2018 LED Headlight Highbeam Is Out.
Discussion in 'Lighting' started by 619Tundra, Aug 7, 2018.
  1. Aug 7, 2018 at 4:08 PM
    619Tundra
    619Tundra [OP] New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    Just ordered passenger side Headlight Assembly Unit. These are Non-Removable LED Bulbs. Still under 1 yr. Warranty.
    ninjajay likes this.
  2. Aug 7, 2018 at 4:16 PM
    LSUTundra
    LSUTundra New Member
    Wow, I didn't know you could not replace the LED bulbs. Seems like a bad design.
    619Tundra[OP] likes this.
  3. Aug 7, 2018 at 4:16 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    So you gotta replace the entire thing? Yikes. And I don't think toyota extended warranty includes headlights either.
  4. Aug 7, 2018 at 4:18 PM
    619Tundra
    I didn't know that either. Prepare to fork out $320 per light if its past the warranty.
  5. Aug 7, 2018 at 4:19 PM
    LSUTundra
    Was the bulb itself bad? Do you do a lot of night driving? LEDs have incredible lifespans.
  6. Aug 7, 2018 at 4:20 PM
    ninjajay
    Spoolston, TX
    Hell, I might grab a pair of spare 2019 black ones before they move to the next gen tundra, since replacement parts might get more expensive. Alternatively one of the aftermarket companies makes a replacement unit for cheap.
  7. Aug 7, 2018 at 4:28 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Oops, this should be covered under the 1 year/12,000mi warranty did you asked your Toyota parts seller before buying a new housings? My LED housings are almost a year now (September 2017) and luckily everything is working good.
  8. Aug 7, 2018 at 5:42 PM
    yosh2000
    yosh2000 New Member
    Denver
    '17 MGM CM Tundra
    No bulbs are used. They are soldered surface mount LEDs, of course they are not user replaceable and require a headlamp replacement.
    What else did you guys expect? An LED bulb? 12000k?! $50 on egay?! Ha
    SR5SE and B737 like this.
  9. Aug 7, 2018 at 5:43 PM
    yosh2000
    yosh2000 New Member
    Denver
    '17 MGM CM Tundra
    Soldered Surface mount LEDs, it's an excellent design. Not sure why you think it's bad?
  10. Aug 7, 2018 at 6:06 PM
    LSUTundra
    Having to replace a $320 housing vs a LED bulb sounds bad to me. The design may be great, I'm not an engineer. I'm looking it as a wearable item that will have to be replaced.
    BuckWallace likes this.
  11. Aug 7, 2018 at 6:08 PM
    yosh2000
    yosh2000 New Member
    Denver
    '17 MGM CM Tundra
    I'm actually an engineer, smd is a better design than a bulb.
  12. Aug 7, 2018 at 6:10 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    The LED boards are replaceable but this involves opening your headlight housings to replace it and this isn’t so easy to do for the end user.
  13. Aug 7, 2018 at 6:13 PM
    yosh2000
    yosh2000 New Member
    Denver
    '17 MGM CM Tundra
    I can't imagine Toyota would sell just the board either.
    But now you got me thinking...a diode Dynamics upgraded board....or even better, an iHacker upgraded board with 1.5-2 times the output!!!! Haha! I dig the look of the lights, juts wish they had just a bit more output.
    SouthBoundSteve likes this.
  14. Aug 7, 2018 at 6:28 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    Hahahahaha I don’t think Toyota would ever offer replacement boards to consumers but yeah Diode Dynamics should come up with something in the future, if you have the right tools and the guts to open your headlights this LED boards could be modified with something better, I’m not doing this because I want a perfect seal in my headlights that’s why I didn’t liked my retros
    SR5SE and Pudge like this.
  15. Aug 7, 2018 at 6:51 PM
    TheBeast The Beach
    damn...halogen bulbs for the win :D
  16. Aug 7, 2018 at 7:09 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I assume this will be an isolated thing.
    Toyota would have a lot of unhappy customers if they have to replace entire headlight assemblies every few years.
  17. Aug 7, 2018 at 7:30 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    Yeah I only heard 2 cases like this Roman replaced the faulty housing to the other guy with this problem
    MotoTundra[QUOTED] likes this.
  18. Aug 7, 2018 at 8:27 PM
    619Tundra
    I took my truck in for 25k service at Escondildo Toyota. They performed the multi-point truck inspection and notified me the passenger side high beam was not working. They weren't sure if the warranty was void because these units where exclusively designed for 2018 trucks.
  19. Aug 7, 2018 at 8:31 PM
    619Tundra
    I don't do much night driving, I don't off-road (yet), I bought these lights in November of 2017 and installed them with @iHacker s harness.
  20. Aug 7, 2018 at 9:19 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    so did they replace it under warranty? you sure its the headlamps and not faulty wiring/harness? it could be a pin that has gone lose or bad.
  21. Aug 7, 2018 at 9:43 PM
    619Tundra
    Yes they ordered me a new light under warranty. I still don't know if the wiring his faulty, but it was working fine before.
    BlueBottle likes this.
  22. Aug 7, 2018 at 10:12 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    good luck and keep us updated. my 1 year is up soon on my '18 leds, hope they don't fail on me.
    dcsleeper408 and Pudge like this.
  23. Aug 7, 2018 at 10:57 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    In November last year we still used the Motocontrol so be sure to check there too, you can swap housings to be sure isn’t a harness issue, we did this troubleshoot with the other guy with faulty headlight and definitely wasn’t a harness issue so he requested a replacement under Toyota warranty.
    Keep us updated and if this is a harness issue send me a PM.
    619Tundra[QUOTED][OP] and B737 like this.
  24. Aug 9, 2018 at 9:01 PM
    619Tundra
    Will do Saturday. Thanks.
  25. Aug 16, 2018 at 4:07 PM
    619Tundra
    Ok guys the High Beam harness plug was inverted. Sorry for the delay. I use my rig for my daily work, and didn't have time to check it until now.
    MotoTundra, Pudge and landphil like this.
  26. Aug 16, 2018 at 4:09 PM
    619Tundra
    I never checked it myself after installing them. I had my helper tell me it worked when I flashed the high beams from inside the cabin with the hood up.
  27. Aug 16, 2018 at 4:11 PM
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    Mine did the same thing. Passenger side high beam went out. Maybe a flaw design.
  28. Aug 16, 2018 at 4:12 PM
    619Tundra
    Check the plug first, it might be inverted.
  29. Aug 16, 2018 at 4:35 PM
    yosh2000
    yosh2000 New Member
    Denver
    '17 MGM CM Tundra
    After all these guys saying LEDs are bad, glad I have halogen bulbs, blah, blah, blah, it ends up being the AFTERMARKET parts fault...
    Glad it worked out OP. Just rember guys, when modding a vehicle, always place your bets against the AFTERMARKET part installed, rather than the OEM part!
    619Tundra[QUOTED][OP] likes this.
  30. Aug 16, 2018 at 4:36 PM
    Erichudgins
    Eric
    Murfreesboro, TN
    Nah it was the light. I actually swapped sides and the high beam worked. Replaced light under warranty and never another issue.
