2018+ LED HEADLIGHTS PLUG N PLAY HARNESS FOR 2014-2021 MODELS [V 2.0]
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by iHacker, Apr 21, 2018.
  1. Jan 9, 2020 at 5:22 PM
    #811
    Azblue
    The Dirty T ( ^_^)_且
    With. As you can see, it almost seems brighter on the camera before turning on the headlights. I know cameras and bright light don't mix well, but it shows how bright the LED DRL are in full bright mode.
  2. Jan 9, 2020 at 5:25 PM
    #812
    Azblue
    On a side note, anybody notice the little mod I had to do to my garage floor to fit the truck in?
    LogCabins and AZTundra like this.
  3. Jan 9, 2020 at 5:41 PM
    #813
    AZTundra
    Paul
    Phoenix, AZ
    Every inch counts.
    iHacker[OP] and Azblue[QUOTED] like this.
  4. Jan 9, 2020 at 5:42 PM
    #814
    iHacker
    iHacker [OP] SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    :D Good deal, :thumbsup::thumbsup:
    Azblue[QUOTED] likes this.
  5. Jan 10, 2020 at 7:35 AM
    #815
    socaltundra951
    socaltundra951 Gentlemen Prefer Black Tundras
    Southern California
    Black CrewMax 5.7
    I went back and forth on this and decided to keep the amber, I loved the bit contrast it gave. Just my opinion but I've never been one for following the crowd too closely, a little bit of different is nice.
    TOYOTRD8, LogCabins and paradizecityz like this.
  6. Jan 10, 2020 at 7:38 AM
    #816
    LogCabins
    LogCabins Professional Procrastinator
    'Merica
    2017 TRD Pro
    Did you get the dimming harness? I would delete the amber DRL but that just my opinion.....to much going on with LED DRL strips top and bottom and an Amber DRL...just my .02
  7. Jan 10, 2020 at 7:57 AM
    #817
    socaltundra951
    Southern California
    Black CrewMax 5.7
    I had my mind made up both ways several times. ;)
    It's super easy to remove, though so for those that prefer it without it's no biggie.
    LogCabins[QUOTED] likes this.
  8. Jan 10, 2020 at 8:13 AM
    #818
    r8rs4lf
    r8rs4lf New Member
    Al
    Tree Juan Hoe
    2015 MGM SR5
    I'm with you and I'm keeping the amber. I like that it's a little different.
  9. Jan 10, 2020 at 8:31 AM
    #819
    LogCabins
    'Merica
    2017 TRD Pro
    Not gonna lie your picture makes it look really nice with the Amber on!
  10. Jan 10, 2020 at 9:02 AM
    #820
    AZTundra
    Paul
    Phoenix, AZ
    Yes, I went with the dimming harness. I'm pretty much set on doing the amber delete, just wanted to see what the consensus was.
  11. Jan 10, 2020 at 11:42 AM
    #821
    r8rs4lf
    r8rs4lf New Member
    Al
    Tree Juan Hoe
    2015 MGM SR5
    Need some help....
    Hooked everything up keeping the amber and I'm not getting the LED DRL's. They come on with the headlights, but nothing while in drive with parking brake off. I tapped into the grey wire and the black wire like instructed.
    iHacker[OP] likes this.
  12. Jan 10, 2020 at 12:02 PM
    #822
    RDRunner
    RDRunner New Member
    2016 SR5 Crewmax 4x4 TSS Edition
    I just installed mine last weekend with the dimmer harness. Mine works perfectly and I went without the amber. However, if I had to do it over again, I would have done the non-dimming harness because I think I would prefer the lights not to dim down (they are not that bright IMO) and all the extra work for the dimming is not worth it to me. I could have spent half the time not going into the cab with the dimming feature.
    I did discover a trick to unpin the gray wire that may be useful to someone. I did not have the de-pinning tool but I did have an ice pick type tool but I could not get it depinned with any tools (not even close). I depinned it by holding the harness lock up with one hand and then using the other hand to pull very hard on the actual wire (pull close to the harness), and it popped right out without damage. I bet I could use this technique over and over again to de-pin. I figured if I broke the wire, no big deal because it would have been broken close to the harness or at the pin, and I would just solder the wire to the connection (leaving the pin in the harness will not affect anything so long as no wire is run to it).
    LogCabins, TOYOTRD8 and iHacker[OP] like this.
  13. Jan 10, 2020 at 1:50 PM
    #823
    r8rs4lf
    r8rs4lf New Member
    Al
    Tree Juan Hoe
    2015 MGM SR5
    Apparently there are two grey wires and I was tapped in to the wrong (thick) one. It's the thin grey wire that needs to be used. Thanks @iHacker for the support!!
