2016 Tundra Cabin swap issues
Discussion in 'Electrical' started by Aidancamp, Jul 27, 2022.
  1. Dec 9, 2022 at 9:22 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Look at it is a learning experience. You have made it this far so keep going. I am confident you will get all the bugs worked out. Is there anything major still wrong with the truck to keep you from driving it?
  2. Dec 9, 2022 at 10:01 AM
    Aidancamp
    Aidancamp [OP] New Member
    Clayton,GA
    Other than it shifting hard and a couple of check engine codes the mechanic said it was drivable.
  3. Dec 9, 2022 at 6:54 PM
    zeekevin
    zeekevin New Member
    Check the fluid level on the trans
  4. Dec 9, 2022 at 11:19 PM
    Aidancamp
    Clayton,GA
    I would hope they checked, they drained and replaced the the transmission fluid when they took off the cover to replace the shift solenoid.
  5. Jan 12, 2023 at 9:24 AM
    Aidancamp
    Clayton,GA
    Just got the truck home today. I drove about 30min the transmission shifts hard and there are alot of errors on the dash.
  6. Jan 12, 2023 at 9:32 AM
    Aidancamp
    Clayton,GA
  7. Jan 12, 2023 at 9:35 AM
    Aidancamp
    Clayton,GA
  8. Jan 24, 2023 at 5:38 PM
    newwelder27
    newwelder27 New Member
    2021 Tundra SR5 TRD 4x4
    Led bed lights, RLB switch controller, ARB air compressor, ditch lights
    Sounds and looks like the tranny took some damage in the roll over. Or maybe check for pinched wires somewhere when guys replace cabs sometimes they aren't that careful when putting cabs back on and beds. Just something to check.
  9. Jan 24, 2023 at 8:35 PM
    Aidancamp
    Clayton,GA
    Yeah, some of the components possibly got messed up in the roll over other than the shift solenoid. I'm wondering if I should sell the truck or try and get it fixed.
