2018 LED headlight problems.. need help
Discussion in 'Lighting' started by Why_Yeah, Nov 14, 2017.
  1. Nov 14, 2017 at 3:16 PM
    Why_Yeah
    Why_Yeah [OP] Let's Go Places
    Shawn
    2017 Tundra Platinum
    Just installed my '18 headlights, on a 2017 Platinum, purchased the motocontrol relay, and the pnp harnesses.
    After plugging everything up, I do not have any low beam lamps, nor do the DRL brighten or dim, they stay the same
    I do however have high beams and all park and turn lamps work,
    But if I swap the plugs around on the motocontrol with the pnp harness I can get low beams to come on by their self when I cut high beams on from the truck.
    Thought I blew a fuse but I check and also reinstalled my original headlamp and everything works fiine..
    Any info would be greatly appreciated.. starting to wear my head out
  2. Nov 14, 2017 at 4:19 PM
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    Can you post pics of the harness plugs? I'm wondering if the pins in the harness are in the wrong spots
  3. Nov 14, 2017 at 4:27 PM
    Why_Yeah
    Shawn
    I found the problem, the 25 amp fuse on the motocontrol was blown, everything works as it should now...
    I was about to freak out because this would make the 2nd set of harnesses I purchased, the first set had the wrong plugs in it for the moto, and then this one was giving me problems but finally got it right..
    Thanks!!
  4. Nov 14, 2017 at 5:00 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    I don't know how well your halogen lights lit up the road but I can tell you that those LED lights are great.
  5. Nov 14, 2017 at 5:03 PM
    Why_Yeah
    Shawn
    From what I've seen so far with them, haven't took a trip on them just shined in driveway they are nice... need to upgrade my fog lights now to match..
  6. Nov 14, 2017 at 5:10 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Just get the 2018 LED fog lights......nice and bright as well.
  7. Nov 14, 2017 at 5:13 PM
    Why_Yeah
    Shawn
    Thought about it, might be what I end up doing.. be later though when I save up some more $$ , these headlights broke me...
  8. May 7, 2018 at 8:52 AM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    Say a prayer I finally brought it into toyota to see if they can fix my fog lights and running lights. (Under warranty I hope lol)
  9. May 9, 2018 at 9:02 AM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    What is wrong w ur lights, what happened?
    Toyota isnt going to fix 2018 lamps in a 2016 truck under warranty. Their heads are going to be spinning. They will charge you to put it all back to stock, then trouble shoot it from there.
  10. May 9, 2018 at 9:57 AM
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    I know dealership has the last word and they reserve the right to refuse or not a warranty claim just for a simple reason “The new 2018 LED headlights were never intended or designed to be installed in our older trucks”, no matter which harness you have used, but just a great example @Erichudgins wasn’t so lucky and received a defective headlight, his high beam stopped working like 2 weeks after installation he used a harnesses with dimming and installed the headlights at home by himself, at first we thought it was simply the harness but wasn’t the case we troubleshoot the problem and he found a bad headlights assy. He took the headlight back to dealership for warranty and got a replacement now everything is working again
    Erichudgins likes this.
  11. May 9, 2018 at 10:13 AM
    B737
    Jersey Shore
    i agree ^^ i guess youd just have to prove the part has failed inside its warranty period. (i think is 1 year?)
    id be apt to hand them the box with the headlight inside it and say, i fit this to my 2018 and its broken, please replace. i feel like if you gave them the truck they would have a whole mess of excuses to duck out of support.
  12. May 9, 2018 at 10:39 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I can hear the naysayers now but just spend $60 and get some LasFit LED bulbs for those fogs. One of my best mods to date. I can now actually tell I have the fogs on. Before I went to the LED bulbs I would not even bother to turn them on. My neighbor thought they would be too bright when we actually have fog but they are fine. The beam is directed down so they work good and really light up the road immediately in front of truck.
  13. May 9, 2018 at 10:40 AM
    iHacker
    iHacker SW TRD PRO
    Mario
    Yeah you’re correct headlights have 1 year factory warranty
  14. May 9, 2018 at 12:11 PM
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    That's correct. I mean we have to be realistic in what we expect from a dealer. We do take some risk with the upgrades we choose. But I'm grateful to have been able to get it replaced under warranty. All this 2018 stuff is new. So there are bound to be some bugs to be worked out. Do the correct troubleshooting and follow these guys guidelines to correctly diagnose the issues. @Roman and @iHacker both walked me through the necessary steps to do so. Thanks again guys.
    Roman and iHacker[QUOTED] like this.
