2017 upper ball joints/UCA’S
Discussion in 'Suspension' started by Upstate tundra, May 2, 2018.
  1. May 2, 2018 at 4:07 PM
    Upstate tundra
    Upstate tundra [OP] New Member
    2017 crewmax
    Rough country 3/1 leveling kit
    I’m new to forum and have a question. I have a rough country 3/1 leveling kit installed on my 2017 crewmax. Both my upper ball joints went bad at 27k. So that meant new UCA’s. I was told by dealer the leveling kit was the reason for failure and not covering them. I have a hard time believing this as I had a Zone 3/1 leveling kit in my 2011 and never had any issues and traded it at 80k. I am now considering removing 1 or both the 1/4” shims to lower the front some to maybe help with not replacing UCA every 27k. Thoughts??
  2. May 2, 2018 at 4:50 PM
    Welcome from Texas
  3. May 2, 2018 at 4:56 PM
    Welcome from CO! Pretty unusual for both oem ball joints to fail prematurely like that with a 3/1 lift.
    TXRailRoadBandit73 likes this.
  4. May 2, 2018 at 5:01 PM
    Ac91
    Ac91 New Member
    Dallas
    2018 Tundra SR5
    Same thing my dealer told me if I did a lift it would void my suspension warranty and they would not cover any issues related to suspension. If they are denying your claim they will probably not change their mind might as well just buy UCA’s.
    Black Wolf likes this.
  5. May 2, 2018 at 5:07 PM
    Upstate tundra
    2017 crewmax
    Already put new UCAs on. Two dealerships said they have never had any issues like that before and there are plenty on tundras around me with same kits. Just wondering if I remove one or both shims to lower the front some if that would help with the ball joints? Or just leave it as is and hope the new ball joints hold up
  6. May 2, 2018 at 5:07 PM
    Ac91
    Ac91 New Member
    Dallas
    2018 Tundra SR5
    Did you replace it with a oem UCA or aftermarket?
  7. May 2, 2018 at 5:08 PM
    Upstate tundra
    2017 crewmax
    Aftermarket
  8. May 2, 2018 at 5:10 PM
    Upstate tundra
    2017 crewmax
    This truck is pretty much a daily driver and minimal off road which only consists of decent farm roads and through occasional cut corn fields. Nothing serious.
  9. May 2, 2018 at 5:12 PM
    Ac91
    Ac91 New Member
    Dallas
    2018 Tundra SR5
    That is definitely strange I have never seen that happen with aftermarket UCA’s especially with just a 3/1 lift
  10. May 2, 2018 at 5:13 PM
    Stroke250
    Stroke250 New Member
    Todd
    Idaho
    2023 Ford F-350
    Which aftermarket UCAs did you use?!
  11. May 2, 2018 at 5:14 PM
    Upstate tundra
    2017 crewmax
    My thoughts exactly. But had a friend at a different garage look at them and confirmed both were bad. Can’t figure this one out especially since nobody else having the problem
  12. May 2, 2018 at 5:15 PM
    Upstate tundra
    2017 crewmax
    I can’t remember the brand, maybe acdelco. Just a oem replacement and not the cheapest ones they had
  13. May 2, 2018 at 5:16 PM
    Ac91
    Ac91 New Member
    Dallas
    2018 Tundra SR5
    That’s your problem you need UCA’s that are adjustable not just oem replacements
    Stroke250 likes this.
  14. May 2, 2018 at 5:16 PM
    Upstate tundra
    2017 crewmax
    My aftermarket ones haven’t failed yet it was oem ones.
  15. May 2, 2018 at 5:18 PM
    Ac91
    Ac91 New Member
    Dallas
    2018 Tundra SR5
    You replaced them with a oem replacement I might be wrong but acdelco is not adjustable like total chaos, jba, Icon or spc
  16. May 2, 2018 at 5:19 PM
    Upstate tundra
    2017 crewmax
    I’m thinking of pulling out the two 1/4” shims to drop the front 1/2” or so to maybe help
  17. May 2, 2018 at 5:19 PM
    Stroke250
    Todd
    Idaho
    2023 Ford F-350
    Buy some SPC adjustable UCAs from @Toytec Lifts and be done.
    Ac91 and T-Rex266 like this.
  18. May 2, 2018 at 5:20 PM
    Upstate tundra
    2017 crewmax
    Definitely not adjustable
  19. May 2, 2018 at 5:21 PM
    Ac91
    Ac91 New Member
    Dallas
    2018 Tundra SR5
    If that is the case those will probably just fail like your oem ones did from what I have read adjustable UCA’s are recommended for 3” lift but considering your oem joints failed you might look into adjustable ones
  20. May 2, 2018 at 5:22 PM
    Upstate tundra
    2017 crewmax
    Just can’t understand them failing so quick when there are lots around with same kit and no issues. 4 in my parking lot at work 3 of which have same kits and way more miles.
  21. May 2, 2018 at 5:23 PM
    Upstate tundra
    2017 crewmax
    You think making it a 2.5” lift in front would make much difference?
  22. May 2, 2018 at 5:23 PM
    Ac91
    Ac91 New Member
    Dallas
    2018 Tundra SR5
    From what I have read and been told on this forum it’s hit or miss with oem UCA’s and a lift it will be fine or it will fail like yours did.
  23. May 2, 2018 at 5:26 PM
    Upstate tundra
    2017 crewmax
    Shoulda just bought a TRD pro and not have to worry about this stuff!
