2018 Safety Sense Lift Issues
Discussion in '2.5 Gen Tundras (2014-2021)' started by HERMTOGO, Dec 2, 2017.
  1. Jan 24, 2018 at 7:55 AM
    ssrgeoff
    ssrgeoff New Member
    18' Tundra
    King, Method, Toyo, CB & TRD
    For what its worth... I picked up my brand new truck with the Pre Collision Sensor on, showing trailer brake error, traction control etc. The dealer had to order a part which came in the next day and on the service order it just says Air Bag ECU Failure. The truck was fixed no alerts for 4 days... then, I installed a TRDPRO grill making my own mounts for the sensor but like above the light comes on with no beeps this time saying that my PCS is turned off and to clean the sensor. I just turn it off for now just in case but have a TRD Sport grill now on order that I will install and hope that the sensor goes back to working as it should... also worth mentioning after installing the PRO grill, I just had coilovers/wheels and 35" tires installed but since I am only at 2.5" I don't expect that to cause an issue. Dealer may think otherwise...
  2. Jan 24, 2018 at 4:21 PM
    ssrgeoff
    ssrgeoff New Member
    18' Tundra
    Just thought I would quickly follow up since my grill arrived today... out with the old TRDPRO and in with the new TRDSport. So far truck is back to normal with no code.
    8MINT8, T-Rex266 and Larmand like this.
  3. Jan 24, 2018 at 8:26 PM
    SocaliTundra958
    SocaliTundra958 New Member
    Temecula
    2018 SR5 CREWMAX TUNDRA
    stock
    So I just want to clarify, is it ok to level the truck, considering of purchasing the 5100s for my 2018 cm to add some better shoes? I love the PCS since it has saved my butt twice now and I did have a random incident during heavy rain telling me to break when their was clearly nothing in front of me, but so far it’s been useful that I Love this truck for it. I just don’t want the wife thinking the tundra was a bad choice after installing mods and I start to vist the service dept more often when I should of just kept it stock to not even deal with problems. So what are the advice from my 2018 tundra owners, worth the gamble or just keep it the way it is?
  4. Jan 25, 2018 at 2:17 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    You are running a risk of losing the TSS if you do. My PCS has only worked once since ive gotten the truck. Just be aware of that. More people have been ok, rather than not. My dealership said that they had levelled about 8 trucks and mine was the only one with the issue. He also had a couple of trucks that were not levelled and also had issues with previous fixes. My dealer refuses to swap the SRS ECU until Toyota technical tells them to. That's what really pisses me off because others here were able to have it done. Best of luck to you, that you don't have any issues if you do proceed.
  5. Jan 25, 2018 at 7:22 AM
    Steve6
    Steve6 New Member
    Tucson
    So based on what the dealer said, some trucks have the issue and some don't, regardless of whether or not the truck has been lifted / leveled.
    I've also read several posts from Toytec in other threads indicating Toyota has advised them that lifts are OK but that there needs to be a little rake (.75 - 1 inch) so that the TSS systems will work properly. I wonder if there is a difference between "working properly" and throwing codes. A level truck will have the sensor pointed up at a higher angle than stock so the system may not function exactly as designed but that may not necessarily mean that the truck will display error codes.
    I'm still planning on doing a lift but now I'm considering leaving about 3/4" of rake rather than level even though I don't care whether or not the PCS works. I'd rather level the truck but I don't want to create a problem for myself and it's starting to sound like the PCS error codes may not be related to leveling the truck.
  6. Jan 25, 2018 at 9:02 AM
    ssrgeoff
    ssrgeoff New Member
    18' Tundra
    Not sure how high mine was lifted since I didn't do the install myself, plus I had rims and tires done the same day. I have Kings and asked them not to crank down on any preload so its set exactly as you would receive out of the box. I have heard anywhere from 2-2.5" of lift. Since putting the stock style grill back on I drove 100 miles yesterday and no code. The rear is stock, so it seems each truck has its own idea of what is okay but I would imagine its the dealer who would want to take the extra step and try to recalibrate the sensor as I find it hard to believe its a set it and forget it type system.
    Like I mentioned in an earlier post... my truck bought stock was throwing a code, ECU swap = Fixed! Not sure why they are not more accommodating to you Larmand. Maybe try a new dealer.
