2018+ LED HEADLIGHTS PLUG N PLAY HARNESS FOR 2014-2021 MODELS [V 2.0]
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by iHacker, Apr 21, 2018.
  1. Apr 2, 2019 at 8:35 PM
    #571
    Chenerr
    Chenerr New Member
    2017 Gray Tundra SR5
    Ihacker I just sent you a PM.
    iHacker[OP] likes this.
  2. Apr 3, 2019 at 7:16 AM
    #572
    iHacker
    iHacker [OP] SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Ok I’m checking and replying to the PM later
  3. Apr 11, 2019 at 6:07 AM
    #573
    VTYOTA
    VTYOTA I DECLARE BANKRUPTCY!!
    Howard
    'Merica
    2014 SS CM TRD
    Another satisfied customer. (Auto Dimming Harness)
    iHacker[OP], Watt maker and Deafmate like this.
  4. Apr 11, 2019 at 10:50 AM
    #574
    trddriver
    trddriver New Member
    '14 1794
    open to discussion
    Is it normal for the Amber's to be illuminated, or is that because it was not led DRLs prior?
  5. Apr 11, 2019 at 10:56 AM
    #575
    VTYOTA
    Howard
    'Merica
    2014 SS CM TRD
    It's not normal. If you are using the iHacker harness, you can choose to keep it or not.
  6. Apr 11, 2019 at 12:24 PM
    #576
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    Once the harness is plug and play.. (bone head proof), ill likely bite. No part of me wants to depin or tap under the dash.. Good Lord No. Lol
    Looks like a nice harness though.. Will be monitoring his progress. :popcorn:
  7. Apr 11, 2019 at 12:27 PM
    #577
    VTYOTA
    Howard
    'Merica
    2014 SS CM TRD
    He already sells a plug and play version. I bought the version that is not PNP, but it wasn't hard at all. Especially since he will provide Posi-Taps that are easy to use. Took me 2 hours in the dark. Most of that time was spent trying to figure out how to take the grill and lower dash off. I could probably do it in half the time now.
    But again, you can go the PNP route and not have to deal with any of that.
    Watt maker and Tierhog[QUOTED] like this.
  8. Apr 11, 2019 at 12:28 PM
    #578
    trddriver
    '14 1794
    open to discussion
    I think it is already full plug N play provided you order it according to your truck
    Thx forfor the response @VTYOTA
    Tierhog likes this.
  9. Apr 11, 2019 at 12:30 PM
    #579
    Tierhog
    Tierhog SIG-AHOLIC
    I probably got lost in chatter then. I read his directions and it seemed limited and others had some under the dash electrical issues that had to be contended with...DRL or something. As luck would have it, I have the amber DRL, and a limited..
    I'll read it again.
  10. Apr 11, 2019 at 12:41 PM
    #580
    VTYOTA
    Howard
    'Merica
    2014 SS CM TRD
    This is what you would need. Nothing to do under the dash. You follow steps 1-4 and then just follow the directions about tapping into the fuse box. Which is just taking a fuse out of the IGN slot -> add the fuse you just took out to the harness -> plug the harness into the IGN slot. Done.
    TRD PRO/SR5/LIMITED Non-Dimming LED DRLs (Bright mode all the time) $110
    Ask first for this option, I can do this one by request only, this work fuse tapped to the IGN fuse your DRL will be ON/OFF keyed. If you have no experience with electrical wiring projects this is the way to go 100% PNP
  11. Apr 11, 2019 at 12:52 PM
    #581
    Tierhog
    Tierhog SIG-AHOLIC
    Thanks Howard. I took a screenshot. That's pretty easy. I'll look for the headlights now. Some apparently have incandescent amber bulbs.. Lol (Who does that?)
    Maybe Sparks, or something closer to me so shipping isn't ridiculous.
    Thanks again.
    VTYOTA likes this.
  12. Apr 11, 2019 at 12:55 PM
    #582
    iHacker
    Mario
    Thanks @VTYOTA like you said there’s a complete plug n play option to have LED DRL in your Limited @Tierhog you can choose the Non-Dimming Harness and everything is done in the engine compartment (no wires through firewall no under dashboard modifications).
    For @trddriver my harness for your 1794 truck is plug and play and you don’t have to do anything for the LED DRL since your truck is pre wired for the single LED strip
  13. Apr 11, 2019 at 1:08 PM
    #583
    VTYOTA
    Howard
    'Merica
    2014 SS CM TRD
    No problem. I ordered mine from Spark Parts ($585 total for me). Make sure to use the "TUNDRAS.COM" code before you check out.
    Tierhog[QUOTED] and iHacker[OP] like this.
  14. Apr 11, 2019 at 8:00 PM
    #584
    Tierhog
    Tierhog SIG-AHOLIC
    Hmmm. Why on earth would Toyota do this.. Lol.
    I appreciate the info.
    Watt maker likes this.
  15. Apr 11, 2019 at 10:14 PM
    #585
    americanaaron
    americanaaron USA
    North Carolina
    2019 Tundra
    If and what harness is needed to switch from 2019 led drl headlights to 2019 TRD Pro headlights?
    Sorry if it’s been answered, but haven’t found it yet
  16. Apr 11, 2019 at 10:42 PM
    #586
    iHacker
    Mario
    What is your truck trim? SR5 with single LED strip?
