2018+ LED HEADLIGHTS PLUG N PLAY HARNESS FOR 2014-2021 MODELS [V 2.0]
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by iHacker, Apr 21, 2018.
  1. Jul 21, 2019 at 9:42 AM
    #691
    iHacker
    iHacker [OP] SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Check this options:
    Kyk1e[QUOTED] likes this.
  2. Jul 21, 2019 at 10:58 AM
    #692
    Yzed608
    Yzed608 New Member
    Wisconsin
    Thanks for this post, it and the video explained the questions I had about functionality. I have a 2017 SR5 non-LED, my plan would be to do LED high all the time harness and keep ambers on. Does your last point mean the ambers would behave the same as now- dim when headlights are on (white DRL's would remain at 100%), and turn signals would flash amber only on and off at normal brightness? Just want to be completely sure on function.
  3. Jul 21, 2019 at 11:24 AM
    #693
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    If you elect to use the non-dimming harness with 2018+ headlights, nothing changes on operation of your 2017 turn signals/park lamps/DRLs. Unless you do the amber DRL-delete mod, all of those functions will remain exactly the same as they are now in the stock 2017 SR5. The reason that's true is because the non-dimming harness does not enter the cabin where the DRL wire and flasher are; it connects to 12V power inside the fuse box under the hood.
    You may want to upgrade the amber turn signal/park lamp/DRL bulbs in your 2018+ headlight housings to LEDs. The incandescent bulb spec'd for the turn signal function is notorious for not being visible to oncoming traffic. Do a search, there are many threads on this topic.
    iHacker[OP] and Yzed608[QUOTED] like this.
  4. Jul 21, 2019 at 11:38 AM
    #694
    Yzed608
    Yzed608 New Member
    Wisconsin
    You're awesome, thanks man!
    JohnLakeman likes this.
  5. Jul 23, 2019 at 9:55 PM
    #695
    ab1653
    ab1653 Ew member
    TX
    2014 Tundra
    Sorry if this has been asked but I just got my hands on some 2014 platinum headlights with the LED at the bottom of the headlight.. my question is what do I need to make them work on my 2014 SR5? Is it plug n play or do I need a harness??
    iHacker[OP] likes this.
  6. Jul 28, 2019 at 12:28 PM
    #696
    mr_data
    mr_data New Member
    Northern New York
    2016 Super White Tundra SR5
    Just finished installing mine. Looks much better than the original lights. No issues at all with the harness, but getting that gray wire out for the DRL was a real PITA. Thanks @iHacker for a quality product and detailed instructions.
    Before:
    After:
    Dray, Kyk1e, Watt maker and 1 other person like this.
  7. Jul 28, 2019 at 12:50 PM
    #697
    iHacker
    Mario
    Thanks for the update!
    A complete front end conversion your truck looks awesome!!
  8. Jul 28, 2019 at 2:31 PM
    #698
    Alaska
    Alaska New Member
    2017 Tundra TRD 4x4 ~Quicksand~
    Baja Designs Squadron WC fogs
    Can anyone speak for the performance of the TRD Pro headlights vs stock SR5s? I am wondering if there is any improvement at night... we have long winters up here in Alaska! Anything better out there?
    Looks GREAT Mr. Data!
  9. Jul 28, 2019 at 2:34 PM
    #699
    Azblue
    The Dirty T ( ^_^)_且
    The LEDs are much better than the stock halogen. A lot "crisper" and improved distance IMHO.
    Alaska[QUOTED] likes this.
  10. Jul 28, 2019 at 6:58 PM
    #700
    408Tundra
    408Tundra New Member
    Will
    2017 Tundra TRD Limited Crewmax 4x4
    I’m installing my 19 pros in my 17 limited I can’t ding the grey wire to depin help
  11. Jul 28, 2019 at 7:15 PM
    #701
    iHacker
    Mario
    Sent you a PM
  12. Jul 29, 2019 at 2:44 AM
    #702
    drhntr
    drhntr New Member
    Derrick
    New Hampshire
    2017 Cement Pro DC
    GoRhino 2.0 Diamondback Switchback 295/70/18 TOYO AT3 TRD CAI Window Tint
    Is there an actual D-pin tool to use it seems like there’s a little bit of trouble D-pinning that lil f@cker
  13. Jul 29, 2019 at 3:18 AM
    #703
    iHacker
    Mario
    Yes I suggest a depin tool in the installation guide but sometimes isn’t in stock from the link I shared but it’s fairly easy to find from other sources on eBay it’s a popular tool for that purpose.
  14. Jul 29, 2019 at 6:46 AM
    #704
    Kyk1e
    Kyk1e New Member
    Kyle
    Limerick, Pa
    2017 Toyota Tundra TRD Pro
    I got my depin tools from Amazon. Around $10
    drhntr[QUOTED] and iHacker[OP] like this.
