2016 Tundra 5.7 - What is this noise?
Discussion in '2.5 Gen Tundras (2014-2021)' started by timdebjaymax, Jan 26, 2019.
  1. Jan 26, 2019 at 7:11 AM
    timdebjaymax
    timdebjaymax [OP] New Member
    2016 Tundra 5.7 - Whines as in this video link ONLY when air is cold - It still whines on and off even after engine is warmed up - It has been doing this every winter for 3 years without getting better or worse - Replaced the fan clutch with no result - Thought maybe secondary air injection but the noise seems to be coming from the center of the engine not the passenger wheel well where that is. Any idea? Toyota service has not been able to pinpoint issue.
    https://www.youtube.com/watch?v=HkunIXiKFAw&feature=youtu.be
  2. Jan 26, 2019 at 7:20 AM
    Mediumrarepls
    Mediumrarepls New Member
    2019 Tundra SR5 TRD Offroad Crewmax Quicksand 4x4 5.7
    Power steering pump? I had a pump in my Honda that made that noise, only in winter. Does change when you turn the wheel?
  3. Jan 26, 2019 at 7:24 AM
    timdebjaymax
    It does not change when I turn the wheel but I am going to test that further to double check today. Oddly, it sometimes does it while driving in cold weather (engine fully warmed up) down a hill with my foot OFF the accelerator. Thank you for your help.
  4. Jan 26, 2019 at 8:35 AM
    bdpeelgren
    bdpeelgren New Member
    Round Rock, TX
    2014 Tundra CrewMax Super White
    Readylift 3/1, Rigid D-series fog lights, Supernova V.4, F/R Coverking covers.
    Mine does the same exact thing. Only when it gets around 30 degrees or lower. And only until the truck gets warm.
    I always thought it was the SAI.
  5. Jan 26, 2019 at 8:51 AM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    Since its super white, it's probably the sound of many panties dropping.;)
  6. Jan 26, 2019 at 8:54 AM
    timdebjaymax
    Does yours sound like it is from the center of the engine area like mine? I think the secondary air inj is located in the passenger wheel well area so that is why the Toyota dealer didn't think is was the sec air inj.
  7. Jan 26, 2019 at 9:24 AM
    bdpeelgren
    Round Rock, TX
    I’ve never really investigated it to far. It’s done it every winter since 2014 and with 126k miles now I figure it can’t be anything too concerning.
    040Tundra likes this.
  8. Jan 26, 2019 at 10:01 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    At least you cam your isn't leaking... Unfortunately mine is :mad:
  9. Jan 26, 2019 at 8:25 PM
    timdebjaymax
    True....
    Thanks
  10. Jan 26, 2019 at 8:27 PM
    ColoradoTJ AMSOIL Snob Staff Member
    Ford F-350, GMC 3500, Roush Mustang, Jeep Crawler
    Pfffttt....
    I whine when it’s cold outside too.
    :D
    Trooper2 and Boosted4runner like this.
  11. Jan 26, 2019 at 8:37 PM
    Boosted4runner
    Boosted4runner Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    It’s the SFCSFCSCW.
    It’s all good.
    (super fucking cold, super fucking cool, super charger whine)
    Trooper2, 15whtrd and ColoradoTJ like this.
  12. Jan 26, 2019 at 8:39 PM
    bdpeelgren
    Round Rock, TX
    o_O
  13. Jan 26, 2019 at 8:39 PM
    Boosted4runner
    WA
    Edited for explanation. :thumbsup:
  14. Jan 28, 2019 at 4:49 AM
    timdebjaymax
    Thanks for trying. Will check out the SAI more.
  15. Feb 4, 2019 at 1:04 PM
    Max Power
    Max Power Groovy Member
    2018 SR5 TRD Off Road
    TRD Dual Exhaust TRD Rear Sway Bar
    My Tundra does this as well. Also have a friend who had a 2010 and now has a 2015 Tundra, both of his made/make this noise. I don't know what it is, but it seems that every Tundra does it in the extreme cold, so I'm not going to worry.
