2017 Tundra Wipers
Discussion in '2.5 Gen Tundras (2014-2021)' started by slongo, Jan 9, 2021.
  1. Jan 9, 2021 at 4:19 AM
    slongo
    slongo [OP] New Member
    2017 Tundra in Barcelona red
    Side Steps - bed cover - matte black splash graphics
    Is there any way to adjust the Drivers side Wiper ? It seems to have slipped down when off and lays down on the plastic and not on the windshield anymore - And then when they are on it no longer makes a full swipe
  2. Jan 9, 2021 at 4:30 AM
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    Take it off and reinstall and see that would fix it. I don't think they are adjustable.
  3. Jan 9, 2021 at 4:39 AM
  4. Jan 9, 2021 at 7:26 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    Unless the whole assembly was removed it shouldn't have slipped. Could it have been damaged somehow?
    Squatting Pigeon likes this.
  5. Jan 9, 2021 at 7:28 AM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    It would be a stretch to think the arm jumped a tooth (or 6), but I guess it’s possible if the splines stripped somehow. Interesting :monocle:
    OP I’d definitely take that arm off and take a look at the splines.
    Trooper2[QUOTED] likes this.
  6. Jan 16, 2021 at 7:20 AM
    slongo
    So finally got around to pulling the wiper arm and yes it slipped 1 spline somehow - No damage to the splines - they are adjustable - not really sure how it slipped as the nut was tight but installed some new wiper blades and adjusted the drivers side arm and I am good to go !
    WILLINH, WFD473 and AZBoatHauler like this.
  7. Jan 16, 2021 at 7:56 AM
    Kung
    KG, VA
    Huh. Ya learn something every day....I didn't even know this was possible. Neat!
  8. Jan 17, 2021 at 4:20 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    The new ones off the part shelf have a smooth conical taper in the aluminum arm. It makes the spline imprint when it's tightened against the harder steel. In case you lay awake at night wondering if you need to order a new one.
    I think they aren't tightened super tight from the factory so that interface is the failure point if the blades freeze down to the windshield. Mine did the same thing when I forgot to shut the wipers off before shutting down the truck in the dead of winter. Thought I stripped it until the parts guy showed me the new one really has nothing to strip. Original arms still working well, although I snugged them up a touch more.
    Trooper2 likes this.
  9. May 26, 2021 at 12:48 PM
    KWC
    KWC New Member
    Conroe, Tx.
    2017 Toyota Tundra
    6112's, 5160 + 1
    How or what did you use to remove those wiper arms? It's pretty difficult. I have a mouse problem and would like to remove that cowling to mouse proof that air intake opening. Thank you.
  10. May 26, 2021 at 12:55 PM
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
    Did you watch this? Guy doesn't talk much..
    https://www.bing.com/videos/search?...3887101449FF32838E97388&view=detail&FORM=VIRE
    He uses a puller, but i was taught a trick. First remove the nut, raise the wiper arm, then with the palm of your hand or a rubber mallet bump the wiper arm right next to the mount. This will break it free.
  11. May 26, 2021 at 1:33 PM
    KWC
    KWC New Member
    Conroe, Tx.
    2017 Toyota Tundra
    6112's, 5160 + 1
    That was pretty good. Thanks very much for sharing. I'll pop the hood tomorrow and try again.
    Do you think the only areas the mice are gaining access to under the cowling, is on each ends by the the hood arms?
    After not being able to remove the wipers today, I stuffed those corners by the hood arms with steel wool in attempt to block that space.
    Again, thanks very much.
  12. May 26, 2021 at 1:46 PM
    3rdTundra
    Central Texas
    Sorry, I have not rodent proofed. I only removed the wiper arm when the arm jumped a spline when ice got in the way.
  13. May 26, 2021 at 2:26 PM
    KWC
    KWC New Member
    Conroe, Tx.
    2017 Toyota Tundra
    6112's, 5160 + 1
    Well I'm sure glad you don't have that problem. Thanks.
