2017 tundra pro shake
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by kevgrant, Nov 29, 2016.
  1. Nov 29, 2016 at 4:47 PM
    kevgrant
    kevgrant [OP] New Member
    kevin
    2017 tundra pro
    20 inch rims
    This is my 4th tundra in the past 12 years
    Vibration/shake from 35mph to 60mph
    Feels like a Ford 1 ton ,Sometimes worse than others,weird feeling under seat,
    1500 miles on it ,
    Did it from day one,Change rims back to the 20 inch rims that were on my 2014 with no issues
    Dealer says ya something there, but not sure what ,will call tech support,tech support says no issues heard of.
    Dealer says its how they all are ,
    Im not impressed with Toyota Customer care at this point.
    Any thoughts
    K.G.
  2. Nov 29, 2016 at 4:50 PM
    My guess- needs road force balancing
    lol at "its how they all are." No, it's not. Take one off their lot for a drive. There'll be a difference.
    757TUNDRA and MotoTundra like this.
  3. Nov 29, 2016 at 4:55 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    If you cured it by switching wheels/tires, like Sean said, sounds like the tires aren't balanced properly.
  4. Nov 29, 2016 at 5:01 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    "I haven't felt a single vibration in my Tundra."
    -M.J. Fox
    Rbtrd, mdavis and TXMiamiFan like this.
  5. Nov 29, 2016 at 5:11 PM
    kevgrant
    kevin
    2017 tundra pro
    20 inch rims
    All my past Tundras went down the road as smooth as a corvette.
    Not tires or rims ,
    Stock 18 inch tires rims = shake
    20 rims and new tires balanced twice =shake
    thinking unbalanced driveshaft ?
  6. Nov 29, 2016 at 5:21 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    A bit confused, but keep us updated. Good luck.
    joonbug likes this.
  7. Nov 29, 2016 at 5:39 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    :notsure:
    MotoTundra likes this.
  8. Nov 29, 2016 at 6:10 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    I wonder if Toyota dealer school teaches that "They all do that" line. No....they don't.
    So anyways, do you have a rear lift (your truck, not you)? Sometimes that can cause a drive-shaft vibration which can be resolved with a carrier bearing drop kit.
  9. Dec 1, 2016 at 6:33 AM
    trdlife
    trdlife Toyota Master Technician
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    I have a 2015 Pro and after it sets for for the work day and i head home, the tires shake for about 2 minutes then goes away. The Tundra will flat spot tires after setting, outside temp makes it more noticeable. You really notice it when you have immediate access to the highway i say within 1/2 mile. I've seen it on 18s & 20s, if you feel the vibe then it goes away, that's it, if not then look at your center u-joint.
