2017 Tundra Audio Project
Discussion in 'Audio & Video' started by Speedkills119, Dec 5, 2018.
  1. Dec 5, 2018 at 9:56 AM
    Speedkills119
    Speedkills119 [OP] Shenanigator
    Ryan
    2017 Silver Tundra 1794
    Mostly Stock Procomp 4" lift Prospeed cold air intake Bakflip bed cover HID head and fog lights 2000W JL Audio build Magnuson supercharger w/ Sniv Pulley AR Headers/full exhaust Auburn Limited Slip Prospeed fuel system w/ 1000cc injectors Dual 450 in tank fuel pump 2nd pump on a Hobbs boost reference switch Lexus RCF throttle body Prospeed catch can system TRD sway bar Prospeed Flex Fuel Tune Dirt Logic coil-over and shocks VR forged wheels CalTracs Nitto 420V 305/50R18
    I started by putting the Infinity reference speakers in on the stock amp but since they were 4 ohm it's not loud enough. I took out the stock 8" sub and put in a Rockford 12" and Rockford R250X; it sounds OK but but doesn't really hit so I'm taking it up a level. I'm bypassing the stock amp and adding a signal processor before the 3 JL amps. I went with class A amps for the component speaker because they sound a lot better but they use a lot of power and creates a lot of heat (notice the cooling fins). The 1000 watt amp will power the 800W 10's in the JL Stealth box. I still have to run the 1/0 power wire, install the distribution blocks, upgrade the chassis ground to 1/0, replace the battery terminals, and splice in the signal wires.
    FWC, TRDFerguson and deedubb like this.
  2. Dec 5, 2018 at 10:20 AM
    Cfincke
    San Antonio
    Looking good!
    did you replace the head unit?
    just wondering where the signal is coming from that feeds into the TwK88.
  3. Dec 5, 2018 at 10:43 AM
    Speedkills119
    Ryan
    No, I'm keeping the stock head unit; I'm just going to splice into the stock amp input. Not really sure why but I'm trying to keep the stock dash look and the functionality of the head unit for all of the non-audio stuff.
    Saltyhero13 likes this.
  4. Dec 5, 2018 at 10:55 AM
    Cfincke
    San Antonio
    since you have a 1794, I assume you have the JBL Entune radio, as I do in my 1794. It is my understanding that in the JBL system that the signal from the head unit to the factory amp is encrypted and the factory amp decodes the signal. You will run into issues if you are just splicing into the cables before the factory amp.
    I originally had a JL Fix86 after the factory amp to clean up and level the factory amp output signal to my JL amps. I have since changed to the Rockford DSR1 with a iDatalink Maestro cable. The DSR1 can de-crypt the the headunit signal and allow removal of the factory amp all together.
    @TundraTex has researched the tundra stereos and wire diagrams, he can correct me if I am wrong
  5. Dec 5, 2018 at 10:58 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Why 2-300/4 amps?
  6. Dec 5, 2018 at 11:25 AM
    Speedkills119
    Ryan
    There's 8 channels and and the 300/4's will be handling 7 of them.
  7. Dec 5, 2018 at 11:45 AM
    Speedkills119
    Ryan
    I think you're correct, actually I know your correct, because the factory head unit sends data for volume control to the amp. I think I can use can use the amp output to the Twk88 since it can handle high level output. Why did you chose to switch from the Fix86 to the DSR1? I almost went that route.
  8. Dec 5, 2018 at 12:29 PM
    Cfincke
    San Antonio
    My factory amp added a LOT of noise to the signal. With the fix volume knob at 50%, i could not turn the stereo up past 40 without getting a noticable hiss. I even set the amp gains much lower than the clipping light on the JL RD amp.
    Once i switched to the dsr1, all the hiss went away and i could bring the amp gains up to just below the clipping light. I can now turn the volume up as much as i want
  9. Dec 6, 2018 at 2:04 PM
    Shelbie67
    Shelbie67 New Member
    Blake
    NorCal
    2018 tundra crewmax platinum
    RADFLO 2.5 suspension, apex rock sliders, BFG KO2, exhaust delete, Full Active Stereo
    I used the ampro 4, into my audition Bit One, super clean signal and no noise!
    I’m about to get a new head unit and ditch the stock jbl one/amp.
  10. Dec 10, 2018 at 5:51 AM
    Speedkills119
    Ryan
    I finished the install this weekend.
    Really the only issue I had was sorting out the harness to the factory amp. The wiring diagrams I found didn't match my truck so I had to start from scratch using a spare speaker and the balance/fade on the head unit to label all the inputs.
    My signal path is:
    Head unit -> Stock amp -> JL Audio Fix 86 -> JL Audio Twk 88 -> amps
    There's absolutely no white noise at zero volume and the sound is crisp and clear with the class A amps. I don't have my stealth box yet so I'm using my 12" Rockford Wedge Box for now. The sound through that one 12" is awesome so I can't imagine what it's going to sound like with two 10's. This system definitely needs the 3f capacitor; when it's turned up and the bass hits it's pulling power from the cap with the truck at idle. I kinda figured it would since the class A amps draw more power than a class D. The amount of adjustment with this arrangement is daunting since the Fix and the Twk can both be adjusted with a laptop and each channel can have it's own EQ. I know there are easier ways to put in a system but I don't mind the extra work with a soldering iron and I couldn't be happier with the results.
    TRDFerguson likes this.
