2018 license plate LED light bulb replacement?
Discussion in 'Lighting' started by Angelslure, Aug 21, 2018.
  1. Aug 21, 2018 at 12:29 PM
    Angelslure
    Angelslure [OP] @BIGSEXY_TUNDRA
    Stephanie
    Virginia Beach
    Super White 2018 Tundra CrewMax 4WD 5.7L
    Leveling 3”/1”, Tint, Tires 285/75/18, LED strip in hood bulge, changed all interior and exterior lighting to LED, Remote Start, Interior foot well LED lighting, Linex spray bed liner, Chrome and Black step bars
    I was wanting to change my rear license plate lights with LED super white to match the front. Maybe even the white back-up lights...Does anyone know if the 2017 bulbs would fit the 2018's? Most places i call say that the truck is too new to have a part number for it yet
  2. Aug 21, 2018 at 1:31 PM
    Have you looked into VLEDs.com Superbrightleds.com , headlightrevolution.com ,
    Angelslure[OP] likes this.
  3. Aug 21, 2018 at 3:35 PM
    GreatAvalon
    GreatAvalon New Member
    2016 Tundra Limited DC
    It’s the same bulb numbers (194/168 for the license plates and 7440 for reverse). I thought I remember reading a person had issues putting LED bulbs in the reverse/brake but they may have been cheap, crappy bulbs or something. Others with the 2018 “upgraded” electrical system and who replaced reverse bulbs will have to chime in to make sure it’s all good. I don’t see why it wouldn’t be, but...
  4. Aug 21, 2018 at 3:58 PM
    TheBeast The Beach
    vleds.com has them
  5. Aug 21, 2018 at 4:04 PM
    kcaustin66
    kcaustin66 New Member
    kevin
    Palestine Texas (East Texas)
    2015 Toyota Tundra CM 1794 4wd
    3” lift, black step bars, aftermarket wheels, LT305/55R20 was this way when I brought it.
    I bought my at Walmart they fit ok, but the backup bulbs didn’t work. Also if you change out the map light bulbs above the dash (remove the entire console) much easier, I bent the reflector and then damaged the socket had to remove the entire unit to fix. Very easy to remove, replace bulb and reinstall.
  6. Aug 23, 2018 at 7:48 AM
    Angelslure
    Stephanie
    Virginia Beach
    okay I will definitely look into that pulling the console deal...Thank you so much.
  7. Aug 23, 2018 at 7:48 AM
    Angelslure
    Stephanie
    Virginia Beach
    I will check that out Beast thank you...
  8. Aug 23, 2018 at 7:49 AM
    Angelslure
    Stephanie
    Virginia Beach
    great I appreciate the info. Thank you
  9. Aug 23, 2018 at 7:49 AM
    Angelslure
    Stephanie
    Virginia Beach
    I haven't but am planning on it today...Thanks for all of the info....
  10. Aug 23, 2018 at 7:53 AM
    :thumbsup:
  11. Aug 23, 2018 at 7:55 PM
    GreatAvalon
    VLEDS FTW
  12. Aug 23, 2018 at 9:13 PM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    I have the Vleds. There worth it. Great customer service and great quality bulbs
  13. Aug 23, 2018 at 9:17 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    VLEDs.com !!! They won’t disappoint. They only carry quality leds.
    Just enter a 2017 tundra. All the rear lights are the same still.