  15. Jul 29, 2019 at 9:14 AM
    #705
    Alaska
    Alaska New Member
    https://www.tundras.com/threads/headlights.36272/#post-916912https://www.tundras.com/threads/headlights.36272/#post-916912
    I found picks comparing the halogen to 2019 LED lights at the link above (MESSAGE #21). It definitely makes a difference! I'll have to put it on purchase list! Where do you all buy these lights, local dealer, online retailer? Shipping on parts to Alaska is horrendous. I was quoted $199 for shipping of a color match grill and an additional $130 for the bulge. ROBBERY!
    Azblue[QUOTED] likes this.
  16. Jul 29, 2019 at 9:56 AM
    #706
    iHacker
    Mario
    :( Considering your high shipping quote I’d rather try at local dealership first
  17. Jul 29, 2019 at 10:03 AM
    #707
    408Tundra
    Will
    Depinning tool need to be inserted all the way in then pulls out easy
  18. Jul 29, 2019 at 10:37 AM
    #708
    Azblue
    Maybe you can show your local dealer prices from other Toyota dealers that sell online and get them to match or at least discount a bit if you buy from them.
  19. Jul 29, 2019 at 12:15 PM
    #709
    Alaska
    Alaska New Member
    Just got a quote for $498 per light. They said that their prices are firm and do not price match. Must have learned that in Stealership 101 training.
  20. Jul 29, 2019 at 12:43 PM
    #710
    iHacker
    Mario
    :crazy:
    That’s insane, where they got that number? Then online ordering is your best bet
  21. Jul 29, 2019 at 1:01 PM
    #711
    Azblue
    Damn, I believe I paid about $280 each and got free shipping during Toyota of Cool Springs Black Friday sale.
    iHacker[OP] and Watt maker like this.
  22. Jul 31, 2019 at 8:09 AM
    #712
    NickBrewer
    NickBrewer New Member
    2023 Toyota Tundra 1794 Edition Magnetic Gray Metallic
    Even Roman at Toyota of Cool Springs doesn't extend his free shipping offer to Alaska. Unlike the rest of the country Alaska only has 3 Toyota Dealers for the whole state and they are all owned by Kendall, so no competition. When I purchased things like the TRD Pro grill, hood bulge and headlights I had Roman ship the items to a freight forwarder, saved quite a bit of money that way. Span Alaska is probably one of the largest freight forwarders serving Alaska and gives great service: https://www.spanalaska.com/
    Alaska and iHacker[OP] like this.
  23. Jul 31, 2019 at 10:47 AM
    #713
    RG2015
    RG2015 New Member
    How’s it going I hacked, wanted to mention that I just saw your video on YouTube about this harness. I’m about two weeks too late, I just purchased my 2019 led headlights from Toyota and ordered a conversion kit harness from headlight revolution. After watching your video, I want yours. I can’t stand the Amber drl on my new ones. Just wanted to know how long it would take to make me a harness for my 2015 tundra with dimming drls and eliminating the amber...all the works.
  24. Aug 4, 2019 at 11:14 PM
    #714
    Tundra-XP
    Tundra-XP New Member
    Will
    2020 Toyota Tundra XP MGM CM TRD Off Road
    IHacker, have you came out with a harness yet for a fog light mod?
  25. Aug 5, 2019 at 9:33 AM
    #715
    Alaska
    Alaska New Member
  26. Aug 5, 2019 at 11:27 PM
    #716
    Tundra-XP
    Will
    They look awesome. I was wandering if he had came out with a wiring harness for a fog light mod so our OEM fog lights can to turn on anytime without the headlights being on or with the high beams.
  27. Aug 6, 2019 at 4:33 AM
    #717
    iHacker
    Mario
    Hello buddy,
    This is a simple process and a harness isn’t required just basic tools you probably have at home and a piece of 16 or 14 gauge wire, check this thread
    Method 1: (easy way 5 mins aprox)
    https://www.tundras.com/threads/easy-5-min-anytime-fog-light-relay-mod-diy.20508/#post-478959
    https://youtu.be/-kfzNGUAs-A
    Method 2:
    Read any of this attached PDFs
  28. Aug 6, 2019 at 7:23 PM
    #718
    Tundra-XP
    Will
    Awesome. Thanks.
  29. Aug 9, 2019 at 9:17 AM
    #719
    ab1653
    ab1653 Ew member
    TX
    2014 Tundra
    I got the harness from @iHacker and it was very easy to install, and this is coming from someone who has zero experience with wiring. Harness arrived fast and I was able to install the platinum headlights with led bottom strip on my 14 SR5. Very happy 0158916F-9619-4CE2-A1D2-A0C980DFD746.jpgD4327FE4-93F2-463C-A887-55EDB5030361.jpg
    drhntr and iHacker[OP] like this.
  30. Aug 9, 2019 at 11:07 AM
    #720
    iHacker
    Mario
    Looks great and working properly as it should be. Installation is not that bad just need patience and 2-3 hours to make things right.
