2017 Tundra mice in cab
Discussion in '2.5 Gen Tundras (2014-2021)' started by alans, May 30, 2018.
  1. May 30, 2018 at 5:22 AM
    alans
    alans [OP] New Member
    alan
    tundra
    where are the mice entering the cab I have caught 2 this week 1 running around with a trap and the other in the cabin air box but from the inside they did not come in through the filter it was intact
  2. May 30, 2018 at 5:26 AM
    alans
    alan
    tundra
    thanks
  3. May 30, 2018 at 5:42 AM
    Norfolk757
    Norfolk757 עַם יִשְׂרָאֵל חַי
    Tom
    Norfolk, VA
    2015 White Tundra- CrewMax TRD Off Road
    That is insane... I just bought my truck a week ago and my first wash/clean i found mice droppings and foam particles behind the back seats once i lifted the bench. Where are they coming from? I used the sticky pads but haven't gotten any mice just yet.
  4. May 30, 2018 at 6:12 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    The wire insulation is soy based, spray it with Cridder Ridder once a month. It’s an expensive fix if chewed through.
    Stumped how they’re getting in your cab, my firewall is pretty tight.
    driverdog likes this.
  5. May 31, 2018 at 8:43 AM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    check the AC drain under the truck. it's a huge hole.
    driverdog, Norfolk757 and JoshuaA like this.
  6. May 31, 2018 at 10:32 AM
    Uncle_Charlie
    Uncle_Charlie New Member
    2018 Tundra- Work truck package
    In the cab, I found chewed remains of insulation from under the hood this winter. I never found the mice probably due to the stray cat population.
  7. Jun 1, 2018 at 8:50 AM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    Bummer. Did you leave your car door or window open for awhile during the day?
  8. Jun 1, 2018 at 7:32 PM
    beaver6713
    beaver6713 2015 CM
    Kleve
    Safford Arizona
    2015 Tundra CM
    6 inch Pro Comp lift. OME rear springs with Coach Builder +3 shackles. Coach Builder tie rod ends. ICON 2.5 front and rear shocks with remote res. ICON Hyd bump stops. 35" Nitto Trail Grapplers on 18" fuel rims. Kenwood DNX 892 head unit with JL audio and RF amp pushing 2 Image Dynamics idq10 subs. SABM, S POD switches for 42" in bumper and 32" behind grille LED light bars. Full interior and exterior LED conversion. LED flush mount back up lights in rear bumper. Valentine one radar detector. V Leds under dash and seats foot well lighting. TRD pro head lights and grille. Full AJT dash kit
    Had one come in my 2015 CM, came in under the hood cowl, sat on top of the cabin air filter and gnawed itself into the cab, chewed up all the wires to both subs and both of my amps. So if I was you, I would check your air conditioning duct, and the solution to the problem is to cover the big hole under the hood cowl with wire mesh.
  9. Jun 2, 2018 at 3:53 AM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    Damn I hate rodents!!! I would go into FULL KILL mode...IE: Every ounce of physical and mental energy,every waking second,no sleep,no food,every fiber in my body and my entire soul would be lazer focused on COMPLETE and total eradication.I might even have to sacrifice the truck to accomplish this mission.Did I mention that I hate rodents?
  10. Jun 2, 2018 at 4:12 AM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Try this to get rid of them mice.......(jk)
  11. Jun 2, 2018 at 7:49 AM
    plumber802
    Andy
    Vermont
    Yes...This is an option!
  12. Jun 2, 2018 at 9:00 AM
    rds95991
    rds95991 New Member
    2018 Super White Tundra CrewMax SR5 TRD
    I hate the things. I had my Accord parked in my back driveway and garage and found something had made a nest in the engine bay. We have trees they hide in and the dumb things use the telephone and cable lines to cross the streets and get to houses. I've had to stuff stainless steel wool in the roof vents on my house to keep them out of my attic. Now I keep my pellet rifle in my shop and when I see one, I take a shot at it.
  13. Jun 2, 2018 at 9:46 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I have no idea how there getting in. But here is the trap that I use around my RV. I catch at least two ground squirrels a week with the exception of the Winter season. It saves a few dollars because there reusable. Peanut butter gets them everytime..
    Ely010606 and VadersTundy like this.
  14. Oct 8, 2018 at 8:22 AM
    NHPig
    NHPig Toyota For Life
    New Hampshire
    Super White 2016 Tundra Limited TRD CrewMax 5.7L V8
    Are there images of where that might be exactly?
  15. Oct 8, 2018 at 7:28 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    O
    M
    G
    !!! :eek2:
    :puke:
  16. Apr 3, 2020 at 2:27 PM
    JohnBoy
    JohnBoy New Member
    Mice deficateing and pissing on your Tundra cloth seats? Do you like the smell? I don't get it, all I see here are folks joking around about what I feel is Toyota's poor engineering. How fn hard can it be to screen the known locations of mouse holes, if you are the engineer that designs Tundras'. I built my own house, it is fn mouse proof for gods sake. I feel like a class action suit would do the job, who's interested? Why should Toyota get off the hook for this. I just don't get it.
    kingpin3919 likes this.
