2016 TUNDRA SR5
Discussion in '2.5 Gen Tundras (2014-2021)' started by AIRHEARTAUTO, May 20, 2024.
  1. May 20, 2024 at 2:11 PM
    AIRHEARTAUTO
    AIRHEARTAUTO [OP] New Member
    LINDA
    16 TUNDRA SR5
    I HAVE A 2016 TUNDRA SR5. REPLACED WIRING HARNESS, DUE TO SQUIRRELS CHEWING WIRES. THEN THE BATTERY LIGHT CAME ON. BATTERY IS BRAND NEW. THE ALTERNATOR IS OVERCHARGING BUT NOT GETTING TO BATTERY. CAN SOMEONE PLEASE TELL HELP ME OUT.TIA
  2. May 20, 2024 at 2:21 PM
    2mchfun
    Welcome from OKC! Blown fuse or bad/missing ground connection. Check all of the fuses, both fuse boxes, 1 under hood, 1 small one way up under the dash above brake pedal and toward the parking brake. Do you have continuity from the alternator housing to the negative battery terminal when testing? I would probably swap around fuses with same rating other fuses while looking them over.
  3. May 20, 2024 at 2:22 PM
    AIRHEARTAUTO
    LINDA
    16 TUNDRA SR5
    ALL THE FUSES ARE GOOD AND RELAYS
    2mchfun likes this.
  4. May 20, 2024 at 2:23 PM
    2mchfun
    Have continuity from alt to neg?
  5. May 20, 2024 at 2:26 PM
    2mchfun
    What happens if you put a jumper cable from engine to neg batt post? That will help diag ground issue.
  6. May 20, 2024 at 2:28 PM
    2mchfun
    Assuming the truck runs, yes?
  7. May 20, 2024 at 2:36 PM
    AIRHEARTAUTO
    LINDA
    16 TUNDRA SR5
    YES TRUCK RUNS FINE. NO ENGINE LIGHT ON JUST BATTERY. THE GROUNDS ARE GOOD.
  8. May 20, 2024 at 2:41 PM
    2mchfun
    Have a battery from another vehicle, old battery, or jumper car to try and hook up? Maybe you just have a new defective battery. Not likely, but maybe.
