2016 Tundra CM Spark Plug Replacement - 5.7L V8
Discussion in 'Performance and Tuning' started by Trk5100, Nov 18, 2019.
  1. Nov 18, 2019 at 7:11 PM
    Trk5100
    Trk5100 [OP] New Member
    Tate
    2016 Super White 4x4 SR5 CrewMax Tundra
    Upgraded from 2015 Tacoma TRD Pro in January 2019
    Hey there, Tundra Fam! I did a couple quick searches for Spark-Plug replacements for 3rd Gen Tundra's and didn't find anything. I figured I would share a few tips and photo's from tonights experience for anyone that wants to look over the process prior to poppin' the hood!
    Aside from the 8 Bosch Iridium plugs I bought from Amazon, I had the required tools on hand..
    Gather the following:
    • 3/8" Ratchet
    • 6" Extension
    • (2) 3" Extensions
    • 10mm socket
    • 3/8" swivel
    • Spark Plug Socket
    Once you've got your gear, pop your hood and add some odd-colored light!
    First - Remove the plastic "5.7L V8" cover. It should just lift straight up with minimal force.
    Disconnect your positive battery terminal as well... (10mm)
    If we start with the passenger side, you're going to want to remove the air intake completely in order to make some room to work. This involves a couple of hoses, an electrical connector, and the short use of your trusty 10mm socket to loosen a clamp.
    First, loosen this clamp with your 10mm socket so you can disconnect the air intake.2A03DDC4-DA7F-493E-814D-16EE127A334F.jpg
    Next, remove both of these two rubber hoses...
    Finally, disconnect this electrical connector in order to remove your intake manifold and set aside...
    Next, you're going to use your 10mm socket and some varying combination of your extensions and swivels in order to remove the coil packs. (Photo's are an example of one of the coil packs, located on the drivers side.)
    E07DF5A3-F78F-4050-B627-9C157197C2EA.jpg 301F50EB-50F1-4EDD-9861-93A7F1A977B0.jpg C08164EE-842B-46CC-BF43-9F01FBCB39A9.jpg F0C1FF63-328B-42E8-9C56-C69985A24CE7.jpg
    At this point you can insert your Spark Plug socket and 6" worth of extension in and remove the existing plug. Replace each plug as you go, tighten, and re-assemble coil pack.
    **On the plugs on the drivers side of the engine, I used two 3" extensions, inserting the first extension and the plug socket half-way, and then attaching the second 3" extension in order to avoid removing various other engine compartment components. Just my suggestion - do what works well for you!**
    Continue to replace each plug and re-assemble anything you removed in the process. There really weren't any plugs that were significantly more difficult to remove than others.
    ...& now you should be done!
    **I am a long-time user of various forums like this, but this is my first post anywhere with any sort of contribution. Please feel free to leave comments, tips, or suggestions on how to complete this task easier, or how to improve this post! My attempt was to keep this as simple, yet visually informative as possible! - - Take Care all!**
  2. Nov 18, 2019 at 7:16 PM
    Blueknights75
    Ron
    Clayton, NC
    Great write up! Out of curiosity how many miles are on your truck and how did the plugs look?
    Trk5100[OP] likes this.
  3. Nov 18, 2019 at 7:21 PM
    Trk5100
    Tate
    Thanks @Blueknights75
    Truck has 82000 miles on it. Here's a photo of two of the plugs..
    Blueknights75 likes this.
  4. Nov 18, 2019 at 8:32 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Nice write up. Gearwrench magnetic swivel spark plug socket might make this job a little easier
    Cesartt and TheBeast like this.
  5. Nov 18, 2019 at 9:01 PM
    TheBeast The Beach
  6. Nov 19, 2019 at 12:54 PM
    TX210Tundra
    TX210Tundra New Member
    2008 RCSB 5.7 2WD "Sport" / 2022 Limited Hybrid
    2008 - SOS 2/4 Lowering Kit : Firestone Bags : Bilstein Sports at 4 corners : TRD Pro Grill : TRD Pro 18in BBS Forged : Grip Pro LSD : Mike's "ByeNanny" : ARH LT 1 3/4 : ARH Cats : 3" X-Pipe: 3" Dual Borla XR1's / 3" Vibrant Resonators: 3" Tail pipes: DIY SABM: TRD Intake : AFE T/B Spacer : TRD Accelerator : LED Interior/Exterior : Atoto Pro HU : Cerwin Vega 10in Slim : AVS Visors : Sequoia Leather Seats : TRD shift Knob - OVTuned "Spicy 91 Torque Tune" 2022 Limited Crewmax Sonic Red Hybrid - TRD Filters : EGR Window Visors : Cheer Dring Android Adapter : RC Bed Cover : RC 1.75 Level Kit : Undercover Swing Case
    I'll be doing these this weekend. I went with NGK's new Ruthenium HX plugs which are suppose to be a better choice over Iridium. I shall see...