  17. Apr 3, 2020 at 2:40 PM
    JohnBoy
    JohnBoy New Member
    Seems to me that Toyota engineering department is full of idiots. How can they continue to allow this to happen to their loyal repeat customers. Every time I get in my new truck, I have to clean out the torn up tissues, foam from seats, mouse feces, and god knows where the mouse pee smell comes from. It seems to me that after years of people complaining about this problem would bring it to somebodies attention that actually cares about their customers. How about a class action law suit to solve this once and for all. Anyone interested?
    I built my own house, and by god it is mouse proof. All they have to do is put stainless hardware cloth over all openings that a mouse can get through, problem solved. If they chewed though a grommet, I can see that, but is not the case. If they chewed through the cabin air filter, I can understand, not the case. If you can't tell by now, I am one pissed off Tundra owner.
    TUNDRAPROGUY2017 likes this.
  18. Apr 3, 2020 at 2:46 PM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    I had to buy a bottle of Peppermint Oil a few years back, after I spotted a "visitor" in my garage. Every now and then, I spray a little under the hood on harnesses and firewall. No issues since 2010.
  19. Apr 3, 2020 at 2:46 PM
    JohnBoy
    JohnBoy New Member
    I spent over an hour on Toyotas' customer satisfaction phone number today. Tier one agent was helpful and understanding saying "that's just not right". And then he passed me to tier two. This Biotch was rude and told me it was an outside influence and I could turn it in to my insurance company, really! Finally I talked to a supervisor, same story. They are not responsible! Wanted me to go the the government official who oversees corporate responsibility. We all know the results that would get us. So seriously who is up for class action?
  20. Apr 3, 2020 at 2:47 PM
    TUNDRAPROGUY2017
    TUNDRAPROGUY2017 New Member
    Illinois
    2017 TRD PRO Crew Barcelona Red Metallic
    I agree. I was doing some work behind the driver side seatbelt area and found all of the same things you have mentioned. I honestly thought it was from my garage but after hearing this I tend to think differently. I know mine is a 17 but there is no other reason this should be happening.
  21. Apr 3, 2020 at 2:47 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Get yourself one or both of these:
    One is a fat spoiled fur ball and the other is a Western Rat Snake that crawled into our crawl space to help himself to our Roof Rat colony
  22. Apr 3, 2020 at 2:58 PM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    One word. SNAKE.
    texasrho83 likes this.
  23. Apr 3, 2020 at 3:24 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
  24. Apr 3, 2020 at 3:27 PM
    Rex Kramer
    Georgia
  25. May 2, 2020 at 6:30 PM
    2014 TRD
    2014 TRD Doesnt hire TV personalities.
    Deep in the heat of Texas
    Greetings, Ive got the same issue. But my truck was parked out in the hill country (Texas) for 4 days a week ago. Got home and saw a mouse jump out and run for it....no biggie I thought. Until it started to smell in the cab. I took all the stuff from under the back seats and found two smaller mice.....not pinkies so I know the other one didnt birth them.....
    BUT, it STILL stinks. Ive been leaving the windows open in my driveway to air it out since I CANNOT find any other mice.....not under the seats, not in the air filter....
    BAH!!
    I dont see any evidence of them chewing into the air grill. And I did leave the door open when loading/unloading. But where in the heck did the babies come from??
  26. May 2, 2020 at 11:37 PM
    2020 dc
    2020 dc New Member
    2020 tundra dc sr
    Solution to rat and mice problem is BAIT STATIONS. I ordered five or six of them from Amazon. Place them all around my yard. First month, the rats ate the poison like candies (I have to refill the station once a week). After a month time, the eating taper off. Soon no more rats. Just make sure your dogs do not get to it.
  27. May 3, 2020 at 12:07 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    YOU WILL NEVER WIN ! :bananadead:
  28. May 3, 2020 at 4:40 AM
    Midnite72
    Midnite72 Anything DIRT !!
    Bill
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    I have been BATTLING a FU$king mouse invasion of my company bucket truck(Ram5500) that I park next to my garage that houses my Tundra
    Have had some “signs” of mice in garage but NONE in Tundra YET !
    like to keep it that way !
    I “live” in the Ram 60hrs + every week (before COVID - SHIT - very SLOW now)
    eating breakfast/ lunch and sometimes dinner in truck- mice started getting in Ram a couple months back and taking food trash out of trash can and causing havoc.
    I started by making sure I took out all trash every nite then the bastards started bringing in outside nuts etc and eating/ processing them in truck AGRRRRRR !!
    Then I went with my old faithful- supergluing cheese on 2-old school style mouse traps in Ram at nite - killed a family of 5 in matter of days - Still continue to remove my trash and have been GOOD- so far
    I know there will be more - Does Toyota still use soy- based wiring In my ‘18 ??????
    Going to look into the critter rider and peppermint oil ???
    Any new suggestions to keep them out of TUNDRA !!
    SORRY for the LONG rant
  29. May 3, 2020 at 6:00 AM
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    The only thing I found that works is running a Ozone generator in the vehicle. I have one running in my Lexus that just sits there and it does work, nothing else did, Or would only last for awhile. Your vehicle will always smell good.
