2017 Tundra SR5 4WD - Don't see any grease points
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by NeilAgg, Nov 30, 2019.
  1. Nov 30, 2019 at 1:46 PM
    NeilAgg
    NeilAgg [OP] New Member
    Neil
    2017 Silver Tundra SR5 4wd
    Hey everyone:
    I checked my owner's manual. It said I need to grease the 4WD propeller shaft. I crawled under the truck and did some searches on here. It looks like there are supposed to be grease zerks in the end caps of the drive shaft ujoints. Mine does not seem to have them. I guess mine is using sealed u joints. Other threads on this forum said that is for 2018+.
    I just want to be sure I am not skipping anything. Can anyone confirm if there are any places to grease on my vehicle?
    Thanks,
    Neil
  2. Jan 14, 2020 at 1:54 PM
    rockfordhx
    rockfordhx New Member
    NeilAgg - Looked under my 2017 DC 2WD and I dont have any grease zerks either.
  3. Jan 14, 2020 at 2:48 PM
    15whtrd
    15whtrd Mr. Blonde
    2017 is the year they started phasing it out. Some 17s will have it and some won’t.
    2wd Typically doesn’t have it anyways.
    On the bright side of things, I hear that a solid U joint without a Zerk fitting is stronger. Less likely to fail under load.
    LifeCycle likes this.
  4. Jul 15, 2020 at 2:29 PM
    ErSlickEr
    ErSlickEr New Member
    2018 MGM Tundra 4x4 CrewMax 5.7L FFV Limited
    I have a 2018 4x4 MGM 5.8L Tundra FFV Limited and can tell you that my tundra does not have any zerk fittings on the Front Propeller shaft or the Rear Propeller shaft.