    I also sit at 82k miles
  7. Dec 2, 2019 at 4:26 AM
    Stig
    Stig New Member
    OP probably gets 1-2 more mpg now!
  8. Dec 17, 2019 at 3:41 AM
    TNTundra7
    TNTundra7 New Member
    TN
    2016 SR5 4WD 5.7L
    Bilstein 5100s, TRD RSB, TRD Wheels
    @Trk5100 You are a gentleman and a scholar. Great write up. Considering replacing mine.
  9. Dec 22, 2019 at 10:04 PM
    rt_tundra_co
    rt_tundra_co I'll get tired of tweaking this truck...never
    '15 SR5 CM TRD
    Magnaflow cat-back exhaust Leer Topper, color matched to truck Thule Aeroblade roof rack on topper FABTECH 4” Suspension Lift Decked Storage, 2 drawer SPYDER LED headlights and taillights kits Hertz HDP5 5 Channel Class D Amplifier 2 x 10” subwoofer boxed behind rear seat Door speaker upgrades by Elite Auto Sound Colorado Springs Lock’er Down EXxtreme Console Safe LD2043EX Lock’er Down rear seat 3 x safes Lock’er Down gun magnet 80 LED in-grill light bar Baja Designs LED ditch lights TRD Pro grill Rotiform SIX-OR 20x9 wheels 35x12.5R20 Toyota Open Country R/T tires TheSource sPOD power control hub with in-cab installed accessory switches Firestone Ride Rite air suspension system with Air Command remote, on board compressor and rear bumper air port SDHQ rock sliders
    Esteemed gentlemen of the sparks, I'm putting this plan together for my '15 5.7l as well and want to know recommendations for best plugs to use for this job. Note that I do not mind spending extra on increased quality or performance. I have 8 x Bosch 9613 Double Iridium plugs in my cart currently.
    Should I consider an improved coil while I'm at it or no sense?
    Thanks!
  10. Apr 18, 2021 at 7:10 AM
    charclif
    charclif New Member
    HOUSTON WE HAVE A PROBLEM. "Disconnect your positive battery terminal as well... (10mm)"
    Conventional Flow vs Electron Flow
    https://www.youtube.com/watch?v=gQEuliFx_Pc
    https://www.youtube.com/watch?v=8Posj4WMo0o&t=127s
    https://www.youtube.com/watch?v=QV6zFhc4c00
    You never disconnect the POSITIVE (+ RED) side of a car battery first.
    If you only disconnect the positive side only it is not safe to work on. power is still on
    Always disconnect the NEGATIVE (- BLACK) side first and re-connect it last.
    Once the Negative side is disconnected it is safe to work on. Even with the positive side still connected.
    No need to disconnect the positive side unless you are removing the battery.
    Direct Current (D/C power) Electrons flow from negative to positive.
    The CURRENT is coming out of the NEGATIVE post and returns to the battery into the POSITIVE post to complete the Circuit (Circle)
    Why you ask. If you disconnect the positive side first and your wrench touches any metal part (AKA GROUND) as you turn the wrench it will put 700 AMPS into the form of a arch (spark).
    That is why you have a rubber/plastic boot on the positive side and not the negative side.
    G_dog1, Mdjamesd and matictundra like this.
  11. Apr 18, 2021 at 7:49 AM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Thank you, you beat me too it.
    Mdjamesd and charclif[QUOTED] like this.
  12. Dec 27, 2024 at 11:03 AM
    Joro43
    Joro43 New Member
    2018 TRD Sport 4x4 quicksand crewmax
    1st tundra nautical blue 4x4 5.7l DC TRD had oracle custom color shift halo projector headlights, Fab4 bumper with 12k winch. RBP RX3 Grill Pro Comp stage 1 with bilstein 6112 coil overs SPC UCAs BFG KM3 35x12.5x20 with Moto metal 959s NFab running boards TRD LED DRL pioneer avh 4200nex with Polk speakers and JL 600w amp with JL audio stealth box 196k miles and running strong ready for another 200k until I wrecked it on 2/26/21 Just bought 2018 CM 4x4 5.7l quicksand TRD package upgraded headlights and adaptive CC Trifold bed cover, blacked out badges, KMC wheels BFG KO2 tires, 3/1 pro Comp lift FAB4 front bumper with rigid lights and fab4rear bumper.
    Good write up
  13. Dec 27, 2024 at 11:32 AM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    Careful of purchase of spark plugs. eBay and Amazon might sell you counterfeit parts. Get plugs from Dealer or auto parts store to be safe.
    Least of your problems with counterfeit plugs is bad performance over time or right off. Worst of your problems is plug could break in pieces and wreck havoc on your top end. Good luck. D
    TX210Tundra and ATV25 like this.
