2018 Bed Lights w/o factory harness.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Linuxmale, Feb 23, 2020.
  1. Feb 23, 2020 at 7:03 AM
    Linuxmale
    Linuxmale [OP] 2018 Tundra 2003 Tj
    Sault Sainte Marie, MI
    2018 CREWMAX TRD Off Road ( a Canadian import )
    I bought some LEDS and had planned to wire them to the factory harness on the rear drivers side look. Then I found out that in the 2018 that doesn’t work. So I tapped into the places outlined in the factory install directions. One has constant 12volt and one changes based on the overhead lights. So my question is, does the factory LED harness have a relay or something in it?
  2. Feb 23, 2020 at 7:59 AM
    Linuxmale
    I tried that but this is a 208 and apparently that doesn’t work in 208 and later.
  3. Feb 23, 2020 at 7:59 AM
    Linuxmale
    Oops 2018 and later I meant.
  4. Feb 23, 2020 at 4:59 PM
    Linuxmale
    I was trying this and gave up in frustration, but it turns out the multimeter I was using had a part time bad lead. I started to wonder and realized it was bad when the continuity test read zilch. I’ll try again.
  5. Feb 24, 2020 at 11:56 AM
    7.62X51
    7.62X51 New Member
    Virginia Beach
    I have an 18 and I tapped into the wire under the scuff plate. Mine works fine.
  6. Feb 24, 2020 at 12:18 PM
    Linuxmale
    I'm going to try again tonight.. any chance you remember the color? I think it may be a light blue.
  7. Feb 24, 2020 at 12:19 PM
    7.62X51
    7.62X51 New Member
    Virginia Beach
    Gimme about two hours and I will take a pic and post it here.
    NewImprovedRon likes this.
  8. Feb 24, 2020 at 12:25 PM
    Linuxmale
    That would be great!
  9. Feb 24, 2020 at 1:30 PM
    I thought somebody posted it was the thick pink wire, supposedly there are 3 pink wires.
  10. Feb 24, 2020 at 1:45 PM
    7.62X51
    7.62X51 New Member
    Virginia Beach
    It's a pink wire. There are red ones in there as wel . Make sure you get the pink one
  11. Feb 24, 2020 at 1:52 PM
    55kcement
    55kcement New Member
    Troy
    Sonora ca
    2020 TRD Off Road limited Double cab
    Currently none
    Do you have a email , I have the pdf for installing these lights that I think is the same for 2018 .
  12. Feb 24, 2020 at 2:10 PM
    55kcement
    Troy
    Sonora ca
    Currently none
    I’m trying this not sure it will work
    GlobalGuy likes this.
  13. Feb 24, 2020 at 2:12 PM
    55kcement
    Troy
    Sonora ca
    Currently none
    Those are the bed lighting install instructions from Toyota for 2019-2020 tundra’s !
  14. Feb 24, 2020 at 4:04 PM
    Linuxmale
    Thanks for everything guys. I had the 2018 install guide that goes to the front but it didn’t seem like mine was turning off with the doors. I’m going to go take a look now.
  15. Feb 24, 2020 at 5:57 PM
    Linuxmale
    I got the 12volts from the pink wire under the scuff plate! Part of the problem is that one of the fancy expensive taps I was trying was designed for a larger gauge. When I used the clamp type that come with trailer wiring kits it worked. Thanks again all. I’ll post a pic when I’m completely done!
  16. Mar 3, 2020 at 2:31 AM
    55kcement
    Troy
    Sonora ca
    Currently none
    Hey that pink wire is triggered on with the cargo light , they didn’t switch it with a ground and a relay ?? So you just tapped into the power and just found a clean spot for your ground under the outside of the truck ? Is there a good weather proof spot to get your power wire in side ?
  17. Mar 3, 2020 at 6:11 AM
    7.62X51
    7.62X51 New Member
    Virginia Beach
    If you have the bed rail system on your truck, I used one of those screws and everything works perfect.
  18. Mar 3, 2020 at 10:57 AM
    Linuxmale
    To everyone who posted on this thread thank you. Finally got a chance to finish.
    I did the puddle lights too, might change these to strips at some point.
    https://youtu.be/qQFEwf11eQE
    Ostrich, Joss1799 and NewImprovedRon like this.
  19. Mar 3, 2020 at 1:25 PM
    55kcement
    Troy
    Sonora ca
    Currently none
    I do but I’m getting a spray in bed liner on Saturday , I’m guessing it won’t ground through that figured I would just find a spot to ground my light under the bed or cab ! Still waiting for the parts to make my kit !
  20. May 26, 2020 at 7:23 PM
    drewgreg
    drewgreg New Member
    Drew
    Huntington Beach, CA
    2014 Tundra Crewmax Limited 4x4
    3/1.5 Toytec Boss Aluma w/ rear shackles and total chaos UCAs 18x9 Pro Comp rims w/ 295/70R18 Nitto Ridge Grapplers Westin Outlaw Front & Rear Bumpers with Fogs, light bar, and skid plate Dirty Deeds 10" BAMuffler Stainless Steel Standard System Tri-Fold Tonneau Cover TRD Rear Sway Bar Side Steps Ditch lights Bedside Molle Panel Pop & Lock LED Bed Lights K&N Air Filter Blacked Out Emblems Dash cam Tint
    I’m trying to wire bed lights to the driver side wire loom under the scuff plate and tap into the cargo light wiring and I am having a hell of a time. Everything I have read says to run the wire from under the truck up through a rubber grommet that pops out at the wiring under the scuff plate. All the rubber grommets I am seeing from under the truck don’t come out where they should. Looks like they come out under the metal plate that the wire loom is connected to so I can’t access them. I have seen the OEM bed light instruction PDF that says to run them through the passenger side into the footwell then over to the driver side but everyone says they just popped them through the grommets on the driver side. I am going crazy! Anyone got any tips or pointers???
  21. May 29, 2020 at 7:44 AM
    drewgreg
    drewgreg New Member
    Drew
    Awesome thank you Ron! I will give that a go!
  22. Jun 4, 2020 at 4:51 PM
    drewgreg
    drewgreg New Member
    Drew
    So I ended up running them to the passenger side due to also getting a pop n lock. I got everything into the passenger scuff plate and got the pop n lock hooked up and working but can’t seem to find the wire for the cargo lights. Is there a cargo light wire on the passenger side as well? Or is it only on the driver side??
  23. Jun 4, 2020 at 7:16 PM
    biebs96
    PA
    If you tap the puddle lights into the footwell light circuit they will fade in and out rather then abruptly turning off. Also illuminate when the vehicle is shut off.
    https://youtu.be/Q5VmAUuNGnE
    MaxMB likes this.
