2018+ LED HEADLIGHTS PLUG N PLAY HARNESS FOR 2014-2021 MODELS [V 2.0]
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by iHacker, Apr 21, 2018.
  1. Sep 12, 2022 at 3:46 PM
    #1411
    Taco-Spike
    Two Trucks
    Use a long Phillips along that shaft to align them. You don’t need direct behind access
    iHacker[OP] likes this.
  2. Sep 12, 2022 at 4:10 PM
    #1412
    iHacker
    iHacker [OP] SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    As @Taco-Spike mentioned you don’t need to have access to the plastic gear to level your headlights just use a long Phillips screwdriver but I see a small problem in your picture #2 and you tucked the harness in that place blocking the channel for the Phillips screwdriver, not a big deal but take care in that part to avoid damage to the wiring
    Taco-Spike likes this.
  3. Sep 12, 2022 at 4:16 PM
    #1413
    BreezyTX
    BreezyTX New Member
    Had to YouTube to see what you meant and couldn't believe it was that easy. All squared away now, thanks! Works great @iHacker thanks for the fast shipping!
  4. Sep 12, 2022 at 6:57 PM
    #1414
    iHacker
    Mario
    Glad you figured out this!!
  5. Sep 16, 2022 at 7:02 PM
    #1415
    RyCo85
    RyCo85 TOYOTA - The One You Ought To Admire
    Ohio
    2015 Black Tundra SR5
    Slowly making her look like a 2020
    Thank you again @iHacker! Got my LED headlights installed on my 2015 tonight. Such an easy install with the harness!!
    1 question to everyone who has done this though…anyone have a misalignment on the two plastic push clips on the outside top of your grill compared to your headlight? I had to push in on the side of my headlights to get the hole to the headlight to align. Got them both installed but don’t remember them not being lined up when they popped out.
  6. Sep 17, 2022 at 5:57 AM
    #1416
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    Maybe make sure the harness wires aren't pinched somewhere behind the headlight- causing that slight misalignment.
  7. Sep 17, 2022 at 6:48 AM
    #1417
    iHacker
    Mario
    No misaligned issues reported, and I never had this problem with the installations I have made personally, check for pinched wires as @UTAHRTK mentioned or if your truck has ever been in an accident and repaired that could be a reason for this issue too.
  8. Sep 17, 2022 at 8:27 AM
    #1418
    RyCo85
    Ohio
    Checked harness and no previous accidents reported, looks good there, it’s happening on both lights….curious if it’s because they are the TYC CAPA lights….got them from a buddy who works at a repair shop brand new at cost…seems they may be misaligned a little
    iHacker[QUOTED][OP] likes this.
  9. Sep 17, 2022 at 9:24 AM
    #1419
    iHacker
    Mario
    Ohhh that could be a reason as well, I know the TYC headlights don’t have any difference in the wiring but not sure about a perfect fitment but must be really close to OEM headlights fitment
  10. Sep 17, 2022 at 12:34 PM
    #1420
    RyCo85
    Ohio
    Yeah the wiring was perfect and your harness plugged in perfectly….I bet the mounting points on the TYC are slightly off since they aren’t as good as the Toyota OEMs. Oh well, just wanted to check if anyone else had the same issue, I appreciate the insight on this!
  11. Sep 23, 2022 at 1:03 PM
    #1421
    Lettman
    Lettman New Member
    Hi @iHacker - I have a 2016 TRD Pro and I am interested in the dimming harness with amber delete -I sent a private DM - How do we move forward please? Thanks!
  12. Oct 6, 2022 at 4:01 PM
    #1422
    Lettman
    Lettman New Member
    Thanks @iHacker - Another VERY satisfied customer! And I appreciate the education on how the Emergency Brake works with the DRL's! Never realized that with the Ambers but now I will never forget! :) Fogs tomorrow along with new Predator steps. Then a break until Xmas when I get my new DiamondBack cover. :thumbsup:
    iHacker[OP] and RobertD like this.
  13. Oct 10, 2022 at 3:00 PM
    #1423
    InfernoBoyz
    InfernoBoyz YoutubeTech
    Reno, NV
    2016 Inferno Tundra Double Cab OR
    Just got my headlights in, going to install sometime this week but wondering how many of you had good headlight alignment out of the box? I got the TRD pro headlights, and a TRD pro front lift so wondering if they'll be good to go. can't wait.
