2017 Tundra Hard to Start FIX
Discussion in '2.5 Gen Tundras (2014-2021)' started by JasonPB, Dec 6, 2024.
  1. Dec 6, 2024 at 10:07 AM
    JasonPB
    JasonPB [OP] New Member
    JASON
    2017 Tundra
    I have a 2017 Toyota Tundra that was over cranking to start sometimes it would take a couplle of times to start . The tail pipe would smell rich of fuel. I read all the horror stories on here being a fuel pump with no fixes a new battery with no fixes. I had new air filter new spark plugs new fuel filter nothing would work. I saw a deal on a mid range scanner and thought I woul give that a try and boy I'm glad I did . I was able to go under maintenance under Engine and ECT and reset the memory and learning values. Been 2 weeks never had to change gas just reset memory and values start up rt now everytime. The scanner I bought is a topdon ArtiDiag 600S. I hope this helps someone.
    Bakershack and ID-Matt like this.
  2. Dec 6, 2024 at 10:21 AM
    Flex fuel truck?
  3. Dec 6, 2024 at 5:33 PM
    JasonPB
    JASON
    2017 Tundra
    Yes it is
  4. Dec 8, 2024 at 8:39 AM
    Sunfish
    Sunfish New Member
    17 4X4 CM Limited
    Mine needs a pump and every so often you have to reset the alcohol density. Research Flex fuel pump here on the forum. This problem seems to be worse in colder climates. There is a way to put an external filter on these available from URD and bypass the donut filter on the pump. The thinking is why put a Toyota pump that costs $600 if you are going to have the same problems down the road. Some of the members have put a non Flex fuel supply line and blocked off the switching valve while leaving the connection hooked up. Its a pretty big chore to remove those 38 gallon tanks
  5. Dec 8, 2024 at 11:20 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Scanners of any type pay for themselves pretty quickly when your truck starts acting up.
