2018 headlight conversion
Discussion in 'Lighting' started by sargebt, Sep 1, 2018.
  1. Sep 1, 2018 at 4:29 PM
    sargebt
    sargebt [OP] New Member
    Brandon
    2016 Platinum Tundra
    7 inch BDS, running 35’s
    Hey gang. Just changed my headlights out for a set of 2018s. Now my blinkers are hyper blinking. Any idea why? Harness was plug and play
    Thanks
    Y0TA PR0 likes this.
  2. Sep 1, 2018 at 4:35 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    What harness did you get?
  3. Sep 1, 2018 at 4:40 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Ihacker harness?
    Do you have LED taillight blinker? Did you put
    LED blinker bulbs in headlights?
    NewImprovedRon likes this.
  4. Sep 1, 2018 at 6:41 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    Did you swap the running light and blinker pins in the harness? The 18 LEDs use a 7443 blinker, the pins are swapped from the 3157 wirimg.
  5. Sep 3, 2018 at 6:09 PM
    sargebt
    Brandon
    I’ll have to ask all of these questions. I have an led tail light bar. But didn’t change any bulbs in my tail lights. Do I need to put led blinker bulbs in the heads?
  6. Sep 3, 2018 at 8:28 PM
    Cuzican
    Cuzican New Member
    Louisiana
    The bar, I'm assuming you mean like a line of fire under the tailgate, won't have any effect on the blinkers. If you put LED bulbs in the front, they will require load resistors.
    I don't know what harness you have, but if it's not ihacker's, the front blinkers do plug in, but the wiring is wrong as the pins in the socket swap locations. iHacker's harness comes with a set of plug in adapters to swap the wiring, so you don't have to de-pin and re-pin the blinker harness, they prevent the blinkers from hyper-flashing. Contact @iHacker, he can get you straight on what you need.