  14. Oct 10, 2022 at 8:13 PM
    #1424
    iHacker
    Mario
    The headlights arrive close to be perfectly aimed and sometimes require just a tiny adjustment, when installed mine I remember the driver side was on spot and just a little adjustment in the passenger side mine was I little bit low on the passenger side
  15. Oct 19, 2022 at 8:28 PM
    #1425
    PKL92
    PKL92 New Member
    20221019_143439.jpg 20221019_203047.jpg 20221019_202932.jpg Thanks @iHacker. The harness work perfectly and was easy to install. Very happy with the overall new look
  16. Oct 20, 2022 at 3:52 PM
    #1426
    OffDaHook
    OffDaHook New Member
    Hi @iHacker I sent you a DM, looking to place an order :)
  17. Oct 20, 2022 at 8:29 PM
    #1427
    spicychickentundie
    spicychickentundie New Member
    Danny
    SOMD
    2014 Barcelona Red Tundra SR5 CM 4x4
    TRD RSB
  18. Oct 23, 2022 at 5:51 PM
    #1428
    Lemuel1
    Lemuel1 Enjoy
    Samuel
    2020 Tundra
    ToyTec Alumas 2.5,icon IT 2.5 rear,Wheelers superbumpstops, JBA UCA’s, 8 inch BA muffler kit,
    RobertD and iHacker[OP] like this.
  19. Oct 29, 2022 at 11:47 AM
    #1429
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    @iHacker sent you a PM, looking to place an order ASAP :spending:
  20. Nov 2, 2022 at 1:14 PM
    #1430
    Heb
    Heb New Member
    2017 Tundra SR5 Superwhite
    Katskinz leather seats, canopy
    @iHacker PM sent in a wiring harness request.
  21. Nov 5, 2022 at 10:45 PM
    #1431
    AndreLou91
    AndreLou91 New Member
    2014 White Tundra DC SR5
    @iHacker PM sent! Payment ready. Thanks!
  22. Nov 9, 2022 at 3:45 PM
    #1432
    Bentbrent25
    Bentbrent25 New Member
    BRENT
    TUNDRA TRD PRO
  23. Nov 19, 2022 at 6:56 PM
    #1433
    BoatBroker
    BoatBroker New Member
    Sarasota, Florida
    2016 Tundra SR5
  24. Nov 21, 2022 at 8:55 PM
    #1434
    AndreLou91
    Second time I've done this mod with @iHacker 's harness and it worked perfectly again as expected (bright mode all the time, amber delete, gloss black TRD pro housing). High quality harness, fast shipping, great communication. If you're on the fence, just pull the trigger. IMO it's the best front end aesthetic and functional mod for these trucks.
  25. Nov 22, 2022 at 4:42 PM
    #1435
    iHacker
    Mario
    Nice picture :thumbsup::thumbsup:
  26. Nov 27, 2022 at 10:43 AM
    #1436
    jonclark96
    jonclark96 Not so new member
    Jon
    Maryland
    2021 Army Green SR5
  27. Nov 27, 2022 at 3:52 PM
    #1437
    BoatBroker
    Sarasota, Florida
    2016 Tundra SR5
    I just used his harness to put 2020 LED headlights from a 1794 into my 2016 SR5 and it worked perfect. I did the dimming option.
  28. Nov 27, 2022 at 5:12 PM
    #1438
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    Excellent customer service and fast shipping.
    @iHacker makes upgrading to LED lights easy peasy.
  29. Nov 29, 2022 at 9:53 PM
    #1439
    Nahperator
    Nahperator New Member
    2021 Tundra TRD Sport
  30. Nov 30, 2022 at 10:45 PM
    #1440
    Shaff777
    Shaff777 Rocking the Tundra since 2010
    Justin
    Boise
    2020 cement SR5
    Boss 2.5 Aluma kit. SPC UCA’s Color matched front surround Scs Ray 10 wheels. Cooper AT3 XLT’s 295/70/18
    IHacker- I have a 2020 Tundra SR5. Came with DRL strip. I just purchased the TRD pro LED’s from sparks parts. I was under the impression that I didn’t need a new harness if my truck had the DRL’s starting in 2020. Can you clarify?
