2017 highlander Rear creaking on low speed bumps
Discussion in 'Other Toyota Vehicles' started by spyshot, Jul 9, 2022.
  1. Jul 9, 2022 at 3:13 PM
    spyshot
    spyshot [OP] 1Cor 15:55-57
    Ohio
    2019 Tundra Platinum
    Platinum pretending to be Pro
    This noise is definitely in the rear suspension somewhere. Only happens at low speed when going over speed bumps, entering/exiting driveways, etc. I would describe it as a creaking noise.
    Only 38000 miles on my Car.
    Has anyone has this with their highlander?
  2. Jul 18, 2022 at 1:31 PM
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    My Highlander (2019 with 11k miles) does the same thing. I just need to schedule an appointment to have it looked at.
  3. Jul 18, 2022 at 2:06 PM
    Do those Highlanders have leaf springs?
  4. Jul 19, 2022 at 4:32 AM
    spyshot
    Ohio
    **UPDATE**
    I found that the problem is a creaky rear trailing arm bushing. There is a TSB on it, but I'm out of warranty. Another forum member lubricated with silicone lubricant and said that lasted years. I did the same. So far, no creak.
    If I was in warranty I'd have them replaced. For now, this is an acceptable fix.
    omgboost likes this.
  5. Jul 19, 2022 at 4:35 AM
    spyshot
    Ohio
    No
  6. Jul 19, 2022 at 4:35 AM
    spyshot
    Ohio
    I don't have access right now, but there is a toyota website somewhere that will show you TSB's on your vehicle. You may want to mention that to the shop.
    JDR76[QUOTED] likes this.
  7. May 1, 2023 at 9:58 AM
    JDR76
    JDR76 New Member
    WA
    I'm REALLY late on my reply to this... :D
    I didn't even realize it, but my Highlander is out of warranty. Tried to take it in, thinking it would be covered, and realized that I was past the 36 months! So I'll try to address this myself. It's really annoying.
  8. May 15, 2023 at 11:53 AM
    spyshot
    Ohio
    I sprayed silicone lubricant on the rubber bushings last summer. It solved the problem. The squeaking when away for a long time, but it is now starting to come back. Will probably have to re-apply every year. Not terribly hard to do.
    JDR76 likes this.
  9. May 15, 2023 at 12:02 PM
    JDR76
    JDR76 New Member
    WA
    Good to know it wasn't too hard to do. I still need to get around to doing this.
