2017 CM 6112 questions
Discussion in 'Suspension' started by BTBAKER, Dec 23, 2017.
  1. Dec 23, 2017 at 9:25 AM
    BTBAKER
    BTBAKER [OP] BE YOU. THE WORLD WILL ADJUST.
    Brad
    Castle Rock
    2017 Tundra Limited
    Hi everyone, I didn’t get exactly what I was looking for by searching so I’m reaching out for answers.
    I am planning to do 6112/5160 setup in the tundra and plan to set them at 1.9 just to level and give a better ride and perhaps get rid of some bed bounce.
    Will it align without issue? I don’t want to do anything else with UCA, diff drops etc. I put 5100 in my Tacoma and was told it would align no problem but I had to do UCA as it floated on the highway.
    Also, what would be a good tire size to run without any rubbing etc?
    Thanks for any input and Merry Christmas!
  2. Dec 23, 2017 at 9:55 AM
    831Tun
    831Tun crazy Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    TC LT w/ king 2.5 C/O and bypass, ADS bypass rear, Toytech shackles, TRD dual exhaust dumped, KM3 37s on Method standard +18. N_Fab front bumper, Westin rear w/ hitch relocate, RCI skids, Desert Eagle tranny skid, All Pro sliders, ARB dual compressor, 5.29 gears and ARB rear locker
    No need for UCAs unless you run a really wide tire with the stock rim and its +60 offset.
  3. Dec 23, 2017 at 9:56 AM
    BTBAKER
    Brad
    Castle Rock
    2017 Tundra Limited
    Alright, thanks.
  4. Dec 23, 2017 at 10:07 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    You’ll be fine at under 2”. If you do want flexibility on alignment than get spc uca. But only if you have a shop that knows how to align them. Most shops don’t know.
    BTBAKER [OP] and 831Tun like this.
  5. Dec 23, 2017 at 11:13 AM
    BTBAKER
    Brad
    Castle Rock
    2017 Tundra Limited
    Good deal. I may install them down the road but my budget allows just the shock upgrade for now.
    I get a decent bed bounce on cement highway here in Colorado. Will the 5160 reduce or eliminate it?
  6. Dec 23, 2017 at 12:42 PM
    831Tun
    831Tun crazy Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I don't have any experience with those. People who have 'em seem to like 'em. I've got Fox 2.5 rears and don't have any bed bounce complaints.
    BTBAKER [OP] likes this.
  7. Dec 23, 2017 at 1:12 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    @HBdirtbag had that setup and is for sale. He upgraded so he may have some input for you.
  8. Dec 23, 2017 at 1:32 PM
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    Hey man, I just installed 6112s, set at 1.9in on my 2017 last week. Alignment guy didn't say a peep about it and it rides great. Definitely a nice upgrade, and leveled it to within 1/10th an inch.
    Casper3, BTBAKER [OP] and 831Tun like this.
  9. Dec 23, 2017 at 3:20 PM
    BTBAKER
    Brad
    Castle Rock
    2017 Tundra Limited
    That looks great! You plan on putting bigger tires when you need to?
  10. Dec 23, 2017 at 3:31 PM
    Steve6
    Steve6 New Member
    Tucson
    Did you change anything on the rear? I'm leaning towards the 6112s at 1.9 on the front and leaving the rear stock for a while. Your truck looks great - level looks perfect.
  11. Dec 23, 2017 at 3:57 PM
    BTBAKER
    Brad
    Castle Rock
    2017 Tundra Limited
    I’m having everything installed next week. 1300 OTD with alignment
    geno0506 and MistrRoboto like this.
  12. Dec 23, 2017 at 4:00 PM
    BTBAKER
    Brad
    Castle Rock
    2017 Tundra Limited
    And I’m really hoping the 5160 tames the bounce on concrete highway..
  13. Dec 23, 2017 at 4:37 PM
    MistrRoboto
    Virginia Beach, VA
    Yeah for sure, just not in a rush. I'd go 285/70/18 when given the chance. Nitto Ridge Grapplers. I had 295/70/17s in their Trail Grapplers on my FJ and got almost 90k out of them.
