2018 LED headlights install on 2015 platinum
Discussion in 'Lighting' started by Pudge, Jun 15, 2018.
  1. Jun 15, 2018 at 11:42 AM
    Pudge
    Pudge [OP] Super Secret Elite Member #7
    CT
    2015 Blue Ribbon Platinum
    So it's about to go down. Got my headlights from @Erichudgins yesterday and my harness from @iHacker today and i couldnt be happier with these two guys. A+++ rating for both. This harness quality is beyond what I expected, well beyond. I'm heading out now to put them on and I'll take some pics as I go. Wish me luck!
    These are "sport smoked" 18 headlights. Instead of a chrome bezel it's smoked chrome. Not a huge difference from the chrome but slightly darker. I head Toyota will be doing "black" soon, presumably for the 19 PRO
  2. Jun 15, 2018 at 11:44 AM
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    Lol I knew you wouldn't be disappointed!! Hit me up if you have any questions man!
    Pudge[OP] likes this.
  3. Jun 15, 2018 at 11:52 AM
    Pudge
    CT
    Smoked chrome area above and below reflector in first pic
    2nd pic compared to chrome on my 15 OEM lights
    Some pics show the darker color due to less reflections. Definetly darker than chrome.
    The inner parts of the lights are dark in color, smokes, gray, black. So overall all the 18 led headlights are darker than previous generations, even look darker overall compared to the 3rd gen pro lights
    First step will be to remove the grill!
    TXRailRoadBandit73 and iHacker like this.
  4. Jun 15, 2018 at 11:53 AM
    Pudge
    CT
    Thanks Eric. I'm taping off now and will remove grill in a few
  5. Jun 15, 2018 at 12:06 PM
    Pudge
    CT
    Grille off without incident. Had an idea how to do this from when I put on my pro grille. 4 bolts, 2 retainer pins on top, 2 clips down low one of which I previously broke lol. Then it pulls right off.
    I did a quick spray detail wax on bumper lip since it was dirty and accessible.
    Next is trim under headlights
    boostedtrdpro and Erichudgins like this.
  6. Jun 15, 2018 at 12:16 PM
    Pudge
    CT
    Two push pins and 2 bolts in fender well. You gotta pull harder than you think but nothing will break. Yank off the panels
    Sorry for crummy pics.
    More spray wax in area and some black pray paint in a few parts behind grille.
  7. Jun 15, 2018 at 12:26 PM
    Pudge
    CT
    Remove headlight
    Two bolts up top, one one the side. And then you need to lift up a bit in the top mount tabs and also lift slightly to release from a little sliding tab below. Put a towel on bumper area to rest the light on while you unplug all the connectors
  8. Jun 15, 2018 at 12:27 PM
    Pudge
    CT
    Next is to remember to disconnect battery ground. Lol. This should be done 1st but I just remembered.
  9. Jun 15, 2018 at 12:37 PM
    Erichudgins
    Eric
    Murfreesboro, TN
    Also set your motocontrol at 0!
    iHacker and Pudge[OP] like this.
  10. Jun 15, 2018 at 12:41 PM
    Pudge
    CT
    Now start connecting your harness from @iHacker, it's self explanatory and very easy to figure out.
    This would also be time to swap the marker light bulb or blinker bulb if you plan to go full LED. I just swapped the side marker with a hikari 194 bulb I had sitting around.
    Reinstall lights in opposite order you took the old one off. It slid in very easily and I tucked the wires in behind without issues.
    Reattach ground and test light functions
    Teaser pic....
  11. Jun 15, 2018 at 12:48 PM
    Pudge
    CT
    Sweet success!!!
    One down one to go.
    DRL, side marker, blinker, low and high beams. All working perfectly thanks to @iHacker
  12. Jun 15, 2018 at 12:50 PM
    Pudge
    CT
    Live install feed still going. Will do other light now and pics when grill back on
  13. Jun 15, 2018 at 1:10 PM
    Pudge
    CT
    Done. That couldn't have gone better or been more simple. Given I have the platinum which requires a little less work as far as wires. It was a super easy mod and damn do these lights look good. Can't wait for it to get dark out so I can take a drive
  14. Jun 15, 2018 at 1:29 PM
    Pudge
    CT
    DRL automatically dims if you have a Platinum and ihacker harness is compatible with this feature, pretty cool.
    Pics don't do it justice, it looks so good.
    Also DRL LED's don't photograph well when tbey are dim, it's weird but trust me they're all on and look great
    I have 3k yellow nokian halogen fog bulbs. That may change soon.
  15. Jun 15, 2018 at 1:45 PM
    Pudge
    CT
    This really makes my front end look so much better. From the day I put on my pro grille I have been dying to rid of the chrome headlights. I stumbled upon this deal and ran with it. Not only does it look better, the function will be greatly improved over the OEM 2015 headlights. I swapped bulbs many times trying to get brighter and whiter light to no avail. The output was just terrible and I can't wait to try these out.
  16. Jun 15, 2018 at 1:52 PM
    Pudge
    CT
    I loved the LED strip on my old light but now those don't even compare
  17. Jun 15, 2018 at 1:57 PM
    Pudge
    CT
    If you can't tell...im very happy
  18. Jun 15, 2018 at 2:11 PM
    @Pudge THEY FUCKING LOOK BADASS!!!!
    Erichudgins and Pudge[OP] like this.
  19. Jun 15, 2018 at 2:13 PM
    Pudge
    CT
    Thanks Adam. Pics don't even do it justice.
    You won't regret doing this buddy.
  20. Jun 15, 2018 at 2:20 PM
    Like I said I got the cash already in hand I'm just waiting to see those 2019 TRD Pro headlights
  21. Jun 15, 2018 at 2:24 PM
    Pudge
    CT
    My Guess is they will be black where these are smoked chrome. But a few other features would be cool too
  22. Jun 15, 2018 at 2:28 PM
    Just have to wait and see
    Pudge[QUOTED][OP] likes this.
  23. Jun 15, 2018 at 2:45 PM
    Pudge
    CT
    Patience is a virtue. You're a stronger man than I
  24. Jun 15, 2018 at 2:47 PM
    I kind of want those headlights now
  25. Jun 15, 2018 at 3:02 PM
    Pudge
    CT
    Hahhaa I won't try to tell you no
  26. Jun 15, 2018 at 3:52 PM
    Pudge
    CT
    Sexy. Gave her a nice 2 bucket wash and some ech2o/reload "drying agent"
    iHacker and TXRailRoadBandit73 like this.
  27. Jun 15, 2018 at 4:05 PM
    Damn you!
  28. Jun 15, 2018 at 4:09 PM
    Pudge
    CT
    Remember patience.....
  29. Jun 15, 2018 at 4:10 PM
    I'm coming into San Antonio right now I can stop at Red McCombs Toyota and get them
  30. Jun 15, 2018 at 4:13 PM
    Pudge
    CT
    Umm ummm dont do it!
