2017 Tundra warning lights ALL ON!
Discussion in '2.5 Gen Tundras (2014-2021)' started by marlon671, Dec 13, 2017.
  1. Dec 13, 2017 at 5:59 PM
    marlon671
    marlon671 [OP] New Member
    Marlon
    2017 MGM Tundra SR5 4x4
    I've seen a post on this but not so much 2017 specific. My truck has 3,9xx miles. Today about 20 mins into my commute, this happens. All lights on. Brake controller malfunction. Blind spot monitoring system issue. 4hi and 4lo flashing. Traction light on. ABS light on. Etc.
  2. Dec 13, 2017 at 6:00 PM
    It’s all warrantied at this point, but it reminds me of the trailer brake issues.
  3. Dec 13, 2017 at 6:26 PM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    It's because it's the Christmas season.
  4. Dec 13, 2017 at 6:27 PM
    Take back to dealership...hope it gets resolved
    MotoTundra likes this.
  5. Dec 13, 2017 at 6:28 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Figured it to be a good place to post this.
    Watt maker, 757TUNDRA, mdavis and 2 others like this.
  6. Dec 13, 2017 at 6:31 PM
    zlaneb
    zlaneb New Member
    Austin, TX
    Can you get the truck to shift higher than 4th gear or get over 50 mph? I had your problem plus it wouldn't shift higher than 4th gear and it turned out a rat had chewed up my main wiring harness. Pop the hood and look for rat pellets and chew marks on the wiring harness.
    Let us know what resolves this for you.
  7. Dec 13, 2017 at 6:41 PM
    marlon671
    Marlon
    I was driving past 50 on the freeway. Truck didn't feel different at all. It just started beeping and then the light show started. Lol
    I did turn of the truck when I got home and restarted. All lights went off except for the traction and abs light. IMG_0151.jpg
  8. Dec 14, 2017 at 6:23 AM
    tinyt1553
    tinyt1553 New Member
    Tom
    Cypress, TX
    2017 1794 CM - Magnetic Gray
    Exterior: POP & Lock Power Tailgate lock BakFlip MX4 Tonneau Cover Rhino Bed Liner Swapped OEM Halogen Fogs with Formula-J87 LED 6000k bulbs Rough Country 60" Tailgate LED lightbar 6" rubber stub antenna Interior: Front Emblem Camera with anytime backup cam, Crux Vimty-05 for Vehicle in Motion Override Center console wireless charging Verizon Hotspot in center console Chromecast to OEM head-unit display ESP Rear Seat 3 Compartment Storage 5% Ceramic tint on rear window and rear doors 18% Ceramic tint on front doors Weathertech rear seat cover (try to take Hank (boxer/pointer mix) with me everywhere I can) In The Works: Upgrade to 2018 OEM LED Headlights VLEDs throughout the rear (turns, brakes, highmount 3rd brake and cargo) GRT Lighting LED's to replace all interior bulbs Future Wishlist: Swap OEM Head-unit with Kenwood DNX994S and use iDataLink Maestro RR to integrate OEM backup cam, OEM USBs, OEM Aux input, etc AMP-Research Power Sidesteps Train (air) horn
    Im guessing it's the alternator. It's common to see all these warnings, as the Alternator stops producing high enough power, the computer loses connection to the sensors and triggers all these warnings.
    NewImprovedRon and trayday like this.
  9. Dec 14, 2017 at 6:47 AM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    My truck did the same thing and 4wd wouldn't engage. I read on another Tundra forum that someone had the same thing happening and it was the battery. I swapped my battery for a Yellow Top and I haven't had issues sense.
    equin and TTund16 like this.
  10. Dec 14, 2017 at 7:40 AM
    blizz86
    blizz86 New Member
    don't disconnect the negative terminal or try to diagnose it yourself if you're still under warranty.. pain in the ass service reps will try to say "oh you reset the codes so we cant see whats wrong" etc etc. just bring it to the dealership
    equin and MotoTundra like this.
  11. Dec 14, 2017 at 7:46 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    I'm assuming you either lost power or data comms to your cluster, brake controller, and 4x4 switch.
  12. Dec 14, 2017 at 7:57 AM
    Tundra_mike89
    Tundra_mike89 New Member
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    Toytec boss coilovers Toytec shackles Total chaos uca's Method wheels Nitto ridge grapplers
    My 2014 did that minus the trailer brake, and bsm errors. It never went away. I always had to turn the truck off and turn it on to clear it. I never was able to find the problem. So I just traded it in for a 16 lol.
  13. Dec 14, 2017 at 8:28 AM
    ScottsBad
    ScottsBad New Member
    Scott
    Free Idaho, escaped Commiefornian
    2018 TRD Limited
    Just a Bed Rug, Soft Topper, Console Safe
    Pretty Christmas lights! Sorry, I know its not funny. Hope the dealer can get it resolved. Low voltages or intermittent power fluctuations can play havoc with computers which is one of the reasons I sometimes think I'd like to have an early 70's truck with crank windows.
  14. Dec 14, 2017 at 9:27 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    All the key cycle does is make the systems go from active to dormant until systems goes through a check or calls up that specific sensor/actuator.
    Until you drive a certain amount of key cycles or miles, the faults will remain until they self heal based off the above (if they ever do).
    As others mentioned, don't deal with diagnosing this yourself. Its under warranty, let Toyota deal with it.
    You didnt by chance run over any debris in the roadway just prior to this did you?
    trayday likes this.
  15. Dec 14, 2017 at 10:26 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Like previously mentioned, I won't try to reset anything, you are under warranty and you want the dealer to read the code so they know what is/was up.
    They will get it worked out for you!
    trayday likes this.
