2018 4.6L Oil Filter Housing Leak?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Torgo, Mar 7, 2023.
  1. Mar 7, 2023 at 3:56 PM
    Torgo
    Torgo [OP] New Member
    I'm in the process of purchasing a one owner 2018 SR5 2WD 4.6L with 82,000 mi. which CarFax says was serviced regularly. I noticed a drop of oil on the filter housing and questioned the seller since they told me they made an oil change. After a couple of days, they said that this type of oil leak is common for these engines and will put on a Toyota recommended fix. I Googled and couldn't find any oil housing issue. I would appreciate any guidance!
  2. Mar 7, 2023 at 4:14 PM
    I have never heard of that. Is it the black plastic housing? Many of us switch to the aluminum.
    Torgo[QUOTED][OP] likes this.
  3. Mar 7, 2023 at 4:46 PM
    Torgo
    As I am new to the gen 2.5, all I can say is that the drop I observed was on the aluminum(?) plug in the bottom of the black (material?) housing.
  4. Mar 7, 2023 at 4:53 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    Make sure it’s torqued correctly. It could be over torqued which will also cause it to leak. The o-rings come with the filter cartridge so maybe replace it for peace of mind.
  5. Mar 7, 2023 at 4:54 PM
    Rocko9999
    Rocko9999 New Member
    Any leaks from the timing cover? Those are the most common.
    Torgo[OP] likes this.
  6. Mar 7, 2023 at 5:01 PM
    Torgo
    I don't know how to respond individually, but Dalandshark : yes I don't know what they did.
    Rocko9999 I didn't look specifically but the front of the engine looked clean.
    Rocko9999 likes this.
  7. Mar 7, 2023 at 7:18 PM
    Yep that is the filter drain. As mentioned, replace the o-ring on it and don't overtorque it. You will only get a few drops of oil when you remove that plug.
  8. Mar 7, 2023 at 7:20 PM
    To respond individually (called a tag) , you just put the @ symbol in front of the username that you are directing your reply to. For example I'll tag you @Torgo
  9. Mar 8, 2023 at 1:01 AM
    Torgo
    Thanks for the guidance. On my first oil change I'll inspect the housing and drain plug and replace/upgrade as necessary.
  10. Mar 8, 2023 at 7:22 AM
    ekw_92
    ekw_92 New Member
    Wisconsin
    2017 Super White Tundra 1794 TRD offroad CM
    2017 Tundra 1974 CM - Bilstein 6112/5100 1.9 with CB 2/1 shims. CB +2 shackles. 17x8.5 RRW wheels, 315/70/17
    Make sure to install the large o-ring on the correct spot (seen it before) and use oil to lube both o-rings before installing as they can catch and tear causing it to leak and can make the next removal difficult if not done.
    Torgo[OP] and Rocko9999 like this.
  11. Mar 14, 2023 at 3:40 PM
    WhistlingPete72
    WhistlingPete72 New Member
    2017 Toyota Tundra SR5 CREWMAX
    I also have a 2017 tundra 4.6l v8 that I purchased used and it was leaking on plug at bottom of black plastic housing... I replaced with the Toyota aluminum oil filter housing with part # 15620-31060 and no more leaks it works great. Congrats on new tundra best wishes
