire button to remove the icons. Problem solved.
    Hard part is just tracing the wires in the button to the plug.
    Personally, I never use the buttons on the steering wheel. I'd love to remove all of them..