  16. Feb 4, 2019 at 1:52 PM
    timdebjaymax
    Today my Toyota mechanic gave me the info below. The upper intake manifold was replaced today. It is going to be below 20 degrees here late this week so I will post the results.
    SUSPECTED CAUSE
    IS INPERFECTION IN INTERNAL CASTING THAT IS RESULTING IN
    AUDIBLE NOISE.INSTALL UPPER INTAKE MANIFOLD.
  17. Feb 10, 2019 at 4:22 PM
    Mediumrarepls
    Wow... thanks for the update.
    How many miles are on your truck?
  18. Feb 10, 2019 at 4:41 PM
    timdebjaymax
    25,000 ! It has been making this noise since new. Upper intake manifold was replaced. It was 18 degrees this AM and it made the same noise so that was not the solution.
  19. Apr 25, 2019 at 4:50 PM
    InfernoPro15
    InfernoPro15 New Member
    Mine make the same noise when warming up. It doesn’t have to be that cold either. Around 50 degrees it still does it. When it warms up it goes away. Been bugging me but looks like it’s normal. Does yours also vary in pitch while it’s making the noise. High pitch low pitch?
  20. Apr 25, 2019 at 6:42 PM
    timdebjaymax
    The pitch varies with engine RPM. Sometimes it will make the noise when going down a hill (only when air is about 30 or below) but the engine can be fully warm. If I put the truck in neutral and coast it still makes the noise varying the RPM so I know it has nothing to do with the transmission. The dealer tried a bunch of things but it never stopped. Maybe it is normal like you said but it would seem like more owners would be familiar with the sound.
  21. Nov 1, 2019 at 5:44 PM
    MarkInGB
    MarkInGB New Member
    2015 Platinum Barcelona Red CM
    I have the same noise... any update on it?
    sschulz2 likes this.
  22. Oct 16, 2020 at 11:50 AM
    sschulz2
    sschulz2 New Member
    2016 SR5 White
    Was there ever resolution or a fix to this issue? I've got a 2016 SR5 that started making this noise yet again this year as the temp was in the 20s this morning. Same thing every winter. Closest dealer service folks are pretty good and think its an air injection pump issue. Likely not worth the cost of replacing and ultimately not changing the problem... Doesn't seem to be causing other problems with the truck, just an annoyance.
  23. Oct 16, 2020 at 1:24 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    I'm thinking it's a idler pulley, they're a known problem. My truck has been doing the same the past few winter's. I'll be looking into this when I get some free time this winter.
  24. Oct 17, 2020 at 8:45 AM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    My truck made this same noise this morning and my idler pulley is pretty new, did it after I changed it last winter too, I don't know what it could be.
    Casper3[QUOTED] likes this.
  25. Oct 17, 2020 at 9:05 AM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    Well s@#t! Back to the drawing board:mad:
  26. Oct 17, 2020 at 2:25 PM
    Sumo91
    TN
    I know the OP replaced his fan clutch, but I'm wondering if you took your fan clutch off the night before, and started in the morning when it's cold without it, if it would still make the noise? Hmmm
  27. Jan 30, 2022 at 5:20 PM
    mikecsi
    mikecsi New Member
    Black 2016 1794
    Stock
    Is there any updates? My 2016 has been squealing for some time. I can be driving slow or on the highway. Thanks
  28. Feb 1, 2022 at 5:18 AM
    WXman
    WXman New Member
    Kentucky
    2016 Tundra SR5 Crew Max 4x4 5.7L
    Same here.
  29. Mar 28, 2023 at 7:15 AM
    nesnfred5
    nesnfred5 New Member
    2008 Sequoia
    Just wondering if anyone has chased this down? I have an 08 Sequoia, 239k and it just started making a similar noise. I describe it as someone blowing in the top of a coke bottle. I suspect the SAIS system. The pumps are in the passenger wheel well but the two valves are located under the intake manifold near the firewall. Also the valve unit connects to the hard lines running to the exhaust manifold and both connecting points (driver and passenger side) have a metal gasket. I’m suspicious either the valves aren’t opening or closing correctly or one of those gaskets is failing. Will keep this thread updated as I inspect mine.
