2018 Limited - remote start any good?
Discussion in '2.5 Gen Tundras (2014-2021)' started by XV1100SE, Aug 20, 2018.
  1. Aug 20, 2018 at 3:00 AM
    XV1100SE
    XV1100SE [OP] 2018 Tundra 4x4 Crewmax LTD
    Don
    Kitchener, Ontario
    2018 Tundra LTD
    Toyota running boards and tonneau cover
    Just ordered my 2018 Tundra 4x4 Crewmax Limited. Asked the salesperson about the Toyota remote starter (supposed to have something like 800 yard range) and he said it didn't work very well with the Tundra. He said you had be be close to the truck (within about the same range as the key fob).
    True?
  2. Aug 20, 2018 at 4:29 AM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    junk. just get an aftermarket one from directed with smart start or something.
  3. Aug 20, 2018 at 4:31 AM
    Cfincke
    San Antonio
    the factory remote start turns off the engine once you open the door. Aftermarket ones will keep the engine running when you open the door and insert the key.
  4. Aug 20, 2018 at 4:55 AM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    I would go aftermarket for the above stated reasons. I have an aftermarket and love it.
  5. Aug 20, 2018 at 6:57 AM
    XV1100SE
    Don
    Kitchener, Ontario
    2018 Tundra LTD
    Thanks !
  6. Aug 20, 2018 at 7:03 AM
    sprtbkr
    sprtbkr Average Member
    Scott
    Denver, CO
    2018 Tundra SR5 4x4 Double Cab - Inferno
    TRD Wheels & Tires, Double Cab Fold-down Back Seat mod, LED Interior Lighting, Turned Off Seat Belt Chime, Franken-key (Flip Key), Duraliner Bed Liner, Bed Rails, Hood Wind Deflector, Console Gun Safe, iBoard 5" Running Boards, TRD Sport Bed Vinyl, Fortin Evo One Remote Start with Mycar Cellular Module, Plasti-dipped Badges and Bumper End Caps, Tinted front windows, Extang Solid Fold 2.0, Pop-N-Lock, TUNDRA tailgate inserts, RCI Powder Coated Skid Plate - coming soon - 12” android radio, oemaudio+ Reference 500Q, under dash/seat lighting.
    tech12volts.com has a kit. I installed it on mine with the mycar cellular option for $330 total.
    MotoTundra, B737 and RoscoePico like this.
  7. Aug 20, 2018 at 12:44 PM
    TacoWuzzaTurd
    TacoWuzzaTurd Loving my Tundra
    Scottsdale AZ
    2018 SR5 4x4 Crewmax, TRD Offroad
    6112s @1.9", TRD Dual Exhaust, rims, tires, jl audio system
    Interested in doing this myself. How difficult was the install? How long did it take you? I start sweating a bit with I think of pulling electrical wires out on a brand new truck and tapping into them. Was there a video you watched to install or just paper instructions?
    plumber802 and MotoTundra like this.
  8. Aug 20, 2018 at 1:01 PM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    Viper two way. 1000 yard range. Bluetooth smartphone enabled with cellular option and two remotes plus shock sensor. $600
    Oh.. They have a T harness too.
  9. Aug 20, 2018 at 1:36 PM
    sprtbkr
    Scott
    Denver, CO
    It's essentially a programmed Fortin Evo-One. There is one harness, and about 6 wires to tap into. Took me less than 2 hours. All the connections are under the driver's side dash.
    http://cdn02.fortin.ca/download/69711/evo-one_ig_thr_bi_toy2-tundra_2018_hkey_a_69711.pdf
  10. Aug 20, 2018 at 2:23 PM
    TacoWuzzaTurd
    Scottsdale AZ
    I purchased an Evo Fortin system for the Tacoma I had. It took 20 minutes to install because the kit was prepped with unnecessary wires taped up and essentially removed from the equation. There were two or three plugs that integrated directly with factory connectors so it was super quick and easy. This sounds like a different type of install from what you describe though. I think the longest part of the install for the Tacoma was unscrewing the dash and pulling it down out of the way just enough to make room for unplugging and plugging in connectors. However the factory key fob remote sucked. Range was poor (limited to factory fob range) and the motor died when opening the door. The 2016 tacoma was a push button start.
  11. Aug 20, 2018 at 2:28 PM
    sprtbkr
    Scott
    Denver, CO
    Yeah, he has it all prepped with only the wires you need out, the rest tied back, and the unit programmed. On the 2014-2017 there was an second harness that made it all but plug and play with the exception of like 1 wire. For the H key in the 2018 model, the configuration is different and can't use that harness.
  12. Oct 20, 2018 at 7:52 AM
    18TundraPlat
    18TundraPlat New Member
    Charlie
    2018 Tundra Platinum
    Do any of the aftermarket remote start systems void the Toyota warranty?
  13. Oct 20, 2018 at 8:46 AM
    timsp8
    NY
    I went to ziebart for the rust protection and had them install one. Theirs works with key fob and they also gave me another remote that works up to 1/4 mile. It stays running when you open the door. The unlock on the fob also still works with it started, so I dont have to try to manually unlock with key if there’s ice.
  14. Oct 20, 2018 at 12:45 PM
    TacoWuzzaTurd
    Scottsdale AZ
    Nothing will void the entire vehicle warranty as a whole. The way a warranty works is say you install the remote start incorrectly and fry your truck electrical system...that would not be covered under warranty. But if your exhaust falls off they cant possibly say that was caused by your remote start. If you install aftermarket shocks and your lower control arm fails or some other suspension component fails, they wont cover it because theyll say the shocks you installed contributed to the failure. However if you install shocks and your engine craps out, theres no way they can say the shocks had something to do with it. Get it?
    18TundraPlat[QUOTED] likes this.
  15. Oct 20, 2018 at 1:07 PM
    TNtundra18
    TNtundra18 New Member
    Charlotte, NC
    2018 Tundra Limited
    Which one did you go with?
  16. Oct 20, 2018 at 11:04 PM
    Vendeta2k
    Jay
    Bozeman, Montana
    I went with compustar. Works like a champ! 3x lock activates the remote start. Factory fob is still fully functional allowing for unlocking of the doors without use of the key.
  17. Oct 21, 2018 at 7:33 AM
    18TundraPlat
    Charlie
    Does the factory remote work for remote starting, or do you have to use the Compustar remote exclusively?
  18. Oct 21, 2018 at 7:55 AM
    Vendeta2k
    Jay
    Bozeman, Montana
    Factory fob....push lock 3 times it starts...
    18TundraPlat likes this.
  19. Oct 21, 2018 at 8:42 AM
    TNtundra18
    Charlotte, NC
    2018 Tundra Limited
    Straight plug and play or is there wire splicing?
  20. Oct 21, 2018 at 4:20 PM
    Vendeta2k
    Jay
    Bozeman, Montana
    Splicing..I had a friend who’s an installer at a local stereo shop do mine.
  21. Oct 22, 2018 at 6:58 AM
    sbbrown333
    sbbrown333 MGM Wrecking Crew
    Blake
    2018 MGM Limited CM 4x4
    I think remote start will be my next modification.
