2017 rear differential noise
Discussion in '2.5 Gen Tundras (2014-2021)' started by Kidharvey, Sep 19, 2022.
  1. Sep 19, 2022 at 6:18 AM
    Kidharvey
    Kidharvey [OP] New Member
    Harvey
    2017 blue 1794ed
    None
    New member here, so bear with me... I have a 17 (Wife's) and 16 tundra. 17 rear diff scrapping sound --- rotor (OEM rotor) grinding against e brake back plate.... no obvious rust, diff gear oil looked fine, no play i could feel, and no grinding sound when truck is in drive on the lift.... but spin axle by hand n hear a clear gear tapping sound (poor explanation, but have video .. too big for upload)... dealer states limited slip on tundra is reason for sound.. no issue!! My issue is my 16 has 20k more miles n sound is very different! Thanks for any insight
  2. Sep 19, 2022 at 6:21 PM
    TTund16
    TTund16 New Member
    FYI, I don't think Tundra has a true limited-slip. Rear diff is an open diff but brake assisted to kind of simulate limited slip behaviour ... I think it's called Auto-LS. Tundra rear diff is very solid!
    Any chance it's wheel bearing noise. Or brake sticking a little or calipers or warped rotor. some say Tundra rotors are not the best. I don't have any issues with my '16 ... Do you drive in deep water a lot?
    AZBoatHauler likes this.
