2017 TRD pro
Discussion in 'New Member Introductions' started by Pacao1234, Jun 11, 2017.
  1. Jun 13, 2017 at 9:30 AM
    comai8981
    comai8981 The payment is the cheap part!
    Joe
    Murrieta, CA
    2016 TRD PRO Crewmax
    Coach Builder .5" shim w/ +3 shackles K&N intake/filter
    Did you have to remove the lower shock bolt on the rear to remove the tension from leafs? Trying to figure out what time I'm going to have that first beer!
  2. Jun 13, 2017 at 9:37 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Yeah I think I did. You'll want to put the truck on stands and then lower the axel with the jack just enough so you can swap out the shackles. **Watch the tension on the brake lines when you do lower the axel. I had to disconnect the brackets from the frame to give a little more slack. Oh, and the beer will start flowing once you get to the bushings lol.
  3. Jun 13, 2017 at 11:47 AM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    This^^ I'm installing 2 shims and +3 shackles in a couple weeks. shims should give me 1" up front and +3 shackles will give about 1.75" in the back front what I hear...
    R0CKETMAN and boardude[QUOTED] like this.
  4. Jun 13, 2017 at 12:47 PM
    Newm
    Newm New Member
    KC
    Just a thought...if you rent the ball joint press you might consider also renting the 4X4 adapter kit for it as well.(my local O'reilly had it as well) Larger and deeper receiving tubes made it much easier for me.
    R0CKETMAN and boardude like this.
  5. Jun 13, 2017 at 12:55 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    This is a good idea. I had to tape a couple of the tubes together to make it deep enough to pop them out lol.
    Newm[QUOTED] likes this.
  6. Jun 13, 2017 at 1:02 PM
    comai8981
    Joe
    Murrieta, CA
    Getting some great input here! Thanks guys! I will post pics once I get it installed. Still waiting to hear back from coach...btw how much did the shackles and shims run?
  7. Jun 13, 2017 at 1:20 PM
    Newm
    Newm New Member
    KC
    $18 per shim and $250 for the +2's with poly bushings....if memory serves me correct.
  8. Jun 13, 2017 at 1:49 PM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    no
  9. Jun 13, 2017 at 2:01 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Welcome from :canada:
  10. Jun 13, 2017 at 2:46 PM
    comai8981
    Joe
    Murrieta, CA
    That's a great price! It's going to cost me more in beer and tri tip to get a buddy to help!
    PM'd coach builder still waiting to hear back to order.
  11. Jun 13, 2017 at 2:49 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I would just call him. He sent me an invoice right after talking with him and it was shipped the next day.
  12. Jun 14, 2017 at 7:34 AM
    comai8981
    Joe
    Murrieta, CA
    I called and got a hold of him yesterday...He suggests the +3 over the +2 for the 2016 because of the gas tank. I am torn. Have you seen any pics for comparison of +2 vs +3?
  13. Jun 14, 2017 at 7:54 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I haven't seen any comparisons on 16's+. From what I understand the +3s on a '16 = +2 on a '15. I know he has done a ton of Pro's so he might have some compare pics but I don't recall any 16's going with the +2s
  14. Jun 16, 2017 at 11:56 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Welcome!
