2018+ LED HEADLIGHTS PLUG N PLAY HARNESS FOR 2014-2021 MODELS [V 2.0]
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by iHacker, Apr 21, 2018.
  1. Jul 27, 2018 at 7:04 PM
    #181
    Pudge
    CT
    2015 Blue Ribbon Platinum
    That's a shame. Those poor farmers work so hard and get screwed by mother nature. It Sucks
  2. Jul 27, 2018 at 7:24 PM
    #182
    iHacker
    iHacker [OP] SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Totally agree, that’s why I support local farmer markets instead of buying from big box retailers
    Pudge[QUOTED] likes this.
  3. Jul 27, 2018 at 7:31 PM
    #183
    Pudge
    CT
    Me too buddy. I grew up working on and buying from small farms, I wouldn't have it any other way.
    iHacker[QUOTED][OP] likes this.
  4. Aug 1, 2018 at 8:33 AM
    #184
    Canary2323
    Canary2323 New Member
    G
    08 Toyota tundra
    Can you make me a plug and play harness for a 08 ?
  5. Aug 1, 2018 at 10:49 AM
    #185
    Pudge
    CT
    You need a harness for a 2md gen tundra, also you need 2018 sequoia headlights for 2nd gens. Unless you do a full 3rd gen front end conversion, if you do that the wiring harness is the least of your worries lol
    Canary2323[QUOTED] likes this.
  6. Aug 1, 2018 at 10:52 AM
    #186
    Canary2323
    G
    08 Toyota tundra
    Did the conversion already ,wasn't as bad as I expected. Now just need a harness
    matrdguy likes this.
  7. Aug 1, 2018 at 5:32 PM
    #187
    Pudge
    CT
    I think you may need to make your harness. Or get together with @iHacker and @xrunnerdude67 to see both wiring diagrams, 2nd and 3rd gen diagrams I'd what I'm referring to.
  8. Aug 2, 2018 at 9:02 AM
    #188
    xrunnerdude67
    xrunnerdude67 New Member
    Those aren’t the ‘18 LED headlights on that black truck. Look like regular halogens?
    iHacker[OP] likes this.
  9. Aug 2, 2018 at 9:13 AM
    #189
    iHacker
    Mario
    Yes in the picture those are the old halogen headlights and now he’s trying to install the new 2018 LEDs, harness is really simple to make but not sure what changes they made to the stock harness to convert from H11 (lows) and 9006 (highs) to H4 single bulb, if they kept the wiring untouched that’s a piece of cake basically the same harness but with the respective H11 and 9006 male connectors,
    The rest is the same, turn signals, side corner markers, LED DRL and probably leveling system but I think second gens don’t have that option
    Pudge likes this.
  10. Aug 2, 2018 at 6:03 PM
    #190
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    For anyone who has used his harness, can y’all explain why I have tapped into the gray wire (I’m keeping Amber & Headlight DRLs), tapped into black wire, connected the wire running thru the firewall, and still not getting Ambers?
  11. Aug 5, 2018 at 5:14 PM
    #191
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Hi,
    Im new here, looking to make a purchase of your harness. My truck is a 2017 SR5, im doing the 2018 bi-leds headlights conversion for my truck.
    Can you recommend the correct, proper, p'n'p harness for me please?
    I am paypal confirmed and verified.
    Regards,
    Brandon
    chuck416 likes this.
  12. Aug 7, 2018 at 2:59 PM
    #192
    SloppyJ
    SloppyJ New Member
    NW Arkansas
    2023 Black SR5 Crewmax Long Bed
    Luckily for me, iHacker and I live close to one another. I met him today to pickup my harness to swap out my lights for the full 2018 LED version and the quality is top notch. I would highly recommend his harness. I'll post pictures when i make the swap.
    Side note: if anyone wants a pair of 2018 halogen lights with the 1 LED bottom running strip, shoot me a PM.
  13. Aug 7, 2018 at 4:11 PM
    #193
    iHacker
    Mario
    Thanks,
    Thanks, and I’m glad to meet with someone local, this is my second time doing this. If you need help just send me a message.
  14. Aug 7, 2018 at 11:33 PM
    #194
    Bluetundra18
    Bluetundra18 New Member
    2016 blue tundra 4x4
    7" Pro Comp lift 22x14 american forces Platinum headlights Morimoto XB fog lights Super 40 Series flowmaster
    I have a 2016 tundra limited.
    Doing the headlight swap. I dont want amber on. What harness do I purchase. I am PayPal ready. Thanks.
