2016 Tundra w/ 38 gallon gas tank question....
Discussion in '2.5 Gen Tundras (2014-2021)' started by thumphrey, Jan 8, 2016.
  1. May 14, 2016 at 3:41 PM
    alalmcgrath
    alalmcgrath Old Fart at Large!
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    Read my post #28. You seem to be the only one in this thread that actually thinks about what they've been told and doesn't take it for gospel.
  2. May 14, 2016 at 5:45 PM
    Red Freighter
    Red Freighter Red Freighter
    Oregon City
    2013 double cab sr5 trd red
    2014 TRD wheels and TRd pro center caps. Stock 2014 running boards. Stereo gps dvd deck two 12" subs w/amp. Dvd Headrests. Rear air bags with compressor and air tank.
    I would like to thank everyone for sharing their views. I'm so over this. Krazie Sj was talking about his Tacoma with a 21 gal tank, well I had a Tacoma for 7 years and thought I had a 18 gal and the low fuel came on with a gal in it (So I thought) and never gave it a second thought. Blessed are the ignorant.
    V8sOnly likes this.
  3. Mar 26, 2017 at 3:23 AM
    Pirateradio
    Pirateradio New Member
    2017 tundra SR5 Crew
    275/75r20 Toyo MT, 20x9 KMC Granade XD series
    I'm a new toyota tundra world member, at only my second fill up, my truck only have 350 miles. Yes it's 2 weeks old, and first fill up was a courtesy from the dealer. I have a 38 gal. Tank but today it only took 30 gallons to kick off the pump at a Costco station. And display warning showed 50 miles to empty.
    So I'm asuming I had 8 gals. In the reserve?
    Yes im a little bit confused too. But like most people here. I better be safe having extra gas to empty, than sorry running out of it.
    Now the MPG is not the greatest if I only got 12mpg. (City only) Which I knew I would be. I got mud terrains and aftermarket wheels from the dealer, so I guess that affects it too.
    Anyways, after winning a lemon law suit, against GM because a defective 2014 silverado, and getting into a toyota world It was the best decision made.
    TOTALLY happy with my TUNDRA even though it would be always "BLOOD THIRSTY" 5.7 v8.....LOL.
    Viper3G likes this.
  4. Mar 26, 2017 at 5:35 AM
    Jus curious...any one here have the 46 gal tank from transferflow? Worth it?
  5. Mar 26, 2017 at 6:50 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I have the 48g transfer flow tank. My '15 Pro came with the 26g tank. I'm fed up with jerrycans for fuel and don't want to do that any more. The replacement with the 38g factory Toyota tank, which became available in 2016, costs more.
    For me it's definitely worth it. Maybe not for everyone. Also added weight, between the steel vs plastic plus the weight of the additional fuel it's about 200lb
  6. Mar 26, 2017 at 6:10 PM
    So would a 38 tank fit my '14 sr5 tss CM 5'5 bed?
  7. Mar 26, 2017 at 6:30 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    It's truly a 38 gallon tank.. I've had my truck for 2 months and the first fill up only took 30'gallons so the next 4 fill ups I did I drove it on purpose when it said 0 miles " low fuel" and I drove it around for another day!!! And the most my tank took last week was 35 gallons.. which means I still had 3 gallons left or a little less depending on what's in the fuel injectors and all that other stuff.. I won't do it anymore but those of you on your way to work with a 38 gallon tank and don't want to stop cause you're running late, you'll be fine.. you can drive around the rest of the day and be cool...
    Pirateradio and htw_hawaii like this.
  8. Mar 26, 2017 at 7:12 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I'm pretty sure that the 38g tank would go into the '14, @Roman helps with Toyota parts and could answer for sure, a
    Roman likes this.
  9. Apr 4, 2017 at 11:05 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Bump,
    Curious if a 38gal will install on my '14?
    @Roman or anyone?
    Thanks
  10. Apr 4, 2017 at 1:49 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    A transferflow tank is cheaper and 46 gallons
    Lilly and Roman like this.
  11. Apr 4, 2017 at 1:56 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Depends where you shop....found a 38gal tank that I could probably pick up for $4-500
  12. Apr 4, 2017 at 2:01 PM
    Pudge
    CT
    You should jump on that!
  13. Apr 4, 2017 at 2:03 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    I would like to....
    But I first would love to know if it'll work lol
    Do I need a new EVAP canister? Pump control module? Or is it a pretty simple remove/replace?
    Tank being sold comes with in tank pump, which I know is different between the two tanks.
  14. Apr 4, 2017 at 2:04 PM
    Pudge
    CT
    I'm not sure of all that but if you can get it that cheap you could flip it and double your money
  15. Apr 4, 2017 at 2:29 PM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    I looked up every single part associated with the two different tanks, and 99% of the parts are different. You would basically have to replace everything associated with the tank for the bigger Toyota tank. Fuel pump, charcoal canister, skid plate, fuel neck, lines coming directly out of the tank, etc.
    In other words, I'd go with the Transfer Flow. :D
    atman84 and 14burrito[QUOTED] like this.
  16. Apr 4, 2017 at 2:35 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I'd be very leery about using a used tank in my brand new truck. Not sure what dirt or contamination may be inside. Rebuilding a few injectors could eat that savings pretty quick.
