2018+ LED HEADLIGHTS PLUG N PLAY HARNESS FOR 2014-2021 MODELS [V 2.0]
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by iHacker, Apr 21, 2018.
  1. Jul 13, 2023 at 3:48 AM
    #1501
    Tundra_1307
    Tundra_1307 New Member
    @iHacker PM sent on purchase, thank you
  2. Aug 11, 2023 at 1:49 PM
    #1502
    ATXHusker
    ATXHusker New Member
    Chad
    Austin TX
    2016 TRD Pro CM Quicksand
    Ranch Hand brush guard, TRD rear sway bar, TRD air filter, Husky front mats, Weathertech rear mat, LED interior lights, tow mirrors, Salex console organizer, key ring light mod, AJT key fob, Gator bed cover
    I have a 2016 TRD Pro w/ stock halogen headlights that have completely fogged over and look like complete garbage. I in no way have any wiring / electrical experience / training so I'm feeling a little intimidated to try this out. I'd like to ultimately get the 2019 LEDs w/ harness. I'd like to get some feedback from others who did this with my experience level pls thx
    Black@Blue19 likes this.
  3. Aug 11, 2023 at 3:14 PM
    #1503
    Taco-Spike
    Two Trucks
    There is this option for people who are on your experience level at this moment in time
    ****2014-17 TRD PRO/SR5/LIMITED Non-Dimming LED DRLs (Bright mode all the time) $110 +shipping
    Non-Dimming Harness (Bright DRL All The Time), This option is 100% Plug n Play no wires to splice or mess with, no firewall wire or any sort of wiring under dash besides the Amber DRL Delete (optional) but the LED DRL turns ON/OFF with ignition and stay at full brightness all the time (not like factory functionality which dims the LED DRL). To power the LED DRL in this option we go to use a fuse tap to replace the 10A IGN fuse in the hood fuses box. Price for this option is $110 +shipping.
    This option is highly recommended if wiring projects are not your thing (better safe than sorry) or if youdefinitely need a quick PNP solution*****
    The other solution isn’t too bad (the $130) option. Function is more OEM with dimming DRL when low beams activated. If you look at the Instructions multiple times and get familiar with it. Installation will go a little easier, but does require tap / splicing / or cutting depending for desired amber delete.
    just choose you’re comfort level. At least there are options for people comfort level which is a plus.
  4. Aug 11, 2023 at 8:31 PM
    #1504
    iHacker
    iHacker [OP] SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Hello there, as @Taco-Spike mentioned there’s a fully plug and play harness option and you should be good to install the 2019 TRD PRO headlights in your 2016 PRO.
    There’s a lot of people running this setup and never had any issues, the only thing is optional is if you decide to delete the Amber DRLs and for this case you have to go under dashboard and depin gray wire from flasher relay (Pin 5 J29 harness)
    If you have more questions please let us know.
    Take care!
  5. Aug 12, 2023 at 3:36 AM
    #1505
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Nothing complicated about this at all. There are plenty of videos out there showing how to get the front end off and the rest is plug and play. It really is that easy, plus you being from the Austin area there probably should be someone out there that might lend you a hand if asked. Watch the videos a few times and everything goes very smoothly. Best of luck to you!:)
    ATXHusker[QUOTED] and Taco-Spike like this.
  6. Aug 12, 2023 at 5:07 AM
    #1506
    fyrfytr26
    fyrfytr26 New Member
    Eastern PA
    2021 DC SR
    Exactly. It’s a straight-forward modification. iHacker’s harnesses are the best out there - far better than options from other vendors. Just tell him what you have and what you’re upgrading to and he will get you the correct harness. After that it’s just removing the old headlights, plugging the adapter harnesses in, and reassembling.
  7. Aug 13, 2023 at 12:54 PM
    #1507
    ADOJC
    ADOJC New Member
    @iHacker Have you or would you consider building an 07-13 Tundra to 18-22 Sequoia LED Conversion Harness?
  8. Aug 13, 2023 at 2:21 PM
    #1508
    iHacker
    Mario
    Hello sir for the moment I don’t have any plans for this, I think a guy here in the forum is already working in this specific mod and he offers a harness for sale.@xrunnerdude67
    Not sure if he’s still working on it but you can Pm him
  9. Aug 13, 2023 at 10:38 PM
    #1509
    w3fl3x
    w3fl3x New Member
    @iHacker Do you have any Non-Dimming Harness available right now? I'd like to order it if you do have it available.
    iHacker[OP] likes this.
  10. Aug 14, 2023 at 11:10 AM
    #1510
    ATXHusker
    Chad
    Austin TX
    Appreciate the feedback! I ended up finding some new 3rd party ones on FB Marketplace for only $60! At that price I decided to take a chance on them. Only thing is I can't figure out how to get the motor adjusters on to the new ones from the originals. Before and after pics...