    Larmand likes this.
  7. Jan 25, 2018 at 1:41 PM
    c0astie31
    c0astie31 New Member
    Dennis
    2018 TUNDRA OFF-ROAD CEMENT
    I have a level kit coming in tomorrow for the front. Now I am thinking of leaving it alone.
  8. Jan 25, 2018 at 1:44 PM
    SocaliTundra958
    Temecula
    stock
    My dealer actually said I was the first one with that airbag software update they had to do, I’m not sure if that’s a good thing or a bad thing? Lol
  9. Jan 25, 2018 at 2:01 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    I measured mine and as it sits with a 3/2 "level", I'm at 1.25" rake. With 275/70 18 tires.... Ground to top of fender wells is 42" in rear and 40.75" in front.
  10. Feb 4, 2018 at 7:43 AM
    [DELETED]
    [DELETED] New Member
    Jeff
    Does anyone know, is Toyota working on a fix for this!? Or, will it be up to us to mod the sensors?
    Who is working on this!? If Toyota plans to launch the TRDPro in '19, they'll have to get this squared away! They say, that's why it's not available this year...
    Dealership won't lift the truck I just bought that's sitting at the dealer. :/
  11. Feb 4, 2018 at 5:26 PM
    Wartouched
    Wartouched New Member
    I also have a bone stock SR5 TRD Crew Cab. I had the same issue with the PCS light coming on. I never got the error message just the light. Dealership had my truck for a whole week. Fixed it once and i made it 1/2 mile from the dealership and the light came back on. Took it right back and then two days later they called to tell me that they were taking a new truck apart and putting the parts in my truck. Turned out to be a bad radar sensor in the grill. They confirmed ib by placing my sensor in the new truck and withing 2 mile the light came on. So far i have over 100 miles on the truck and have not had the light come back on. I only have 450 miles on the truck as of now so i hope this solves the problem. While talking with my salesman, he also told me that the dealership can no longer install any lift in any new Tundra or Tacoma because of the safety sense issues.
  12. Feb 4, 2018 at 8:09 PM
    epa4wd
    epa4wd New Member
    Ed
    Curious about this, what happens then if you have a heavy load on the bed therefore, leveling the truck? Would TSS throw an error?
    Laz1388 likes this.
  13. Feb 5, 2018 at 8:18 AM
    Laz1388
    Laz1388 New Member
    Laz
    South Florida
    2019 1794 MGM
    Windows tinted, Spray-on bed liner, Chrome Delete, Roll-N-Lock retractable cover, Painted fender flares, TRD PRO Suspension, Front and Rear TRD Sway bar, Magnaflow Exhaust, ReadyLift 6" lift, Bronze KMC XD Grenade wheels 20X9-18, Toyo Open Country R/T 37X12.5-20
    I've wondered about that myself
    epa4wd[QUOTED] likes this.
  14. Feb 5, 2018 at 11:06 AM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    Just getting ready to ask this question.
  15. Feb 5, 2018 at 12:41 PM
    c0astie31
    Dennis
    So I installed a 2.5 spacer in the front last week. I know it’s a spacer and for now it will be fine until I put 5100’s on
    I have about 1” rake in it and no issues at all. Everything works as it should
  16. Feb 6, 2018 at 5:26 AM
    design311
    design311 Smoke Eater
    Brad
    Bentonville, AR
    2018 Tundra Inferno TSS
    I just put on a 3" front spacer and the ToyTec 1.5" shackles on my truck. I've had no issues with my 2018.
    Thesquatchy1 likes this.
  17. Feb 6, 2018 at 9:13 PM
    Drewski83
    Drewski83 New Member
    2018 sr5 Tundra
    2.5 king suspension front/rear, Icon uca billet, 18" fuel trophy on 35" toyo open country rt
    I just received this notice in the mail from Toyota. I also have a 2018 sr5 4x4 TRD and had the PCS warning come on once. I am taking to the dealer soon to have this address and my 5k service.
    Laz1388 likes this.
