2018 Crewmax SR5 - Need Suggestions
Discussion in 'Audio & Video' started by Riskyguy, Feb 29, 2020.
  1. Feb 29, 2020 at 6:30 AM
    Riskyguy
    Riskyguy [OP] New Member
    Stewart
    2018 Tundra SR5 Crewcab
    I just traded in my 08 for this truck which has the non-JBL system in it. I modded my 08 with a new HU, speakers, 5 channel amp and sub aand it sounded great.
    My wife will kill me if I spend much money on a new sound system right now, so I need some sage advice on what I can do to improve the sound. Can I stick with the existing HU or is that stupid? I would like to get some bass but not bone shaking amount. I willl likely do the install myself.
    Any suggestions will be greatly appreciated.
  2. Feb 29, 2020 at 7:26 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I have a 2016 with the non JBL system. I set the bass to full and it has helped quite a bit. Don't be afraid to up the volume, even at full power it will not distort. It sounds ok with where I have the settings and at higher volume.
    Our stereos don't have much power, I would guess probably 1/2 as much as aftermarket systems or premium stock systems in other trucks/cars. You could add an amp, woofer and such to your stock system but I think just changing the head unit would be cheaper and give much better sound than adding to the stock system. It would also enable you to get android auto and other apps.
    For comparison, I changed just the head unit in my 2006 4 runner and it was like I installed a full system with speakers, woofer, etc. It was a night and day different. The 4runner system sounds so much better than my 10 years newer Tundra.
    Out stereo systems pretty much suck. Cost effective and better performance option is to swap the head unit vs. putting lipstick on a pig.
  3. Feb 29, 2020 at 7:27 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Head units are a weak point so I’d start there replace it first.
  4. Feb 29, 2020 at 8:11 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    I have a 2016 SR5 non JBL unit.
    Not counting the amp rack, just sub, 5 channel amp and LC7i i have less than 500 in mine.
    Crutchfield scratch and dent amp kenwood
    801.5 ($180.00) and AudioControl LC7i - new ebay ($124.00). Used sub locally Facebook Marketplace. Rockford Fosgate R2S-1X12($50.00)