  11. Aug 14, 2023 at 11:19 AM
    #1511
    ATXHusker
    Chad
    Austin TX
    Tundrastruck91 likes this.
  12. Aug 14, 2023 at 1:10 PM
    #1512
    ADOJC
    ADOJC New Member
    @iHacker Understood. Thanks for the quick reply. I appreciate the referral to xrunnerdude67 but he hasn't responded to anyone in several weeks so i'm not sure what happened to him. Hopefully he's ok. Thanks again!
  13. Aug 14, 2023 at 1:58 PM
    #1513
    iHacker
    Mario
    Wow, we don’t have any ideas on what is going on with him but he also post on TundraCrew group in Facebook and Instagram
  14. Aug 14, 2023 at 5:02 PM
    #1514
    iHacker
    Mario
    ATXHusker[QUOTED] likes this.
  15. Sep 10, 2023 at 7:47 AM
    #1515
    Brian17pl
    Brian17pl New Member
  16. Sep 10, 2023 at 8:36 AM
    #1516
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    Same here. Top Notch construction. And a real good guy
  17. Sep 13, 2023 at 9:27 PM
    #1517
    Brian17pl
    Ordered and paid Sunday, got the adapters 3 days later, install was a breeze! True pnp.
    Definitely recommend!
  18. Sep 14, 2023 at 1:28 AM
    #1518
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
  19. Sep 23, 2023 at 11:43 AM
    #1519
    RedRegCab
    RedRegCab New Member
    Just finished my install. IHacker helped with all my questions and concerns, amazing customer service.
    Everything works perfectly !
  20. Sep 23, 2023 at 2:32 PM
    #1520
    Black@Blue19
    Ken
    SE Texas
    ^^^^yup yup that’ll do:) very nice indeed.
    out of all the mods I personally think this one ranks right at the top. Thank you iHacker!!:)
  21. Sep 25, 2023 at 3:26 PM
    #1521
    AZBoatHauler
    So.Arizona
    Has anyone encountered random crank but no start issue that ended up being traced back to the add-a-fuse? I have an intermittent issue and when checking fuses/relays I found this add-a-fuse wobbly and got me thinking…
  22. Sep 25, 2023 at 7:12 PM
    #1522
    iHacker
    Mario
    Hello, I haven’t heard from other members to have this issue but if you do lots of extreme off road that could be a possibility to have some issues with the fuse tap.
    In this case I recommend to change the fuse tap with one of the mini ATM fuse tap, this have the long fuse blades and that could help to solve this little issue. Or the other option is using a different fuse slot for any of the ignition switched fuses so that way you keep your IGN fuse alone.
    AZBoatHauler[QUOTED] likes this.
  23. Sep 25, 2023 at 7:55 PM
    #1523
    AZBoatHauler
    So.Arizona
    Thanks for the response. Do you happen to know an alternate slot that would work? Any key on circuit should work, right?
  24. Sep 25, 2023 at 9:35 PM
    #1524
    AZBoatHauler
    So.Arizona
    Just to be clear - I’m 1000% satisfied with my harness and customer service is as good as it gets. Thank you.
    Ebrperk and 1lowlife like this.
  25. Sep 28, 2023 at 3:15 PM
    #1525
    juanpatm
    juanpatm New Member
    Juan
    2019 SR5 Crewmax
    I'm new in this forum, actually in any forum, I'd like to get the harness from iHacker to replace my original 2019 SR5 Crewmax headlights with a pair of OEM TRD LED's i just bought. Can somebody direct me please on how to get that harness or if I should message iHacker directly and how to do that?
    Thank you very much, looking forward to find cool things for my Tundra here.
  26. Sep 28, 2023 at 3:32 PM
    #1526
    AZBoatHauler
    So.Arizona
    Look at one of his posts above, then click “start a conversation” under his profile picture to send him a direct message.
  27. Sep 28, 2023 at 6:20 PM
    #1527
    iHacker
    Mario
    Thanks!!
  28. Sep 28, 2023 at 6:20 PM
    #1528
    iHacker
    Mario
    Hello buddy, I sent you a PM
  29. Oct 4, 2023 at 1:33 PM
    #1529
    17tundratrdoffroad
    17tundratrdoffroad New Member
    Calgary, AB
    Shout out to ihacker! Harness with the dimming function installed and works great. A couple small hiccups but got it done. Thanks again.
    Black@Blue19 and iHacker[OP] like this.
  30. Oct 11, 2023 at 5:47 PM
    #1530
    Levipooh
    Levipooh New Member
    2014 Black Tundra SR5
