2018 Platinum Battery?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Timmy V, Jun 16, 2023.
  1. Jun 16, 2023 at 1:21 PM
    Timmy V
    Timmy V [OP] New Member
    2018 Tundra Platinum
    Road Queen
    Just bought a 2018 with 68k on it. Figure the battery will be the first thing to go. Anyone know what brand the stock battery is? I haven't had any issues yet but I like to be proactive and don't feel like breaking down for $200
  2. Jun 16, 2023 at 1:24 PM
    AZBoatHauler
    So.Arizona
    Toyota brand - the factory batteries are notoriously shitty but the Toyota branded replacements are supposed to be better.
    I opted for a X2 from Batteries Plus which is a rebranded Northstar.
    Taco-Spike likes this.
  3. Jun 16, 2023 at 1:26 PM
    Timmy V
    Road Queen
    10-4, it has a Dura-Last Gold...
  4. Jun 16, 2023 at 1:30 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Exide make Toyota batteries
  5. Jun 16, 2023 at 1:39 PM
    AZBoatHauler
    So.Arizona
    So the OEM one gave out on the orig owner most likely. Your Duralast one should have a month and year of manufacture on it.
  6. Jun 16, 2023 at 3:08 PM
    pursuit2550
    pursuit2550 New Member
    My 2020 battery crapped out at around 2 years(20k miles), I did a post about it. Anyways it was under warranty so they replaced it with a Toyota battery, which the guys here say it's better than OEM. Looks like yours crapped out also. Look for a year on your battery and see how old is it. Could be fairly new and might not have to change it.
  7. Jun 16, 2023 at 9:04 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    If you guys want to make your batteries last, pick up an Optimate charger, I plug my truck in maybe once a month and it still tests out perfect on my 2019, also dont forget to check the water levels and top off with distilled water. Obviously some batteries are better than others but many fail because of no maintenance done to them. I once had a battery last over 10 years on a motorcycle because I plugged it in when ever not in use. Obviously not something practical to do with a truck. I also carry a JNC660 just incase, rather do that than replace a good battery, plus it makes it super easy to help someone who needs a jump.
