2017 tundra 5.7 trd pro p
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Mighty-fizzle, Sep 4, 2024.
  1. Sep 4, 2024 at 8:11 PM
    Mighty-fizzle
    Mighty-fizzle [OP] New Member
    2017 Toyota Tundra TRD PRO
    Hello everyone have a major isue with my 2017 tundra.
    The check engine comes on when ever I'm driving about 2.000 rpm with a random missfire (PO300) code and a cylinders 1,3,5,7 cylinders (PO301) (PO303)(PO305)(PO307) these codes never show togeter but allways randomly as PO300 with one or two of the bank 1 cylinders.
    I changed all the coils and sparkplug plus and all injectors also replaced Secondary Air Injection Check Valve and checked vacume pressures and cylinder compression. With everything that I checked being good
    I bought the truck with a salvage title. around 70,000 miles.
    When working on the engine I can see that bank 1 ( with the missfire) the head was removed at some point.
    My thinking is that the timing chain jumped a link and is causing everything.