    PermaFrostTRD and CM-LENNY like this.
  17. Apr 4, 2017 at 2:47 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Luckily it appears most of the parts listed are included...aside from the charcoal canister which is probably a pretty penny :(
    Ill just keep it until a diesel option comes out lol
  18. Apr 4, 2017 at 3:08 PM
    Roman
    Roman
    Franklin, TN
    14burrito likes this.
  19. Apr 4, 2017 at 3:09 PM
    #49
    14burrito
    2014 SR5 CM 4x4 5.7
    Not surprised the least bit at the price.
  20. Apr 4, 2017 at 3:19 PM
    #50
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
  21. Apr 4, 2017 at 6:07 PM
    #51
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Not sure if someone else has mentioned it because TL;DR. If your truck is new or your MPG meter has been recently reset, it will take a good while for the computer to "normalize". Also, Toyota is notorious for underestimating Miles To Empty, probably as a cya safety "feature". All that said, yes your tank is every bit as big as they say it is.
    toyohtadude likes this.
  22. Apr 5, 2017 at 5:16 AM
    #52
    chadjamesr
    chadjamesr New Member
    Chad
    Atlanta
    2016 Tundra Platinum 4x4 Crew Cab
    Fox 2.5 w/ DSC Remotes F&R Coach Builder +3 Shackles RW Wheels w/285/75/17 Terra Grappler G2 Interior and exterior changed to LED Retrofit headlights with DS2 4.0 Morimoto LED fog lights Morimoto 40" LED bar in front bumper Retrax PRO Tonneau cover RCI front skid plate Crystalline tint on all windows and windshield P&P Rock sliders and full skip plates
    Yes, Toyota is just bad about the low fuel light. On my 2016 the light comes on with about 8 gallons left in the tank. The other day my computer said I had 0 miles left and I still drove another 50 miles. When I went to fill up, it only took 32 gallons. My truck has around 7k miles on it, so the computer should have learned by now.
    Don't feel too bad though, when I had my hybrid Camry, the low fuel light would turn on when I had over a 200 mile range left. I always new I had plenty of fuel left, but that little voice in the back of your head keeps saying "the light turned on, I must be almost out of gas" but then you go to fill up and find out you could have gone another 240 miles.
    The 38 gallon take is great though. When you can go a few weeks without visiting the gas station you don't care what MPG you are getting.
  23. Apr 5, 2017 at 6:15 AM
    #53
    15whtrd
    15whtrd Mr. Blonde
    It needs those extra gallons of fuel to keep the pump cool. You don't want to run it down to 1 gallon unless it's your last resort. My 26 gallon tank always takes about 19 to 20 gallons when the low fuel light comes on. You have a longer tank so it needs those two more gallons than mine, as to keep the pump submerged.
    PermaFrostTRD likes this.
  24. Apr 5, 2017 at 7:07 AM
    #54
    Shooter
    Shooter New Member
    Forney
    2017 Magnetic Grey Metallic Tundra Limited Crewmax
    I have a 2017 Crewmax w/38 gallon tank and my first fill up was after the light came on, still drove 53 miles to work. The next morning drove to gas station with it sitting on empty and could only put in 30.471 gallons.
  25. Apr 5, 2017 at 7:15 AM
    #55
    Pudge
    CT
    You guys still are gaining about 10 gallons over me. When I fill up, I have gone past 0 miles to go and only put in 20 gallons in my smaller tank
    15whtrd likes this.
  26. Apr 29, 2017 at 6:27 PM
    #56
    F34R
    F34R New Member
    2017 Silver Tundra SR5/4x4
    My 2017 crewmax 4x4 sr5... 38 gal tank. Here's some numbers I've kept for the last few fill-ups.
    484 miles, low fuel light comes on. reads 35 miles to empty. Filled up, 30.2 gallons.
    480 miles, low fuel light comes on. 44 miles to empty. Drove to 543 miles, 34.5 gallons fill up.
    489 miles, low fuel light comes on. 37 miles to empty. 532 miles, 0 miles to empty. 540 miles, 33.3 gallons
  27. Apr 29, 2017 at 6:35 PM
    #57
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    So with Zero to go there's 4.7 gallons left
  28. Apr 29, 2017 at 6:45 PM
    #58
    F34R
    F34R New Member
    Seems that way. I'm averaging 16.7mpg too. I guess I could go around 78 more miles. So, 610 on a tank. Not toooo bad considering.
    R0CKETMAN[QUOTED] likes this.
  29. May 5, 2017 at 5:39 AM
    #59
    F34R
    F34R New Member
    Just a follow up...
    5/4...
    493.1 mte 36
    530 mte 0
    544.7 filled up with 32.4 gallons.
  30. May 5, 2017 at 6:27 AM
    #60
    jlee
    jlee New Member Vendor
    jerry
    Bay area CA
    2016 TRD Off Road on 35's supercharged and Kings and A 2002 SAS'ed supercharged Tacoma on 37's Linked front and rear
    Oh one or two.
    I have nearly 6 gallons after the hud says 0miles left. I normally full up around 1/4 tank but i never get worried if the fuel light comes on i know i can safely get another 40 or 50 miles after the hud says 0.
    Shooter likes this.
