2018 Platinum Struts
Discussion in 'Sequoia Builds' started by MHappy4, Mar 22, 2022.
  1. Mar 22, 2022 at 10:57 AM
    MHappy4
    MHappy4 [OP] New Member
    Ty
    22 Blueprint Tundra Platinum
    Does anyone know if the sequoia throws CEL or other lights if you replace OEM(AVS) struts with aftermarket? Thanks
  2. Mar 23, 2022 at 7:39 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Changing the coilovers, they are not struts, will not cause a CEL. If the vehicle has TSS, it could cause an alert with that if the front is higher than the rear. But no, coilovers are not monitored and have no sensors, not connected to the truck/computer.
