2018 LED Fog Light Installation Instructions w/Pics
Discussion in '2.5 Gen Tundras (2014-2021)' started by BayRunner, Nov 11, 2017.
  1. Aug 3, 2020 at 6:31 PM
    #91
    brobert225
    brobert225 Firm grasp of the obvious
    Very nice. Thanks for posting “how to”
  2. Aug 10, 2020 at 9:54 AM
    #92
    infamousavi
    infamousavi New Member
    great write up!
  3. Sep 23, 2020 at 10:55 AM
    #93
    infamousavi
    Just completed this! It’s as easy as it looks
  4. Jan 4, 2021 at 11:00 AM
    #94
    TrexTundra
    TrexTundra Live Free or Die Tryin
    Trevor
    Idaho
    2017 Black Tundra Platinum
    **Work in progress** 3/1 Procomp Nitro leveling kit 285/70/18 Nitto Ridge Grapplers 18x9 Black Fuel Vapors +1 offset Led Headlight/fog lights Will be removing chrome and Plastidip black
    Thank you so much for putting your time into all this! Looking to do this exact same thing to my 2017 Platinum. Will follow and let you know how it goes. Thank you!
  5. Apr 7, 2021 at 2:02 PM
    #95
    CarPro
    CarPro New Member
    2017 Sequoia SR5
    great Job. Do you think these parts will fit in 2017 sequoia SR5?
  6. Apr 28, 2021 at 4:56 AM
    #96
    Kevin80
    Kevin80 New Member
    2016 SR5 Crewmax
    Has anyone noticed that the new LED fogs don’t seem to fit as “flush” to the bezel?
    I will try to take a picture but I’m not sure it will work... anyway, there’s not much to putting the light into the bezel (there’s 2 tabs that slide into slots and the one screw), unless I am completely missing something?!?!?
  7. Jun 3, 2021 at 1:26 PM
    #97
    Beerhen
    Beerhen New Member
    sean
    Oceanside, CA
    2018 Tundra TRD Sport 4x4
    2.5 Coil-over IFP Shocks, Firestone Ride-Rite bags, 2.0 Smooth Body IFP shock, BF Goodrich KO2, 17' Method Wheels
    Anyone’s housings loose?? Are they supposed to be really tight against the bumper??
  8. Jun 3, 2021 at 3:26 PM
    #98
    Beerhen
    Beerhen New Member
    sean
    Oceanside, CA
    ok great! I thought I was gonna be the only one doing that. Odd that Toyota made them that way. I pulled them out to inspect them to see if there was something un-clipped but nothing. I’ve also noticed that the fog lens shakes a bit inside the fog housing. Considering getting into some aftermarket fogs so that’ll cure that
  9. Jul 16, 2021 at 6:45 PM
    #99
    Dawg7113
    Dawg7113 New Member
    Ryann
    2019 TRD Sport 4x4
    Are your lens glass or plastic?
  10. Sep 21, 2021 at 11:25 AM
    #100
    tja1080
    tja1080 New Member
    TJ
    Whidbey Island WA
    2016 Platinum
    Anyone have issues with morimoto led fogs repeatedly blowing fuses?
  11. Sep 22, 2021 at 6:48 AM
    #101
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    That’s a circuitry issue. Not an amp draw issue. Most likely a short somewhere either in the factory wiring or internally of the fog light.
    tja1080[QUOTED] likes this.
  12. Oct 25, 2021 at 5:35 PM
    #102
    Nickatnight
    Nickatnight New Member
    Nick
    98445
    2021 1794 Tundra
    Rhino running boards, Amber running lights, Underhood automatic LED Lighting, OEM Fender Flares, Tech12 Volt New Killer Audio System with factory Head Unit.
    Hi folks, I was using my test light on the fog light connector and apparently I blew the fuse. I just donʻt see the fuse anywhere to replace it. Can you help its a 2021 Crewmax. Thanks
  13. Nov 12, 2021 at 4:19 PM
    #103
    FoxSR5
    FoxSR5 New Member
    I was removing the inner liner to install the OEM Fog lights and broke the clip that holds the liner to the frame. I found this part number 90467-07201. Can anyone confirm if this is the correct part number for this clip?
  14. Nov 12, 2021 at 5:12 PM
    #104
    FoxSR5
    FoxSR5 New Member
    Thanks for confirming ...appreciate it
  15. Feb 5, 2023 at 6:56 AM
    #105
    sonofdad
    sonofdad New Member
    steamboat springs, co
    2017 Tundra SR5
    used this to upgrade my stock sr5 fog lights to diode dynamics ss3 yesterday. thanks @BayRunner for the how-to ... really appreciate it :thumbsup:
  16. Feb 5, 2023 at 9:18 AM
    #106
    BayRunner
    BayRunner [OP] I’m here, except when I’m not
    2017 Tundra Platinum
    You bet, glad it was useful.
  17. Jun 22, 2023 at 3:31 PM
    #107
    dofu
    dofu New Member
    Dave
    San Jose, CA
    2015 White Tundra Crewmax SR5
    Very nice job with your detailed instructions and pictures!
