2017 TRD Pro Upper Ball Joints Already?
Discussion in '2.5 Gen Tundras (2014-2021)' started by cjmay13, Jun 25, 2020.
  1. Jun 25, 2020 at 3:05 PM
    cjmay13
    cjmay13 [OP] New Member
    Corey
    Indiana
    2017 Toyota Tundra TRD Pro Cement Gray
    None Yet.
    Just over 60k miles, took it in for service and they said front upper ball joints need replacing and also truck needs another front end alignment. Seems a bit early that the upper ball joints are pretty much done and will be a second alignment. I drive 90% city/highway. Stock wheels and LT275/70/18
  2. Jun 25, 2020 at 3:19 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Need a new place for you service so you don't get disservice like this.
    But........have you jacked up the front end to get the front tire off the ground then grabbed it and gently shook/moved it around to see if you feel any play/movement?
    My 1997 T-100 with 265,000 miles is on it's Mama Toyota upper ball joints and doing juuuuuuuust fine.
  3. Jun 25, 2020 at 3:25 PM
    cjmay13
    Corey
    Indiana
    None Yet.
    I haven't done that yet but it does look like they've leaked some grease out.
  4. Jun 25, 2020 at 3:30 PM
    cjmay13
    Corey
    Indiana
    None Yet.
    Pictures
    hagrid likes this.
  5. Jun 25, 2020 at 3:37 PM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    Typical issue with factory UCA. Totally normal, nothing to worry about. If it bothers you, upgrade to an aftermarket like SPC.
    cjmay13[OP] likes this.
  6. Jun 25, 2020 at 3:47 PM
    cjmay13
    Corey
    Indiana
    None Yet.
    Thanks Makoy