  18. Feb 7, 2018 at 5:20 AM
    Laz1388
    Laz1388 New Member
    Laz
    South Florida
    2019 1794 MGM
    I got the same letter earlier this week
  19. Feb 7, 2018 at 7:14 AM
    #49
    Steve6
    Steve6 New Member
    Tucson
    Having an '18 and waiting to level / lift my truck I have been following the TSS / PCS error threads for a couple of months. It sounds like some trucks have the PCS issue and some don't, regardless of whether or not they are lifted. Some dealers are selling new '18s with a lift installed - see the new member from Las Vegas thread as just one example - https://www.tundras.com/threads/new-owner-in-vegas.21308/ - and some dealers are saying no lift.
    As one of the posters above pointed out, a load in the rear of the truck will change the rake / level on the truck. Does this mean that PCS errors should be expected whenever the truck is used to haul or tow? No, it means that some dealers are full of crap. Who knew?
    Laz1388 and 757TUNDRA like this.
  20. Feb 7, 2018 at 7:43 AM
    #50
    Nike21
    Nike21 New Member
    2018 SR5 CrewMax TSS 4X4 Black Beast
    I just want to make sure when I lift mine, that the TSS works like it's supposed too, and the warranty doesn't get voided. :bananadance::bananadance:
  21. Feb 8, 2018 at 3:14 PM
    #51
    SocaliTundra958
    Temecula
    stock
    So since the 2019 trd pro is lifted, will Toyota service dept still make excuses that the upgraded lift/level is causing the TSS to act up and void warranty?
    netranger6 likes this.
  22. Feb 8, 2018 at 3:19 PM
    #52
    [DELETED]
    Jeff
    RIGHT! This is starting to sound like a CYA move from Toyota...
  23. Apr 8, 2018 at 4:44 PM
    #53
    Thesquatchy1
    Thesquatchy1 New Member
    Georgetown, KY
    2018 cement SR5 4x4 5.7
    Another member on here installed a TRD pro grill, but then swapped to the original grill insert so TSS still works. I bought a pro grill and plan on trying that myself.
  24. Apr 8, 2018 at 4:47 PM
    #54
    Thesquatchy1
    Georgetown, KY
    And I'm sure they'll make it work on a Pro under max tow for the 2019, we'll probably just ending up needing THAT sensor.
  25. Apr 9, 2018 at 5:37 AM
    #55
    smooosh
    smooosh This place costs me too much $
    2018 TRD Offroad Limited Crewmax.
    Ongoing project
    I'm just going to wait on the new pro grill. That way toyota can not blame a hack job on warranty work.
    The problem with a lift is not the sensor its the camera from what i have read. That being said mine works fine. I have the pro suspension so its leveled.
  26. Apr 9, 2018 at 7:20 AM
    #56
    Al92toyo
    Al92toyo New Member
    Alex
    2018 White Tundra Crew Max Platinum 4x4
    I've been toying (no pun intended) with lifting the truck but the TSS issue has me pretty concerned. I reached out to several companies like BDS about their lifts for a 2018 and they all tell me that it is still in development due to the TSS issue. I did however speak to someone at ProComp and they said their 2017 kit works fine on a 2018 with TSS and also emailed me a letter from their Director of Engineering who, according to the person I was speaking with, was the Head of Engineering at TRD. The letter is attached.
  27. Apr 9, 2018 at 8:04 AM
    #57
    Thesquatchy1
    Georgetown, KY
    The guys at my dealership were fine with it, said it was a good idea and they were going to pass it on, so I'm not really worried about problems with warranty work.
  28. Sep 25, 2019 at 7:11 AM
    #58
    Keithbickford
    Keithbickford New Member
    Keith
    Seattle
    2020 Cavalry Blue Tundra
    King 2.5” suspension, Method Race 313 wheels, Nitto Ridge Grapplers 35x12.5x17, TRD exhaust, RCI Skid Plates, Alpine ILX-F309 stereo, Alu-Cab roof top tent on Yakima Overhaul HD, Line-X spray in bed liner, VLED LED reverse light bulbs and VLED LED license plate reverse light. VLED brake/tail light bulbs. VLED third brake light and cargo lights.
    I think you may be on to something with the clues you’ve provided. It sounds like it is occurring only in the afternoon when you’ve had the sunshade in. This needs to be known by Toyota. Are you starting the car with the sunshade in? Or are you removing it first? Is the shade cut wide open around the area of the sensors under mirror, or is it possibly closed trapping heat? If you touch the plastic shroud under mirror, is it hot with sunshade in?
