2018 SR-5 Adding Fog Lights with Push Button Switch
Discussion in 'Lighting' started by El Jefe', Sep 22, 2022.
  1. Sep 22, 2022 at 7:16 PM
    El Jefe'
    El Jefe' [OP] New Member
    Jeff
    Hey everyone,
    This is my first post. I'm using the OEM wiring for the lights themselves but want to use a push button switch installed in one of the existing OEM switch openings on the dash.
    I don't want to replace the combo switch/stalk but prefer to use a push button.
    I want the fog lights to turn off when I turn off the key and maybe even to only work if the headlights are on (unsure how I feel about that - open to input and ideas).
    What advice does anyone have?
  2. Sep 22, 2022 at 7:18 PM
    Welcome from NY.
  3. Sep 22, 2022 at 7:26 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I have a second set of amber fogs that's wired to my switch pro, made it easy. For you, you would have to find where the factory wiring goes to and probably either tap into it or reroute it all together.
  4. Sep 22, 2022 at 7:26 PM
    RobertD
    Robert
    DFW, Texas
  5. Sep 22, 2022 at 11:03 PM
    AZ Red Nek
    AZ Red Nek Native of the Valley, Bowl, Basin, ETC...
    Chuck
    2016 White SR5 Crew 4x4
    Hidden 1200# Waren winch, Baja Desgins lights, Switch Pro switch and controller, S&B air box and in bed tool box.
    Welcome from Phoenix
