2017 projector headlights with leveling?
Discussion in 'Lighting' started by RasTafari48, Jul 30, 2017.
  1. Jul 30, 2017 at 9:45 PM
    RasTafari48
    RasTafari48 [OP] New Member
    Hey all,
    I'm sure this came up before, but I just want to make sure before I take the plunge. When it comes to projector headlights for 2017, every headlight I come across claims that it's not compatible with the auto leveling function on the 2016-17 models. Has anyone installed spyders, or anything else and has a problem? Will it fit and just the leveling will not work?
  2. Jul 30, 2017 at 9:49 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    You can use your leveling motors on your SPYDERS. I've done it
  3. Jul 30, 2017 at 9:50 PM
    RasTafari48
    Thanks man. I was actually gonna delete this post because I took a little more time in the forums and found my answer. But I appreciate the response. Thanks again!
    T-Rex266 and Eclipsed & Floating like this.
  4. Jul 30, 2017 at 9:52 PM
    Eclipsed & Floating
    Voluptuous Whitey
    If you can't figure it out then just reach out. It was a little confusing at first but the second one only took 10 minutes once i figured it out
    T-Rex266 likes this.
