2017 Antenna mast snapped off
Discussion in '2.5 Gen Tundras (2014-2021)' started by slongo, May 18, 2021.
  1. May 18, 2021 at 7:32 AM
    slongo
    slongo [OP] New Member
    2017 Tundra in Barcelona red
    Side Steps - bed cover - matte black splash graphics
    So the radio Antenna mast snapped off the base yesterday leaving the threads in the mount and nothing protruding , Anyone else suffered this and if so how did you get the threads out of the base to replace the mast ?
  2. May 18, 2021 at 7:34 AM
    jdg1982
    jdg1982 New Member
    Florence, Colorado (From Louisiana)
    2017 Magnetic Gray Tundra SR5 4x4
    Happened to me a couple years ago. I tried to use a left handed drill bit and get it to come out. That didn’t work for me, so I ordered a new one and replaced the entire antenna mast.
  3. May 18, 2021 at 7:36 AM
    slongo
    Yea I am trying to avoid that lol
  4. May 18, 2021 at 8:33 AM
    TunBrun
    TunBrun New Member
    Sunnyvale, CA
    2017 5.7L Crewmax Blazing Blue
    I tried this as well. Didn't work and I started to strip the top threads because my bit was too large. Hasn't bena big problem yet but I am expecting to replace the whole thing eventually.
    @jdg1982 How hard was it to replace the whole thing?
  5. May 18, 2021 at 8:37 AM
    Cg13055
    Cg13055 @yota.parts.distributor
    South Florida
    Mcfly Tundra @yota.parts.distributor
    2012’4.0 Tundra-2004’4.7 crewcab-2021 2.7 Tacoma
    just get a used one for cheap, honestly I don't use the radio it's all bluetooth for me has been for years.
  6. May 18, 2021 at 8:40 AM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Stubby antenna! No more snappage!!
    WILLINH and Bammer like this.
  7. May 18, 2021 at 9:08 AM
    RussellVaughan
    RussellVaughan New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    took me 3 hours to replace the entire thing. there is really only one useful video i could find, and you have to watch it backwards because it starts with everything disassembled...the video shows you how to put it all back together though.
    the issue is corrosion. the mast rusts at the base, which allows it to break more easily. if you replace it or have someone else do it, be sure to coat all the threaded connections on the replacement antenna with dialectic grease to prevent it from happening again. and get a stubby antenna.
    TunBrun[QUOTED] likes this.
  8. May 18, 2021 at 10:51 AM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
  9. May 18, 2021 at 10:59 AM
  10. May 18, 2021 at 10:59 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    A few drops of Kroil (everyone has that right?) let it soak and try a left twist bit (use the appropriate size) after drilling a tiny pilot hole.
    I've removed a few bolts this way.
    Worth a try for $12 ...
    OEMTOOLS 25771 Five-Piece Left Handed Titanium Bit Set - Mechanics Length Drill Bits - Amazon.com
    Or cheaper if you just buy the one locally like @Black Wolf suggested.
    Key would be to soak it for a day or 2 if you never remove it.
    I pull mine every time I go thru a car wash..
  11. May 18, 2021 at 5:14 PM
    jdg1982
    jdg1982 New Member
    It wasn't too difficult, just time consuming. There's a lot that comes off. The wheel well liner, the glove box and underneath the passenger dash, the passenger A pillar. grab handle. The antenna connects under the A pillar.
    I followed a video, I think. I'll search for it.
  12. May 18, 2021 at 5:58 PM
    johnxmccoy
    johnxmccoy New Member
    Grove City, Ohio
    2019 Crew Max
    I just got mine out last week. Drilled a ting hole in the stud and I had a drill bit with a flat head on the tip and put in reverse and it slowly came out.'
    What stubby antenna has been satisfactory for a replacement?