  15. Aug 10, 2018 at 12:55 PM
    #195
    PotentPotables
    Washington
    @iHacker, I have a lame question. When converting from an amber DRL (2015 SR5) why is a relay needed to power the LED DRL? Would it be possible to simply use the turn signal 3 to 2 wire adapter but utilize the third wire (amber DRL/Parking lights) and run it to the main headlight plug to power the halo LED's? I did this mod a month ago (used another adapter, sadly) and the DRL are on 100% full time and I had to do all of the repinning/ depinning. I like your version and iteration better. Would you consider making a custom harness? Let me know. Either way, I'll be PM'ing you in the near future! Strong work!
  16. Aug 10, 2018 at 1:28 PM
    #196
    MikeyMTBs
    MikeyMTBs New Member
    Nice touch from @iHacker to include a posi-tap on the SR5 harness. Those aren’t cheap but they’re way better than scotch clips! Thanks!
    Now to get this headlight install rolling!
    iHacker[OP] and Pudge like this.
  17. Aug 10, 2018 at 6:53 PM
    #197
    iHacker
    Mario
    Ohh yeah posi-taps aren’t cheap but definitely worth every penny spent on, this make everything easy and no tools required to use it.
    SikYota and Pudge like this.
  18. Aug 10, 2018 at 7:04 PM
    #198
    iHacker
    Mario
    A relay is required to convert the Factory DRL signal, the factory DRL signal is ground activated from main body ECU this close the relay to supply switched power to the bright DRL, when low beam is activated this open the relay so the DRL bright is turned off and then parking light (violet 3rd wire in turn signals) is used to power the dimmed part of the DRL.
    Doing a T-harness like the one you mentioned in your post will keep the DRL at 100% all the time and the LED will blink when using turn signals.
  19. Aug 11, 2018 at 4:50 PM
    #199
    BrandonL812
    Brandon
    Got mine harness also. Great quality. Ship fast. Awesome communication. Top notch service.
    Will get everything install tomorrow. Can not wait.
    Thanks again for the harness.
    SR5SE, Pudge and iHacker[OP] like this.
  20. Aug 12, 2018 at 9:50 AM
    #200
    BrandonL812
    Brandon
    All buttoned up. Look gorgeously Aggressive.
    Love it.
    Led fog to match.. all oem parts.
  21. Aug 12, 2018 at 10:00 AM
    #201
    Pudge
    CT
    Looks great Brandon you're gonna love them. There is an easy mod you can do to keep fog lights on with high beamd if you wanna do that too. Would love to see output pics when it gets dark if you get a chance
    BrandonL812[QUOTED] likes this.
  22. Aug 12, 2018 at 10:02 AM
    #202
    BrandonL812
    Brandon
    I'll look into the fog stay on with high beam mod. I like that idea. Will get some pictures tonight.
    Pudge likes this.
  23. Aug 12, 2018 at 10:03 AM
    #203
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    On point! This is why you the man!
  24. Aug 12, 2018 at 10:06 AM
    #204
    Pudge
    CT
    I've gotten several PMs from members and new members asking about how to get a harness for their lights and who to go with. I also may have steered a few guys this direction when they were looking for answers on other threads.
    @iHacker is the man!!
    iHacker[OP] and BrandonL812 like this.
  25. Aug 12, 2018 at 12:38 PM
    #205
    Elie812
    Elie812 New Member
    2016 Silver Tundra CM, TRD
    Tint, stealth steps, front step, rear step, others to come.
    I have a 2016 SR5 and want a 2018 SR5 lights. What harness I need and how much is it including shipping?
  26. Aug 12, 2018 at 1:37 PM
    #206
    BrandonL812
    Brandon
    If you want it to operate and function like factory, then get the $140 harness. That's including the shipping cost. That is the harness i purchased and work flawlessly.
    Pudge likes this.
  27. Aug 12, 2018 at 6:58 PM
    #207
    BrandonL812
    Brandon
    Some from phone. Not best quality but, still look amazing. Light output is awesome. Best first mod ever.
  28. Aug 13, 2018 at 7:54 AM
    #208
    SloppyJ
    SloppyJ New Member
    NW Arkansas
    If you still need the lights, I have some from my brand new truck that I would sell. PM me if you're interested.
  29. Aug 13, 2018 at 8:14 PM
    #209
    PotentPotables
    Washington
    This is a quality harness with wicked fast shipping. Thanks @iHacker!
    matrdguy, Sas, BrandonL812 and 2 others like this.
  30. Aug 14, 2018 at 10:34 AM
    #210
    Rockbox
    Rockbox Tundra NOOB!
    Rich
    St George, Utah
    2016 MGM TUNDRA LIMITED
    Hello I Hacker. I'm upgrading to the 18' led headlights. I'd like to buy a harness for my 16' limited tundra. I need the harness with the factory drl dimming option. I'm working atm but I'll get back with you asap