    All fixed and working now!
  14. Jan 10, 2020 at 2:43 PM
    #824
    AZTundra
    Paul
    Phoenix, AZ
    Good to know for tomorrow. Thanks for posting the issue and resolution. :thumbsup:
  15. Jan 10, 2020 at 2:47 PM
    #825
    RDRunner
    RDRunner New Member
    I almost made that same mistake. It is the thin gray wire.
  16. Jan 11, 2020 at 3:10 PM
    #826
    AZTundra
    Paul
    Phoenix, AZ
    2018 Platinum headlights are installed, but my turn signals are hyper flashing. I recall the previous owner mentioning he installed led turn signals into the housings. Could this be my problem? Do i need to do anything else to keep the LEDs or do i need to swap my old turn signal bulbs into the new housing? Overall install wasnt too hard, but depinning for the amber drl delete was a pain. @iHacker made the harness spot on for the swap.
  17. Jan 11, 2020 at 3:16 PM
    #827
    iHacker
    Mario
    Yes definitely the LED turn signal bulb is causing hyperflash but adding load resistors should fix the problem
    AZTundra[QUOTED] likes this.
  18. Jan 11, 2020 at 3:18 PM
    #828
    AZTundra
    Paul
    Phoenix, AZ
    Thanks for the quick response. Are there any specific ones that you recommend? I assume I'm okay to drive like this until i install the load resistors right?
  19. Jan 11, 2020 at 3:20 PM
    #829
    iHacker
    Mario
    You can buy the 6 ohm resistors, yes is safe to leave this as it is until you have the time to install the resistors
    Y0TA PR0 and AZTundra[QUOTED] like this.
  20. Jan 11, 2020 at 3:22 PM
    #830
    AZTundra
    Paul
    Phoenix, AZ
    Perfect. Thanks again.
  21. Feb 5, 2020 at 9:38 PM
    #831
    derkks
    derkks New Member
    Oregon
    Has anyone else had any problems with their LED DRL turning off and on? I can hear a click that sounds like it is coming from the left side of my dash. The headlights don't click on and off.
  22. Feb 5, 2020 at 9:43 PM
    #832
    iHacker
    Mario
    Hello buddy, to me sounds like a loose connection double check the gray>black wire connection, did you kept the amber DRL or just the LED?
  23. Feb 6, 2020 at 12:03 AM
    #833
    derkks
    derkks New Member
    Oregon
    Okay I'll check that out. It's been a long time since I did it but I think I removed the amber DRL by cutting the wire.
  24. Feb 6, 2020 at 5:07 AM
    #834
    iHacker
    Mario
    Ok that makes sense, if you cut the wire the best way to keep it secure is soldering to avoid this kind of problem.
    keep me posted.
  25. Feb 6, 2020 at 8:18 AM
    #835
    2018Tundo
    2018Tundo New Member
    cahd
    2018 Tundra SuperCrew
    what bulbs do you use for the headlights them self. I have leds already at the bottom of my lights?
  26. Feb 6, 2020 at 8:41 AM
    #836
    iHacker
    Mario
    The full LED headlights don’t have any user serviceable LED bulbs (except for side markers and turn signals) but if you don’t want to change the whole headlight housings I recommend you to check the H4 Phillips Xtreme Ultinon.
  27. Feb 6, 2020 at 10:47 AM
    #837
    2018Tundo
    cahd
    i was looking at these
    https://www.amazon.com/Auxbeam-Head...sa_cr_id=6379674470601&ref_=sb_s_sparkle_slot
    but i would like some feeback too. at 170.00 for the phillips id expect they to be amazing..
  28. Feb 6, 2020 at 10:57 AM
    #838
    iHacker
    Mario
    Yep the Phillips bulbs are great I had them in my truck and they are bright enough and had a decent cutoff not scattered like most of the Amazon cheap bulbs, I heard Phillips came out with the 2nd gen of this bulbs I believe I had the first gen so probably the new bulbs are even better.
    I paid $250
  29. Feb 7, 2020 at 1:22 PM
    #839
    JayCO
    JayCO New Member
    Looking good! What bumper is that?
  30. Feb 29, 2020 at 11:37 AM
    #840
    TeamGoose
    TeamGoose Threat Level Midnight, Michael Scarn
    Temple, TX
    2020 Tundra TSS 4x4 Cement
    OEM LED Headlights, TRD Shifter, Interior LEDs, 6112(1.9) & 5160 reg. height
    Well I was able to get to the headlights this morning before work! Thanks @iHacker for all your input and speedy shipment!!!! And yes that was all done in my hotel parking lot lol.. Took all of 40 mins.