    If they filled it out too much or I just want more lift, I'd likely do one CB shim up front for another .5in lift, and 1 inch shackle the rear.
    It rides really nice with the 6112s! You will be pumped.
  14. Dec 23, 2017 at 4:38 PM
    MistrRoboto
    Virginia Beach, VA
    Nope rear is stock. And it rides really nice. Debating between the 5160 and the 5100, but only because guys around here get me all pumped up for stuff I don't need. Reality is the stock rear is just fine for my highway driving
  15. Dec 23, 2017 at 4:41 PM
    BTBAKER
    Brad
    Castle Rock
    2017 Tundra Limited
    Thanks! I have the stock Michelin’s on as well. I hate to dump them with only 7500 miles. The 285s will be ok with no Mods?
    I might look at the Falken Wildpeaks when I have the extra cash..
  16. Dec 23, 2017 at 7:10 PM
    Cheapshot
    Cheapshot New Member
    Looks good. And just what I have been thinking about. I better start saving now. Damn I New I should not have logged on tonight.
    MistrRoboto and BTBAKER [OP] like this.
  17. Dec 24, 2017 at 4:54 AM
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    It should align with no issues. The 5160’s were much better then stock, and I never experienced bed bounce. It was a great upgrade!
    BlueBottle and BTBAKER [OP] like this.
  18. Dec 24, 2017 at 5:19 AM
    mgtundra
    mgtundra New Member
    Joplin mo,
    2015 mg tundra
    6112 bilstein coilovers,5160 remote resivor,camburg upper arm,sway bar,Trd pro skid plate,Trd pro mg grille,high flow air intake
    i did the 6112/5160 bilstein plus the camburg upper arm been 15k no issues love the way it rides on bad roads
  19. Dec 24, 2017 at 6:14 AM
    BTBAKER
    Brad
    Castle Rock
    2017 Tundra Limited
    Looks great! I keep being told that the UCA will not be necessary but you upgraded. Any particular reason?
  20. Dec 24, 2017 at 7:14 AM
    mgtundra
    mgtundra New Member
    Joplin mo,
    2015 mg tundra
    I was told 2in was probally all you could go before you might run into problems.with getting alignment issue so I had the $ so I did,looks better than the oem too,and If down the road I want to go for a higher lift one less thing to worry about lol
  21. Dec 24, 2017 at 9:59 AM
    BTBAKER
    Brad
    Castle Rock
    2017 Tundra Limited
    Good point. I don’t see myself lifting past level at 1.9 so I was thinking I would roll with stock but I don’t want issues. I was told the same on my 2010 Tacoma, pushed it up 2 inches and the alignment was never good. They got it close to spec but it floated on the highway and felt loose. Ended up replacing the UCA. I get why you did it and it was probably a good call but I’ll try stock and hope all is good. I also had to do a diff drop on the Tacoma because I was getting clunking at low stop and go speeds. I was told that wasn’t needed either but it was. You getting any clunking?
  22. Dec 24, 2017 at 10:49 AM
    Big Green Thing
    Big Green Thing My cause is to have no cause.
    Dallas, TX
    '17 Limited White 4x4
    DAP Tune. 1.5" level on front. Revolver X2 Roll Back. Firestone 2445 air bags. TRD sway bar.
    I did 1.5” spacers the front of my tundra and love the way it looks. Almost level with rear and looks better than stock (looks like a 4x4 should). Absolutely no compromise in ride or handing either. Spacers, installation, and alignment under $300. Just got my Firestone 2445’s in and ready to install on the rear to help with the heavy loads.
  23. Dec 24, 2017 at 3:34 PM
    mgtundra
    mgtundra New Member
    Joplin mo,
    2015 mg tundra
    No clunking at all everything good
  24. Dec 27, 2017 at 7:01 AM
    MistrRoboto
    Virginia Beach, VA
    Little better lighting stance pic. When is yours ready?
    Casper3 likes this.
  25. Dec 27, 2017 at 7:03 AM
    BTBAKER
    Brad
    Castle Rock
    2017 Tundra Limited
    Nice!! I’m going Friday to get it installed. I’ll report back with pics.
    MistrRoboto likes this.
