2018 Headlight upgrade With LED Turn Signals
Discussion in 'Lighting' started by Tundra4us, Dec 18, 2017.
  1. Dec 18, 2017 at 9:22 PM
    Tundra4us
    Tundra4us [OP] New Member
    "D"
    So for the people who have upgraded to 2018 lights has anyone added LED turn signals? If so, please share the part number and brand. I tried to install mine from 2016 retros and they did not fit the socket of 2018's. I had the GTR from Headlight Revolution and the bulbs base would not fit down into the socket.
  2. Jun 13, 2018 at 2:29 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I'm interested in this as well.
    The bulb number is 7444NA amber.
    I believe 7443 will also fit.
    I think with most LED bulbs I'll need a resistor to prevent hyperflash. My curiosity is if the blinker light is also a DRL in addition to the LED strip DRLs. Which would open the door for some switchbacks.
    I'll be installing my 18 headlights this weekend (with an @iHacker harness) and would like to upgrade to all LED bulbs if its not too difficult or expensive.
    Has anyone done this project yet?
  3. Jun 13, 2018 at 2:55 PM
    Someone on here did this, they put Sylvania led bulbs, forgot who though
    Pudge likes this.
  4. Jun 13, 2018 at 2:57 PM
    They put these on
    Cause I remember seeing the close up shot of them inside
    Pudge likes this.
  5. Jun 13, 2018 at 3:32 PM
    Azblue
    The Dirty T ( ^_^)_且
    I used Profile bulbs from The Retrofit Source .I already had 3 ohm Vled resistors behind the tail lights for my previous switchback fronts and LED rear turns. They work great so far .
  6. Jun 14, 2018 at 6:26 PM
    Tundra4us
    "D"
    Hey Pudge, I ended up going with Vleds, Triton V6 bulbs. Don't waste your time with the cheap route. you will regret it....
    Tundyfundy and Pudge[QUOTED] like this.
  7. Jun 14, 2018 at 7:43 PM
    Pudge
    CT
    Thanks D. I'll stick with halogen for now but I'm sure it'll drive me nuts and I'll end up going the VLed route at some point. No need for resistor with those?
    Erichudgins likes this.
  8. Jun 15, 2018 at 10:15 AM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
  9. Jun 16, 2018 at 7:43 AM
    Tundra4us
    "D"
    Yes, you need the resistors. Triton V6 is all plug-in, no splicing.
    Tundyfundy likes this.
  10. May 6, 2020 at 11:51 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Just ordered the Tritons for my 2018 headlights. Any tips?
  11. May 6, 2020 at 12:08 PM
    Daxoto
    Daxoto New Member
    2020 PRO
    These are what I put in mine. They work really good compared to the halogens. No resistors needed.
  12. May 6, 2020 at 6:09 PM
    Tundyfundy
    Bay Area, CA
    99046249-5632-464A-95B9-04C945BB409E.jpg D1502936-104A-4B56-B93A-C76085E411D6.jpg
    Installed my V6 Tritons today. What a quality product. Vled knocks it out of the park every time!
    primeiro and Turtle like this.
  13. May 6, 2020 at 6:38 PM
    Turtle
    Turtle New Member
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    Aries Side Bars, DeeZee low profile tool box, weathertech mats, TRD RSB
    Agreed, have VLED on nearly all outer truck lights, recently did the cargo and 3rd brake light after waiting for the cargo with no interference with Key fob. Quality product, without a doubt. Worth the money. Thrilled beyond belief.
  14. May 7, 2020 at 7:33 AM
    primeiro
    primeiro New Member
    Henk
    Netherlands
    thnx for the pic , i have orderd them also
  15. May 7, 2020 at 10:58 AM
    Tundyfundy
    Bay Area, CA
    No problem! FYI in the video the left one is VLED and the right one is stock halogen.