  16. Dec 14, 2017 at 1:13 PM
    marlon671
    Marlon
    Nope. Didn't run over anything. Truck was dropped off tho the dealer this am. We'll see what they find.
    14burrito[QUOTED] and Backslider like this.
  17. Dec 14, 2017 at 2:20 PM
    marlon671
    Marlon
    UPDATE.
    So I get a call today at around 2pm. Because of the drive to the dealership and the lights all mysteriously turning off, they claim nothing registered during diagnostic. They now want me to authorize a 4 hour teardown so the techs can "dig further". And because my truck has a 5" lift, they say my warranty is completely voided. Now I did not take that part too easy.
    I asked, did the suspension modification cause the electronic issues that the truck is experiencing, he says "his manager won't agree to warranty work because my warranty is voided and the labor cost is coming out of my pocket". So then I asked "why would my entire warranty be voided because of a suspension modification if the issue is not related to the suspension"? He says he can't tell me if it'll be warranty work or not unless they do a 4hr teardown.
    They informed me of the lights not being present even after they drove the truck around so I told them "no thanks" to the 4 hour tear down as he agreed since they would be "chasing a ghost".
    Entire vehicle warranty voided because of a suspension lift? That's unheard of. My 16 taco was lifted and serviced under warranty. Weird, shady dealership.
  18. Dec 14, 2017 at 3:00 PM
    marlon671
    Marlon
    IMG_0167.jpg Here's the funny part. Top picture was taken when I got home. 3940 miles. Middle picture shows when I pulled into the dealership. 3943 miles. And third was when I got home from the dealership, 3946 miles. (My intentions of taking pictures was to document the light show, but it came in handy for other purposes.)
    Now if I did the math correctly, it takes approximately 3 miles from my house to the dealership. The service advisor told me they drove the vehicle around and the light still did not come on. I was wondering how they were able to drive my truck around to try and replicate the problem without any mileage being added to my odometer, around their lot maybe?!. Lol. That dealership is such a joke. I guess I shouldn't have brought it there on the day of their holiday luncheon.
    Happy Holidays Toyota Vallejo. Smdh.
    Backslider likes this.
  19. Dec 14, 2017 at 3:20 PM
    Berettafan
    Berettafan New Member
    2017 CM
    I’d bet battery. Don’t buy an optima tho. Overrated.
    Vector W8 likes this.
  20. Dec 14, 2017 at 3:23 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    Magnusson Moss Warranty Act
    equin, 14burrito and marlon671[OP] like this.
  21. Dec 14, 2017 at 3:43 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I would try another dealership. Did you do the Zero point calibration after your lift?
  22. Dec 14, 2017 at 3:45 PM
    marlon671
    Marlon
    That makes 2 battery responses. lol.
    What battery do you recommend?
  23. Dec 14, 2017 at 3:45 PM
    marlon671
    Marlon
    No I haven't.
  24. Dec 14, 2017 at 3:52 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    For those with lifts, does the ZPC only help with VSC issues?
  25. Jan 2, 2018 at 10:36 AM
    marlon671
    Marlon
    ***Solved***
    My issue was a simple fix. Front driver side ABS sensor was acting up. Kinda put the pieces of the puzzle together as my brake fade seems to be focused on the front drivers side. Went to local pick n pull, pulled out another ABS sensor from a donor truck and BAM! Issue resolved. However, dissapointed by my local toyota dealer who decided to give me the run around when i brought in my truck for this issue which was caused by my bad ABS sensor problem. It seems that the bad ABS sensor was causing the circuitry of the truck to act weird which caused all my warning lights to go on. But now, truck runs great! I waited till I hit a couple hundred miles before I'd update to make sure the issue is fixed. No light show present! Thought id share my findings and maybe this will help someone along the way. Happy 2018 folks!
    Heres the link to my other post if you want to see it:
    https://www.tundras.com/threads/2017-tundra-brake-fade.19440/#post-444919
    Beesta, equin, jtwags and 2 others like this.
  26. Jan 2, 2018 at 10:50 AM
    Berettafan
    2017 CM
    Factory. Sears had some highly rated also.
  27. Jan 2, 2018 at 10:50 AM
    Optima not even close to being overrated.
    marlon671[QUOTED][OP] likes this.
  28. Jan 2, 2018 at 10:51 AM
    Sears batteries used to be good. Not any more.
    marlon671[OP] likes this.
  29. Jul 8, 2021 at 6:26 AM
    Petroleum 1
    Petroleum 1 New Member
    Colorado / Arizona
    Just an fyi for others my 2017 4x4 with 70k miles just did the same thing as the photo on post #1. I was leaving boulder colo heading to phoenix az and just as i got on the hwy all the lights came on. I pulled over did some quick research with my tele and decided to shut the motor off and restart. The codes went away and i continued on my trip. About 20min later the dash lit up again. This time i decided to just keep driving as the truck controls felt fine and i figured it was a computer blip. I was not towing a trailer but the bed was loaded with home type items. Not really a heavy load but packed up just the same. I drove for 14hrs with a few stops for gas and made it to phx with no additional problems. The braking felt a little weird but the truck was stopping fine so i gave it no extra thought.
    The next day in phx i brought my truck to right toyota to have it checked out. They quickly diagnosed the problem as a worn drivers side rear axle bearing and leaky seal. Metal shavings and fluid causing the abs sensor to fail. Im not happy with this type of failure on a 70k tundra (mostly hwy miles) but on the other hand it got me home ok with all the bs going on. Since the repair a week ago there have been no more error codes.
  30. Jul 8, 2021 at 7:41 AM
    2mchfun
    Do you ever launch or load a boat? Plenty of water can get in the rear end and cause significant damages.