    Like this
    For a truck like this to add 2019 TRD PRO headlights you gonna need the $100 option check the OP
  17. Apr 15, 2019 at 8:05 PM
    #587
    cali_pro
    cali_pro New Member
    California
    2017 Tundra PRO
    LED Grille Lights Nitto Terra Grappler Rockford 5 Channel Amp JL 10' behind seat Door Speakers Swapped 2019 TRD PRO Headlight swap
    IMG_0637.jpg IMG_0638.jpg Got mine in yesterday...:bananadance:
    Thanks iHacker !!!! Beautiful product. Works great!!
    Oh ya.....grey wire under dash, a b$%ch. I just cut mine. Hopefully I never need it again or need to strip it anymore. No room.
    Rest of install is straightforward via the instructions. Just dont skip a step. I did and cost me about 10 min.
    Buildn, blandon, iHacker[OP] and 2 others like this.
  18. Apr 18, 2019 at 7:26 PM
    #588
    AjOrduna
    AjOrduna New Member
    2016 Blue Toyota Tundra
    I'm wanting to put the 19 headlights on my 16 Limited but I would like to know what happens to the DRL switch on the steering column.
  19. Apr 19, 2019 at 5:33 AM
    #589
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    No switch changes on the steering column.
    With @iHacker DRL dimming harness, you can choose to delete the amber DRL by de-pinning one wire. Or, you can choose to retain the amber DRL, and they will function the same as they did before. With the 2018/2019 headlights, LED DRL strips will be added, but will dim when the headlights are turned on.
    Edit: @AjOrduna De-pinning can be a challenge to the inexperienced. See post #603 directly above yours for degree of difficulty.
    VTYOTA likes this.
  20. Apr 19, 2019 at 7:12 AM
    #590
    New_DoorDing
    New_DoorDing New Member
    2016 TRD Pro DoubleCab
    Its just like @JohnLakeman said. The DRL configuration you want is completely up to you, but trust me, you’ll want only the LED DRL once you see them. That is coming from someone who loved only the amber DRL that my 16 TRD Pro came with. I just changed mine out last weekend. Dont be afraid of depinning(unclipping a wire from plug). If you watch the video which @iHacker provides AND read the written instructions, all on his thread, there honestly is NO way you’ll struggle with it. If you dont want to take my word for it, you can easily try it out before buying anything.
    There are only 2-10mm bolts and super strong clips that are meant to be removed so dont snap on you, which hold the panel by your feet. Watch the video on how to remove the panel on iHackers instructions and practice depinning the gray cable you’re supposed to. The written instructions explains part of the process and the video explains the other part. BOTH ARE CRUCIAL to making this the easiest task ever. A thumb tack or safety pin will work just fine.
  21. Apr 20, 2019 at 7:47 AM
    #591
    AjOrduna
    AjOrduna New Member
    Thanks @JohnLakeman and @New_DoorDing I'm not worrying about installation or depinning, just wanted to know what happens to the original switch. I build Camrys for a living so it should not be too much difference.
    New_DoorDing and Watt maker like this.
  22. Apr 20, 2019 at 9:24 AM
    #592
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    This new version is sweet, i finally had time to take out the old harness out , and swapped it to the new version.
    New_DoorDing likes this.
  23. Apr 20, 2019 at 9:48 AM
    #593
    blandon
    blandon New Member
    Butch
    2016 TRD Off Road
    Got my harness and new lights installed, looks and works awesome!!! Thanks Ihacker for a great harness and easy to follow instructions! Everything looks very neat and clean!!
  24. Apr 20, 2019 at 10:04 AM
    #594
    JohnLakeman
    Maybe I'm confused, but there is no switch for DRL on my 2017 SR5 Tundra. They come on with the engine running and the parking brake off. They go off when you turn the headlights turn on (or you shut the ignition off). Starting with 2018, I believe the driver can turn the DRL off.
    If you're thinking of the Park light switch position, or the fog light switch ring, those functions do not change.
  25. Apr 21, 2019 at 7:52 PM
    #595
    New_DoorDing
    I am also confused. The 16 TRD pro doesnt have a switch to turn off the DRL’s. I’m with @JohnLakeman in that I believe you’re confusing your truck bed light switch to the left of your steering wheel. That light only illuminates the bed of your truck.
  26. Apr 21, 2019 at 10:47 PM
    #596
    iHacker
    Mario
    Older trucks with higher trim have a DRL Switch too, starting with the 2014-17 Limited (not 100% sure), Platinum and 1794 trucks. SR, SR5 and PRO never had that option for those years :(
  27. Apr 21, 2019 at 11:06 PM
    #597
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    I second that notion. Havent had anyone flashing me. Even have come across plenty of cops in the opposite direction.
    iHacker[OP] and New_DoorDing like this.
  28. Apr 24, 2019 at 6:08 AM
    #598
    Bongskie
    Bongskie Mucho LOCO
    2016 Black Crew
    6" Pro Comp Kit, Mayhem 20" rim, Toyo M/Ts
    iHacker, looking to purchase your harness(dimmable).
  29. Apr 24, 2019 at 2:25 PM
    #599
    Okietundra
    Okietundra New Member
    OKC OK
    2025 Lunar Rock Platinum
    So just cut the darn thing? What's all this depin rodeo about? @iHacker what's the word?
  30. Apr 25, 2019 at 4:21 PM
    #600
    Nmanning556
    Nmanning556 New Member
    VA
    2015 Crewmax SR5 4x4
    +1 for these harnesses - super clean work. Fits and runs perfectly