  11. Jun 19, 2019 at 2:57 PM
    Speedkills119
    Ryan
    Update - Added the JL Stealth Box and sound mats. The box is rated at 800w but it handles better than 90% of the XD1000 at 13.4V before it starts clipping. The bass all the way to max is clear and way more powerful than my taste. The adjustment of the system with the JL Audio Fix 86 and JL Audio Twk 88 is infinite. I wanted to to keep the stock head unit unless it became a clear handicap but it's a non-issue. I actually keep it turned up to max. and adjust the volume and the bass with the DRV-205 remote mounted on my center console. If I had it to do over again the only thing I would do different is to go with the JL component speakers instead of the Infinity.
  12. Jul 4, 2019 at 6:37 AM
    Jmmtjoy
    Jmmtjoy Livin the dream
    Bristow, Virginia
    2016 Crewmax SR5 Super White
    Where did you put the ground?
  13. Jul 4, 2019 at 6:48 AM
    Speedkills119
    Ryan
    To the chassis where the stock sub was with 1/0 from the chassis to the distribution block. I upgraded the ground wire under the hood to 1/0 from the battery to the chassis.
  14. Jul 4, 2019 at 8:03 AM
    Jmmtjoy
    Bristow, Virginia
    Is the factory location under the passenger seat?
  15. Jul 4, 2019 at 9:03 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Sounds like a great setup. If you are still rocking the factory battery, upgrade to a Northstar!
  16. Jul 4, 2019 at 12:02 PM
    Speedkills119
    Ryan
    The ground I used for the amps is on the driver side behind the back seat.
    Jmmtjoy likes this.
  17. Sep 16, 2019 at 12:17 AM
    aparker813
    aparker813 New Member
    Any chance you have your time alignment dialed into the TWK-88 and would like to share them? I spent a good bit of time messing with the time alignment earlier today and was getting a bit frustrated. Might help starting (or ending) with someone else's measurements and adjustment and go from there.
    I just put the TWK in, and I have a stealthbox as well - am I imagining the affect, or is the TWK actually able to mute each sub independently? The stealthbox only has one speaker connection so I can't imagine how it would work, but it sure sounded like I was able to turn off left and right subs independently of each other from the Tun software.
  18. Sep 17, 2019 at 6:11 AM
    Speedkills119
    Ryan
    I don't mind sharing it. I just used a tape measure and measure each channel to my ear. The way the stealth box is wired to get the correct ohm load we can't completely mute an individual speaker but you will notice an effect with the balance if you have it wired mono.
  19. Sep 19, 2019 at 11:55 AM
    Speedkills119
    Ryan
    Here's my latest twk file.
  20. Sep 19, 2019 at 12:46 PM
    aparker813
    Awesome - many thanks!
  21. Dec 22, 2019 at 1:57 PM
    Speedkills119
    Ryan
    ptat likes this.
  22. Jan 1, 2020 at 1:47 PM
    3rdGenTundraDC
    3rdGenTundraDC New Member
    MGM
    Central Florida
    14 Tundra DC
    305/50/20 Nitto Terra Grappler G2 Stock, stock, stock.
    Wow!!! 7 tweeters. I bet your sound stage is pretty crisp and bright. Do you have your eq on flat to compensate? I have only 4 tweeters, all on the dash and i have to fade it to the rear about 1/3 to level out with the mids in the door. Very nice, quality system you have.
  23. Jan 7, 2020 at 1:30 PM
    aparker813
  24. Jan 7, 2020 at 1:36 PM
    Speedkills119
    Ryan
    I adjusted the amp output so I didn't need to fade but I do flatten the front channels a little. I was shocked at the difference between this setup and what I had with the stock unit with the sound processors. The detail and sharpness of the sound is much better.
    AZBoatHauler likes this.
  25. Jan 8, 2020 at 12:35 AM
    Twinky
    07 double cab work horse
    You can't adjust the speaker volumes separately thru the head unit?
    Really nice setup and install.
  26. Jan 8, 2020 at 8:32 AM
    3rdGenTundraDC
    MGM
    Central Florida
    14 Tundra DC
    Yes you can especially head unit with Time alignment like my DDX9905S. Not too familiar with the Alpine used above but this Kenwood also has gain setting in the built in crossover on the deck unit. I just use the fade to easily control both sides at the same time depending on the music and it's much faster than individually setting the levels. I set my amps with a DMM and turn off all crossovers at the amps. "Set it and forget it" lol. Plus no one drives my truck but me and the Kenwood has save setting feature to prevent reset after disconnecting battery. I think it's best to control the balance and crossover at the head unit since there's more features as well as preventing wasted energy going to the amps. I think time alignment is a gimmick especially in a car but thats my opinion. For home audio it's definitely worth it but you want an even/centered sound stage in a car/truck rather than focusing it all to one specific hearing position. Might be good if you're just using deck power to run the speakers and they're not enough power to center everything.
  27. Jan 8, 2020 at 11:45 AM
    Speedkills119
    Ryan
    I’m not sure what everyone’s set up is but in mine (JBL) there are 3 speakers on the dash and a component set in each door. The Alpine, and most units, have a front, rear, and sub pre-amp output. The front signal on mine is configured for signal to the dash and two front doors. The center channel on the dash is bridged. So, in the front I can’t control the volume to each individual speaker from the head unit so I do it from the amps to balance the system. I could, one rainy day, put the Twk88 back in and that gives me another set of channels to split up the front some more. They way I bought mine from Crutchfield it was pre-wired and programmed for the steering controls but it doesn’t come with the add on to control lights and other accessories.
