2018 constant hot rear bumper?
Discussion in 'Lighting' started by Baja1000, Feb 11, 2019.
  1. Feb 11, 2019 at 9:33 AM
    Baja1000
    Baja1000 [OP] New Member
    Andy
    SOCAL
    2018 TRD 4X4 Cement CM
    Installing LED’s in the truck bed. Does anybody know where a constant hot wire is along the rear bumper without turning on the ignition?
    Thanks a ton!!!
  2. Feb 11, 2019 at 9:35 AM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
  3. Feb 11, 2019 at 9:51 AM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    My first thought was the 12v in your trailer wiring, but a quick google search shows it’s keyed. You may have to run into the cab (driver side) and use the wiring under the kickplate, it’s not that far....
  4. Feb 11, 2019 at 9:59 AM
    Baja1000
    Andy
    SOCAL
    the plate as you enter the drivers side?
  5. Feb 11, 2019 at 10:17 AM
    Jrharvey02
    Yup, big bundle of wires under there. sorry can’t be more help beyond this as I’ve got a 2nd gen, but somebody on here should know of a constant hot in that area...
  6. Feb 11, 2019 at 10:25 AM
    Jrharvey02
    You could also use one of these “add a circuits” to your fuse panel near your left knee when driving. Again, not sure if/what is constant hot in your 3rd gen but something may be. These are cool cause you don’t have to cut anything, you need this specific “low profile mini fuse” for our tundras....must say “low profile”...can’t stress that enough
    ABN Fuse Tap Fuse Holder & Fuse 5-Pack – 12V Add a Circuit Kit – ATM Low Profile Mini Fuse Blade & 15A AMP Adapter https://www.amazon.com/dp/B01BU59QA8/ref=cm_sw_r_cp_api_i_g0ByCbGC43VR9
  7. Feb 11, 2019 at 10:45 AM
    Jrharvey02
  8. Feb 12, 2019 at 6:12 AM
    Baja1000
    Andy
    SOCAL
    All finished! Routed a wire up the drivers side frame to the battery. Super easy. Thanks for all your help. This is the best forum ever!
  9. Feb 13, 2019 at 7:16 AM
    Baja1000
    Andy
    SOCAL
    Jrharvey02 likes this.
  10. Feb 13, 2019 at 7:31 AM
    Jrharvey02
    Bed lights were my first project after stumbling onto this site 6 months ago, too. That was just the beginning...next was switching most of the 12v outlets to USB within cab. Then the anytime fog light mod (Eddies Mod) followed by Baja Designs Squadron Sport fog lights (wide cornering, amber lense) and switching interior lights to led. This site is awesome, good luck
